Fan settings:
fan_high_speed_ECT1_on = 196
fan_high_speed_ECT2_on = 200
fan_high_speed_ECT_off = 190
fan_low_speed_ECT_off = 182
fan_low_speed_ECT_on = 188
I know the basics of what his means but what exactly does ECT1 and ECT2 mean? You would think it would just be "ECT" like the lower fan speeds.
--Eliminating speed limiters--
(entering 16383 for all values effectivly turns off speed limiters)
- Speed limit stage 1 off = 16383
- Speed limit stage 1 on = 16383
- Speed limit stage 2 off = 16383
- Speed limit stage 2 on = 16383
- Speed limit stage 3 = 16383
Ok, great, I know what to put in for the values but why are there 3 stages of limits and what do the mean?
Set your base timing by the distibutor back to 10*. All of the timing tables in CalEdit are based on 10* base timing and it is included in the values you see.
Ok, set the base timing to 10 degrees. Now how do I set the timing to say..14 degrees?
Here are some of the n/a mods I think I will be able to change. What does "Za0" mean? Can anyone recommend a basic set up for my car using these variables? Should I change my air/fuel ratio with timing? Are these dumb questions? I hope not, lol. Thanks.
ZA0 (94-95) Basic setup
SCALARS
- Checksum Base Address = 0
- Engine Displacement = Actual CID or leave alone if stock bottom end
- Fuel Shut-off Deceleration Minimum ECT = 254 (disables)
- Fuel Shutoff Shifting Minimum RPM = 2000 rpm
- Fuel Shutoff Time to enable = 1
- ISC Maximum Closed Throttle Idle = 100 rpm higher than the desired idle
- ISC Maximum Drive RPM = depends on stall, cam, etc..
- Idle in Gear = depends on stall, cam, etc..
- Idle in Neutral = depends on stall, cam, etc..
- Injector Slope Hi/Lo = actual injector size & actual injector size * 1.2
- MAF Voltage Max/Min = 4.9999 & 0
- Spark Retard for Knock Sensor = 15 or higher depening on if S/C, NOS, Turbo or NA
- Fan Speeds = taylor to your needs
- Manifold Volume = no valid data for positive affects
- Max Spark Retard = 15 or higher depening on if S/C, NOS, Turbo or NA
- open_loop_delay_hyst = 0
- rev limits = taylor to your needs
- spark adder global
- spark_min_for_tip-in_retard = 15 or higher depening on if S/C, NOS, Turbo or NA
