01-08-06, 04:45 PM
|  | I've got your tool right here! | | Join Date: January 2001 Location: Tacoma, WA
| | | Technical Write Ups
All,
In the interest of getting some life back into this forum, I thought it would be nice to get some good tech articles specific to the V6 cars all in one place. Also, check the Write Up thread in S197 GT Tech for write ups that could overlap for V6 and GT models.
Please keep them small if you can. Post links to your hosted tech write ups or post 1 reply with pictures and explanations.
Try to keep the comments to a minimum. Although you may see something cool and want to praise the writer, please do so in a private message to help keep this thread uncluttered.
Posters, please put a title at the top of your write up to denote what it is you are writing about so it can be found a bit easier.
Let's see all that hard work you guys have been doing!!!
01-09-06, 03:49 PM
|  | Official Member | | Join Date: August 2005
| | | Zex Nitrous Oxide Kit
One of the things I get the most questions about is my Zex Nitrous Oxide Kit. It is the kit designed for the 2005/06 Mustang GT but works perfectly on the V6.
Here is the my write up about the Zex and my install. If you have any questions feel free to PM me!
Here's the link: http://www.tammyandjohn.com/Mustang/...ustang.htm#Zex |
01-09-06, 03:52 PM
| | | Paul's High Performance Shop Alternator Pulley |
01-09-06, 03:56 PM
| | | C&L CAI kit install and real world dyno results |
01-09-06, 05:28 PM
01-09-06, 08:27 PM
| | | Stock Rear Lower Control Arms
Sorry about this one... It's not a very technical write up... But this section shows the comparison between the stock LCAs and my replacement BMR adjustable LCA....
Little background, when I went to the Nitto 450s on the 100HP shot the car developed a bad case of wheel hop. The cure? New LCAs from BMR... The stock LCA are rather flimsy and take a look at the mushy stock bushing... The BMR firmly holds the rear axle in place and brought the wheel hop under control! Wow, what a difference!
Here's the small write up and pics: http://www.tammyandjohn.com/Mustang/...ustang.htm#MRT |
01-09-06, 09:41 PM
|  | former 10 second badass | | Join Date: August 2005 Location: Northern Virginia
| | | Dyno Results: Manglfow Dual Kit, AFE and SCT2
Not sure if this qualifies, but here is my dyno write up for: http://forums.stangnet.com/showthread.php?t=601819 - Magnaflow Y Pipe Dual Exhaust Kit
- AFE CAI
- SCT2 w/Professional Tune
I will be doing a write up on the TI CAI and then another one on the Zex kit with my the TI.
01-09-06, 10:21 PM
| | Quote: |
Originally Posted by rygenstormlocke Not sure if this qualifies, but here is my dyno write up for: - Magnaflow Y Pipe Dual Exhaust Kit
- AFE CAI
If not just delete this. I will be doing a write up on the TI CAI and then another one on the Zex kit with my the TI. | Post them up.
Perhaps it will spawn the "Bang for the Buck" thread that shows real HP gains on a dyno from different products. That seems like it could be an informative thread to the potential upgrader  |
01-09-06, 10:25 PM
| | Quote: |
Originally Posted by tylers65 Post them up.
Perhaps it will spawn the "Bang for the Buck" thread that shows real HP gains on a dyno from different products. That seems like it could be an informative thread to the potential upgrader  | Thanks! I just edited my post with the link to the stangnet thread I kicked off. This thursday, my car goes in for two days for the TI CAI tune, and for the Zex install/tune. I will post dynos for both and I will update my web site and thread with a scan of the dyno for my current write up at 190RWHP.  |
01-09-06, 10:29 PM
When you get it, we will start a thread for Dyno sheets. We will ask for members to post some baseline pulls as well to get an idea what these cars are averaging from the factory. Then we can start seeing what bolt-ons and go fast goodies do what.
Keep them coming guys!!!! |
01-14-06, 01:01 PM
| | | Tunable Induction Write Up |
01-28-06, 09:15 AM
| | | MRT single axle-back write up |
01-29-06, 03:45 PM
| | | MRT Rear Window Louver Install |
09-20-06, 10:01 PM
|  | start with the upper hole, and if more traction is needed, try the lower hole | | Join Date: May 2005 Location: 7200 feet
| | | S197 strut tower brace install
i installed a Strange Development STB and wanted you guys to see this if you havent already. install was a breeze and we wanted to give you some great pics http://www.stangnet.com/Tech-Article...ll-060920.html
i only had one hiccup, due to the TSB for 2005s front strut popping (TSB 05-9-11). an alignment was not performed after the TSB, and the struts were a little misaligned. a quick adjustment, and everything was good! |
10-19-06, 05:09 PM
| | | Throttle Body Coolant Bypass
Turns out the 2005 V6's have a "heated" throttle body.. while I have no proof that it's hurts performance, it sure can't help! So in an effort to squeeze every bit of performance out of the Mistress, I decided to do a "bypass" so the TB does get quite so HOT!
My write up for the TB coolant bypass is here: http://www.v6john.com/Main/Performan.../tb_bypass.htm | | Thread Tools | | | | Display Modes | Rate This Thread | Linear Mode | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
