02-12-06, 04:29 PM
|  | Official Member | | Join Date: April 2005 Location: the boondocks
| | | what would it take for a 94 cobra to beat an ls1
i was just wondering cause my friend has a 94 cobra with bbk shorty's h pipe (two cats) and flowmasters it also has a short throw shifter and the bbk cold air intake and throttle body (75mm)
i don't remember how much these cobras came stock so i was just wondering what would be enough to take out say a trans am ws6. |
02-12-06, 05:04 PM
|  | Keep it lubed .... keep it straight .... and keep it slow. It will come out. | | Join Date: March 2005 Location: North Carolina
| | Quote: |
Originally Posted by Kronos throttle body (75mm) |
Anyway .... I think he's gonna need a little more. Besides that, I don't know of many F-bodies out there that haven't been modded as well. So you have to take that into consideration as well. |
02-12-06, 05:11 PM
i'm not sure if it is a 75mm i was just guesing cause it looks pretty big my friend just bought the car and we are looking to throw maybe a cam on it and in the future some gt 40 heads u/d pullys are also on the way but if we got a sick enough cam would that put us close to the mill of a stock ls1 |
02-12-06, 05:20 PM
If it's a '94 Cobra ..... it already has GT40 heads. |
02-12-06, 05:26 PM
oh yeah sorry i know nothing about the 94-95s so i am going into this blindlyits fun though cause it is really expanding my mustang knowledge. what are som other good boltons that i could throw on there and sincve i am guessing the heads are already good enough i should focus money on other things?
-thanks alot |
02-12-06, 05:26 PM
|  | Official Member | | Join Date: April 2003 Location: Tampa Palms, FL
| | Quote: |
Originally Posted by SeventyMach1 If it's a '94 Cobra ..... it already has GT40 heads. | It has the crap GT-40 heads. You will need aluminum heads, U/D pulleys, and gears to even come close. The addition of a cam to all that will definately do the trick.
02-12-06, 05:34 PM
i'm sure your vortech helps alot too do you have any dyno numbers on your setup or at least an estimate |
02-12-06, 06:03 PM
I agree with Shaun. To keep up with them .... your best bet would be to go with aftermarket H/C/I. Preferably aluminum heads .... but IT CAN be done with WORKED iron heads & the right parts to compliment it. Twisted Wedge & AFR seems to be the popular head choice .... as they average 270-320 HP on our cars (depending on C/I). Do you a little search on heads, cams, intakes on here with the search function. It can reveal tons of info. There's also flow charts in the sticky's as well, I believe.
Or, you can go forced induction. Something else to search ..... |
02-12-06, 06:11 PM
thanks for the help fellas soon those pesky little formulas will be no match for our stangs. |
02-12-06, 06:48 PM
|  | Official Member | | Join Date: September 2003 Location: Detroit, MI
A h/c/i 5.0 will probably run with basic stock LS1s....but if they are modded you better have some more in your back pocket. Forced induction, nitrous, or a stroker is a must to have "confidence" when u pull up to a LS1...cause u never know if its modded or stock.
A h/c/i is definately a good start though. |
02-12-06, 06:53 PM
| | Quote: |
Originally Posted by nmcgrawj A h/c/i 5.0 will probably run with basic stock LS1s....but if they are modded you better have some more in your back pocket. Forced induction, nitrous, or a stroker is a must to have "confidence" when u pull up to a LS1...cause u never know if its modded or stock.
Yep. Like in another thread that's going right now .... they have more cubic inches on us. There's no replacement for displacement! (Actually there is ... but I won't get into that here). |
02-12-06, 07:01 PM
yeah i got a buddy with a 347 stroker in a 76 mustang II and it gets the job done i have access to any tool you could imagine and lifts here on base so with that said how hard are h/c/i installs on 5.0s same with stroking. |
02-13-06, 01:06 PM
|  | I didn't read this. | | Join Date: October 2002 Location: Orlando, FL
i run with most lid/cutout ls1's around here with only bolt ons. but i drive the **** out of my car. they usually have a good 2-4mph on me so good driving and traction are what do it. |
02-13-06, 01:21 PM
|  | Official Member | | Join Date: April 2003 Location: DFW Texas
First thing I'd do is get rid of that 4 cat mid pipe
Grady |
02-13-06, 01:30 PM
he doesn't have the 4 cat mid pipe it originally was just a real short o/r h pipe but he had to get 2 cats welded in to pass NY inspection. |
02-13-06, 01:34 PM
|  | Official Member | | Join Date: November 2003 Location: HUNTINGTON BEACH
I can beat an ls1 even with minor mods with whats in my sig. |
02-13-06, 01:40 PM
|  | have car, will race....wait, it doesn't run | | Join Date: October 2004 Location: New Lenox, IL
To be blunt, it takes quite a bit just to run with them. H/C/I, gears, traction, and a good driver are a must, even against stock LS1s. Modded ones are even more trouble, so matching parts vs. just throwing random parts together and hoping for a good combination is equally as important. Against a modded LS1, unless you're running a high compression 5.0 with a solid roller cam, 331. 347, or 351 swap, you start getting into the power adder territory, simply to keep up. |
02-13-06, 02:42 PM
| | Quote: |
Originally Posted by WHITE94COBRA I can beat an ls1 even with minor mods with whats in my sig. |
Thats what u call minor?  And the biggest thing which people have touched on is there is a HUGE difference between a LS1 and a modded LS1. Those things are already quick factory...and it only takes a little of this...a little of that...to unleash even more insane power. |
02-13-06, 02:51 PM
| | Official Member | | Join Date: July 2005 Location: Shelby Township, MI
| | Quote: |
Originally Posted by nmcgrawj Thats what u call minor?  And the biggest thing which people have touched on is there is a HUGE difference between a LS1 and a modded LS1. Those things are already quick factory...and it only takes a little of this...a little of that...to unleash even more insane power. | No he meant that he can beat a minor modded ls1 with all of his add ons.. |
02-13-06, 02:51 PM
ford should just scrap the v6 throw the 4.6 into the base model put the 5.4 in the gt and throw a big block in the cobra. |
02-13-06, 05:02 PM
| | Official Member | | Join Date: January 2006 Location: Christchurch, New Zealand
There's only one way you're going to easily beat a LS1, upgrade your tyres and suspension, put your car on a strict diet, and own him in the corners.
In a straight line, they just have too much over our 302's but their weight will bite them going through the twisties.
As per your original question on how to beat a ws6, well, luck would be a major part in it. |
02-13-06, 05:14 PM
My friend Tim has a ws6, he has exhaust, lid, and tune, and I can beat him pretty easily. Now if were talking F.A.S.T intake, head porting and a cam, I dont have much of a chance besides I can drive better than him. I have the advantage all the way to 6500 rpm, thats where my power is basically gone, where as a ls1 still pulls hard there.
And anything short of a R4 or A4 block with forged everything is minor bolt ons to me.  j/k nmcgrawj |
02-13-06, 05:42 PM
| | Quote: |
Originally Posted by Monsterbishi There's only one way you're going to easily beat a LS1, upgrade your tyres and suspension, put your car on a strict diet, and own him in the corners.
As per your original question on how to beat a ws6, well, luck would be a major part in it. |  |
02-13-06, 10:51 PM
|  | Member | | Join Date: January 2006 Location: Warren, OH
they are far from unbeatable
Most ls1's I've seen at my track run low 14s, high 13s around 99-100. Untuned I went 13.1 @ 104 and had taken care of MULTIPLE ls2 gto's. Tuned I've torn them up pretty good. But they do run!
I've also DRIVEN a 6spd 02 z28. Fun, but not as fast as theyre made out to be. Maybe we have bad air in ohio??
With the right mods and a solid tune in a well driven car, I wouldnt be too scared to line up. Everyone should have a power adder anyways  No squeeze, no fun :P |
02-13-06, 10:52 PM
AWD helps a bit tho
(thats with my laser..I pick up my 94GT saturday) | | Thread Tools | | | | Display Modes | Rate This Thread | Linear Mode | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
