Mustang Forums at StangNet
What is the part called that oil filter and oil pressure sensor bolt into?
This is a discussion on What is the part called that oil filter and oil pressure sensor bolt into? within the 4.6 Tech forums, part of the 4.6L Mustang category; Cause I BROKE mine. Replacing oil pressure sensor, and didn't even get teh new sensor halfway bolted in when teh ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-22-06, 06:09 PM
Angry What is the part called that oil filter and oil pressure sensor bolt into?
Cause I BROKE mine. Replacing oil pressure sensor, and didn't even get teh new sensor halfway bolted in when teh entire assembly BREAKS IN TWO. I am so pissed right now I don't even know where to begin.
  #2 (permalink)
Old 04-22-06, 06:36 PM
sgarlic's Avatar
Randy Stinchcomb calls it "oil filter housing" in a few threads I'm seeing at MD.
  #3 (permalink)
Old 04-22-06, 07:03 PM
tomustang's Avatar
Banned
Oil filter assembly
Oil filter housing
oil cooler assembly
  #4 (permalink)
Old 04-22-06, 07:13 PM
DropTopPony's Avatar
Noob Slayer
i don't teh know.
  #5 (permalink)
Old 04-22-06, 07:29 PM
  #6 (permalink)
Old 04-24-06, 09:15 AM
RandyStinchcomb's Avatar
Official Member
Quote:
Originally Posted by 2002tj
in the above pic there are 2 parts, 1 is the engine oil cooler ($$$) and it bolts to the filters housing/adapter, also $$$
  #7 (permalink)
Old 04-24-06, 04:42 PM
Quote:
Really? I didn't think so, it appeared to be one part. I will know for sure when I drain teh oil and remove the old one tonight.
  #8 (permalink)
Old 04-24-06, 05:24 PM
Official Member
trust me, ther are 2 parts there
  #9 (permalink)
Old 04-25-06, 09:10 AM
Noob Slayer
Hey Randy, are there any differences on these from a 96 Cobra/96 GT? My 96 Cobra block came with this attached and if its the same i wont need to swap mine off my block.
  #10 (permalink)
Old 04-25-06, 09:18 AM
Official Member
yeah, its the same oil cooler & adapter used on SOHS's & DOHC's. now cars wthout the oil cooler have/use a different adapter/filter housing, if someone wanted to delete the oil cooler.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Synthetic Oil Question claytucc3 4.6 Tech 133 10-04-07 11:47 AM
oil filter failure PH2 stangme SVT Tech 8 03-01-06 05:52 PM
Low oil pressure after head swap. Ideas? LTDScott 5.0 Tech 4 04-01-04 10:26 PM
Part Near Oil Filter Leaking jims2321 94-95 Tech 5 03-19-04 12:56 PM
How To Create A Bypass For Your Pcv System marvinmycat V6 Tech 2 12-16-03 08:02 AM
