Mustang Forums at StangNet
Automatic 01 Mustang GT will not shift out of park
This is a discussion on Automatic 01 Mustang GT will not shift out of park within the 4.6 Tech forums, part of the 4.6L Mustang category; I got into my car the other day, started it up, and tried to put it into drive but it ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-23-06, 09:13 PM
I got into my car the other day, started it up, and tried to put it into drive but it won't shift out of park. If the engine is not running and the key is in the run position, I can shift it without a problem. Also, I noticed my brake lights are not working and I have heard from a couple people that as a safety precaution the car will not shift when there is a problem with these lights. Any ideas as to what would cause this? The fuse is fine for the brake lights and I am assuming it must be a grounded out wire since both lights aren't working. Any help would be greatly appreciated. Thanks,
  #2 (permalink)
Old 04-23-06, 09:18 PM
SaleenGT2001's Avatar
Official Member
check the fuse.
if the fuse pops again you will have a bad brake light switch.
  #3 (permalink)
Old 04-23-06, 09:49 PM
imblown-ru's Avatar
Official Member
do you hear the click of the shift lock when you press the brake? should be coming from down bythe shifter, and should be pretty noticeable if its working. Just push the brake down a little bit and listen.
  #4 (permalink)
Old 04-23-06, 10:38 PM
triggz's Avatar
Theres a small steel cable that runs from the brake pedal to the shifter base that prevents moving from park without depressing the brake... Pull off the trim piece around the shifter and press the brake, you will see the cable on the righthand/front side of the shifter base
  #5 (permalink)
Old 04-23-06, 11:48 PM
tomustang's Avatar
Banned
Bang down on the handle a few times and try it then, your handle head might be loose and lifted
  #6 (permalink)
Old 04-24-06, 09:10 AM
elite130's Avatar
Official Member
I had a problem on my '98 exactly like this...If you look under your dash on the brake pedal arm, you will see a switch with a couple wires coming off of it. That is the switch that makes your brake lights go on and allows you to switch out of park on an Auto. On mine, one of the wires was pulled out of the switch (I guess I probably hit it with my foot or something). All I had to do was to push the wire back in and drive it to the dealership, or auto part store, and buy a new switch for around $15 or so. It is an easy swap. But like you found out, the brake lights dont work if this switch isn't working properly, so be careful. Hope this helps you out.
  #7 (permalink)
Old 04-24-06, 03:43 PM
davergt's Avatar
Official Member
what he ^^^^^^ said, i had the exact problem.
  #8 (permalink)
Old 04-24-06, 03:44 PM
svttech76's Avatar
SuperMod
it doe snot
it's the brake light switch.
  #9 (permalink)
Old 04-24-06, 03:47 PM
davergt's Avatar
Official Member
what he said ^^^^^^^^^^
  #10 (permalink)
Old 04-25-06, 07:29 AM
RandyStinchcomb's Avatar
Official Member
there is also a "shift inter-loc solenoid" on the shifter, we sell quite a few of these for other Fords wth the same problem. part # F6ZZ-3F719-AC
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Change to Automatic or keep stick shift soontobefastfox 5.0 Tech 38 04-15-06 10:51 AM
72 mustang shift knob question 71mach72cj Classic Tech 3 03-20-06 09:56 PM
88 mustang 5.0 gt left rear park brake cable earmuff 5.0 Tech 2 08-11-05 08:48 AM
88 mustang 5.0 left rear park brake cable earmuff Classic Tech 0 08-06-05 08:46 PM
Getting automatic shift knob off.. cgrant V6 Tech 11 12-22-03 06:34 PM
