Mustang Forums at StangNet
unstable suspension
This is a discussion on unstable suspension within the 4.6 Tech forums, part of the 4.6L Mustang category; I have a 2003 GT with max speed springs-2" drop (yes I know they are crap), bumpsteer kit, and BBK ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 03-15-06, 10:12 PM
Dave0803's Avatar
Official Member
unstable suspension
I have a 2003 GT with max speed springs-2" drop (yes I know they are crap), bumpsteer kit, and BBK C/C plates. Other that what I have listed, everything else on the chassis is stock. My problem is when I am driving on anything other than a flat smooth road the car wants to wander in every direction. What advice or suspension set up could help with this issue. I want to use it mostly as a daily driver and drag strip car. I was thinking of the ford B springs. I am also running the stock sized tires (245/45R17).
  #2 (permalink)
Old 03-15-06, 10:48 PM
squares98's Avatar
Official Member
  #3 (permalink)
Old 03-15-06, 11:42 PM
sgarlic's Avatar
My advice is to get an alignment if you haven't done so already.. that should help the wandering.
  #4 (permalink)
Old 03-16-06, 01:41 AM
tomustang's Avatar
Banned
bumpsteer
  #5 (permalink)
Old 03-16-06, 06:39 AM
stangliter04's Avatar
Official Member
shocks and struts/ if you are still running stock im sure they are shot.
  #6 (permalink)
Old 03-16-06, 07:17 AM
Kilgore Trout's Avatar
Fried or Broiled ?
Get special ball joints for lowered cars or drop spindles. Also get offset steering rack bushings.
  #7 (permalink)
Old 03-16-06, 09:33 AM
hognutz's Avatar
Official Member
Well first off do some reading. read that link above and go to maximum motorsports website they have some good reading. there is quite a bit of confusion over bumpsteer and how to fix it. I would not recomend offset rack bushings if you already have a bump steer kit. I don't have offseet bushings or bump steer kit and I don't really have noticable bump steer. my alinement is correct though.
1. Is the alinement good?
2. is the bump steer kit installed correctly?
there are four things that will cause a car to drive crappy.
1. alinement
2. bump steer
3. tramlining (following groves in the pavement)
4. worn out parts. (baljoints, bushings, etc)
tramlining is ussually going to happen a bit with high performance tires. If you car is wandering at any other time it is most likely bump steer or alinement.
I would personally go with a differnt spring and ditch the bump steer kit. I have a feeling the kit could just be installed wrong. they are not the most simple installation if you read the instructions. as long as the tie rod is at the same angle as the a arm you should not have much bump steer. you should be able to just look and see if this is correct.
I like the H&R springs. sport are 1.6,1.5 drop with like 490-570 rate up front. supersport are 1.75,1.6 drop with 700-750 up front. both are like 250-280 in the rear.
the ford springs are cheaper but only drop .75 in the rear. the b springs are pogressive and c spring is fixed 650 up front.
once you start undestanding what the mods do it is easier to find the problem. for example the x2 baljoints fix roll center issues with a lowered car but they take the a-arm and tie rods out of alinement and this is when you usually need a bump steer kit. this is something I would not mess with. I would just only lower the car 1" and run race springs. cheaper and don't have to mess with the install. offset rack bushing can change the relation of the a-arm to tie rod if nessesary but that is not always needed like some people think. they can also cause interference with some headers. so just read and search all the info is on here already.
  #8 (permalink)
Old 04-24-06, 10:04 PM
Dave0803's Avatar
Official Member
Since the last post I have taken the suspension back to stock till I can get the parts I want but the car actually feels worse now than it did before. Eevn just changing lanes because of the crown in the road causes the steering to become irratic. Going even over the slightest imperfection in the road where the suspension is not compressed evenly causes the car to become unstable. I had it alingned and checked over after I did the work.
  #9 (permalink)
Old 04-24-06, 10:32 PM
tomustang's Avatar
Banned
Quote:
shocks/struts
  #10 (permalink)
tomustang's Avatar
Banned
wow, I'm blunt
  #11 (permalink)
Old 04-25-06, 01:12 AM
Official Member
If you are lowering for looks, you will spend mucho money for that 2" drop. It will also kill your 1/4 mile ET's. Your car will not handle any better, than a properly tuned 1" drop suspension. My advice would be to get a 3/4" Bullit suspension kit that way you won't change the geometry of the car's front suspension/steering. In my experience the SN97 suspension seems to be very sensitive to changes so you should stick to proven factory mods (which is what I did) unless you want to spend a lot of money.
I know others have spent big bucks on their trick suspensions but I'm not ready to do that. I am perfectly happy with my slightly modded suspension. I also strongly recommend SFC's.
FWIW, the full-race springs are about 1" drop, maximum.
  #12 (permalink)
Old 04-25-06, 01:27 AM
tomustang's Avatar
Banned
But see he reverted back to stock, when he had the max sp'e'd springs in he blew out the dampers, now he needs replacments.
Why couldn't you just keep my answer to being blunt like I wanted it to be?
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Suspension Upgrades (Info) NJstangpilot 2005 - 2009 V6 Tech 1 04-12-05 04:52 PM
Got my new Evolution Motorsport suspension parts! (Another long post with pics) baglock1 94-95 Tech 7 12-31-04 11:17 AM
And another suspension question.... iamlance Classic Tech 16 10-21-04 08:16 AM
in laymen's terms, what do steeda's ball joints do? DerekStangGT 4.6 Tech 5 06-28-04 06:18 PM
Front re-allignment has dropped my front suspension by over an inch?? Brian68GT Classic Tech 8 05-14-04 08:04 PM
