04-12-06, 09:52 AM
|  | Official Member | | Join Date: November 2005 Location: Troy, Michigan
| | | Change to Automatic or keep stick shift I just want to hear everyone's opinion about this.
Currently I am building a beast of a mustang
331 Forged ESP Stroker SVO Block (comp: 10:1)
Ported and bowled Victor Jr Heads
Holley SysteMax Intake
Comp Cams Xtreme XFI Stroker Cam
1.6 RR
Thats the basics, I can put more info needed.
My goal is to make a street/strip monster. Next year she'll have a supercharger. I love stick shift, but I don't want to worry about blowing the crap out of it. So I'm thinking of a AOD? I know I will perform better with the auto, but manual is my favorite. What do you guys think, please give good reasons with your reponse. |
04-12-06, 09:54 AM
|  | Official Member | | Join Date: December 2004 Location: B.C. Canada
| | i like the stick because of how fun it is to drive. you would have to spend some money to get a manual that would hold up to that power. |
04-12-06, 11:13 AM
| | Official Member | | Join Date: March 2006
| | If you love a stick shift then get one. |
04-12-06, 11:46 AM
|  | Official Member | | Join Date: January 2003 Location: North Brunswick, NJ
| | I will be in the same dilemma soon. I say if you drive the car on the street a lot than I would keep the stick shift. If its going to be a track car than I would switch to an automatic for better reliability and more consistant times. |
04-12-06, 11:49 AM
|  | Official Member | | Join Date: March 2006 Location: Myrtle Beach, SC
| | Quote: |
Originally Posted by Blk91stang I will be in the same dilemma soon. I say if you drive the car on the street a lot than I would keep the stick shift. If its going to be a track car than I would switch to an automatic for better reliability and more consistant times. | I'm with him, the auto will be more consistant, but since you like the stick, stick with it. Yes, you will have to spend some$$$ to get a beefier trans but your car is already set up for it, so you would probbably save money in the long run.....IMO. |
04-12-06, 12:59 PM
| | I figured the replies would be like this. I'm just going to have to think about. I want something that will last and not explode with the power output I'll have. |
04-12-06, 02:00 PM
|  | Founding Member | | Join Date: September 2000 Location: Columbus~Georgia~31909
| | .... I swapped from a tremec to an Art Carr AOD and love it. Specially when I added the blower.
A well built AOD and converter will set you back a few $$$$ though. Some days when I just want to cruise I put it "D" and ride and flip OD on when I get up to 55mph. And 97% of the time, I manually shift it.
But don't swap cause people on here say swap, do what you want. If you like the stick I say keep it a stick and just get a better 5-speed to handle the power. |
04-12-06, 02:11 PM
|  | Official Member | | Join Date: June 2005 Location: Grand Rapids MI
| | I like both, The AOD if built right is very fun to drive, not to mention consistent and you never miss a gear, YOu can even put a manual valve body it it if you want to shift it all the time, Sticks are fun also, but there is stuff to worry about missing shifts, over revs, clutches holding up, shifting forks bending, So do want you want.....either way its going to cost some money, When you get into the upper power levels autos that are setup correctly are faster than sticks anyway.  |
04-12-06, 02:14 PM
| | Myke, I just want to hear some opinions and experiences so I can make a well thought decision. I'm open to any.
So are they any people on here making like 500+ hp with a manual trans? |
04-12-06, 02:21 PM
| | Yes there are a few, My last 89 Was around 500, I ran the stock T-5 with a heavy duty clutch, I was careful shifting, no power shifting and I didnt run any slicks, and it worked great until I sold it. Generally you would want to upgrade to a tremec or G force tranny though, They can handle 500 no problem. |
04-12-06, 02:27 PM
| | Right that is what I thought. I don't plan on running slicks because I want it to be more of a street machine. I'm looking at a TKO-600 to replace my T-5. I'm not sure what clutch yet.
It's just my dad thinks I should put in an auto and his justifications are that: I won't overrev, stronger than a manual, and its too hard to shift a car with 500+.
I understand his points all except the last one, he's never driven a 500+ hp car so I don't really count that as a point. I'm not trying get in a fight with my dad, I just want to hear more opinions. |
04-12-06, 04:48 PM
| | Member | | Join Date: April 2006
| | For drag racing auto + stall > manual. |
04-12-06, 06:37 PM
| | Quote: |
Originally Posted by soontobefastfox Myke, I just want to hear some opinions and experiences so I can make a well thought decision. I'm open to any.
Yep, Tremec..536whp. No problems.  |
04-12-06, 06:43 PM
| | [QUOTE=soontobefastfox]
Look at what Lamborghinis, Ferrari's, Turbo Porsches, and most other supercars have always been equipped with from the factory...Having had the privelage to drive a Gallardo  ( not quite 500 hp,) I can tell you the clutch and shifter required less effort than my wife's brand new Jetta GLI..Its all about getting the proper setup. |
04-12-06, 06:51 PM
|  | Official Member | | Join Date: September 2003 Location: Hamden CT
| | Dont be a woman...  shift your own gears. Nothing impressive about an auto going fast down the track, but a well driven stick shift is something to watch! The amount you would put into a well built AOD, you could spend a little more and drop in a T-56 Viper spec tranny. Will hold the power, and give you two overdrives for those long cruises. I am the biggest advocator of the standards, and unless your running deep 9s or better, I will never say go auto...
Listen to me or not, me personally, NO AUTO. |
04-12-06, 07:06 PM
| | Official Member | | Join Date: April 2005
| | Quote: |
Originally Posted by 25thmustang Nothing impressive about an auto going fast down the track. |  because im sure his main goal is to impress you. I would go with what you want, i went with a C4 because i want it to be fast and leave hard on the converter and i dont want to miss a shift and let the guy in the lane next to me take the win. Ive considered a stick, and may go with a viper spec one day, but a well built C4 with a 4000 stall leaving on the trans brake will put your balls in your throat. It seems stick guys hate atomatics but autos dont mind sticks, ill never understand it, but dont let us decide for you... |
04-12-06, 07:40 PM
| | I had and have driven fast versions of both and thats my opinion. I personally cant drive a car that my sister can hop in and drive faster (and yes she could drive an auto faster, she weighs less). I am more for the fact that it takes a skill to go out and bang gears in a stick, whereas it is much less skill to do so in an auto.
Hey you dont like my opinion, thats fine, I tried to put out my disclaimer before hand.
Also to note his goal was to have a fun fast car with a reliable tranny. A Viper T56 is reliable, and retains the fun factor of the stick. |
04-12-06, 07:59 PM
| | I think I'm going to go with stick shift, I talked to a guy a MMR and I'm looking to get the MMR TKO 750. I've always loved manual and my mustang was my first car and my first manual and I want it to stay that way. Now I gotta convince my dad, but its my money I just don't want it to go and hear the whole "I told you so" lol |
04-12-06, 09:29 PM
| | Quote: |
Originally Posted by SAY GO  It seems stick guys hate atomatics but autos dont mind sticks, ill never understand it, but dont let us decide for you... |
I have noticed that too..  Stick shift guys thinks it's the next best thing next to sliced bread or sex.  ( not flaming anyone guys, just cuttin up)
Now, if I had to run a c4 then I would of stayed with a stick shift. But a well built AOD is just as fun as any stick, IMO. Don't get me wrong, not saying their better, but can be as much fun.. If you have a manual/auto or full manual valve body,, and a good converter. |
04-12-06, 09:57 PM
|  | Founding Member | | Join Date: January 2002 Location: Close to Lansing, MI.
| | I would run a TKO 600. It's tough and it's going to give you better milage than a automatic and it's WAY more fun to drive!
SLAM THOSE GEARS!
~Matt. |
04-12-06, 10:07 PM
| | Founding Member | | Join Date: January 2002 Location: East ARKANSAS Delta
04-12-06, 10:12 PM
|  | Sergeant Tangnet | | Join Date: September 2005 Location: Port Elgin, Ontario
| | I like the manual but if I were building a car for alot of strip use I think I would build a nice C4 |
04-12-06, 10:43 PM
|  | Official Member | | Join Date: October 2004 Location: Ohio
| | Quote: |
Originally Posted by 25thmustang Dont be a woman...  shift your own gears. Nothing impressive about an auto going fast down the track, but a well driven stick shift is something to watch! The amount you would put into a well built AOD, you could spend a little more and drop in a T-56 Viper spec tranny. Will hold the power, and give you two overdrives for those long cruises. I am the biggest advocator of the standards, and unless your running deep 9s or better, I will never say go auto...
Listen to me or not, me personally, NO AUTO. | X2!!! |
04-12-06, 10:47 PM
| | i know its faster and more consistent down the strip in an auto but there is one very nice advantage to a stick....dropping a gear, tacking it up and dumping the clutch. that makes the stick worth it right there. |
04-13-06, 12:37 AM
| | Thats a personal thing too... I have had more fun banging gears in 14 second stick cars than 12 second autos. For some guys autos are the only way to go, for me and others, if your not slamming the clutch and hitting the gears as fast as possible, your just going for a cruise. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
