Mustang Forums at StangNet
Selecting An Aftermarket Tuner Package
This is a discussion on Selecting An Aftermarket Tuner Package within the Fox 5.0 Tuning forums, part of the 5.0 Tech category; Since there are several tuning software/hardware alternatives for our cars, it would be nice to have a comparison sheet of ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech > Fox 5.0 Tuning
Over 153,000 Members!!
Reply
  #1 (permalink)
Old 06-04-06, 02:32 PM
vristang's Avatar
Official Member
Selecting An Aftermarket Fox Tuner Package
Since there are several tuning software/hardware alternatives for our cars, it would be nice to have a comparison sheet of the common options.
Here is a list of what I am currently aware of.
Due to post size limitations on Stangnet this post will deal with EEC-IV tuners only. For information on stand alone units see post below.
I have not verified all of this info, so if you see an error please let me know.
If you have some info that should be added please let me know and I will update this post.
Please respond with any info you can add, especially for the non TwEECer options.
Fox EEC-IV Tuning Alternatives
TwEECer - This seems to be the most common route taken by Fox Mustang tuners. The TwEECer comes with all necessary hardware (a J3 "chip", and a 5 position tune selector), as well as 2 software programs. CalEdit is the program that is used to modify the tune. CalCon is the program used to create datalogs.
CalEdit is different from most tuning software in that it creates its own file type; .ccf as opposed to the industry standard of .bin. The original files placed on the computer by Ford were .bin files, and other tuners have not changed this, except the TwEECer. This does make the TwEECer files incompatible with other tuners. Not a big deal in most situations.
CalEdit and CalCon are both free to download from the downloads page of tweecer.com. http://tweecer.com/downloads.htm
A user manual is also available there as well.
EECEditor - This is a tuning software similar to CalEdit for the TwEECer system. Datalogging is not possible, but it can be used with other hardware packages, and is free to download from here http://www.moates.net/software-drivers-c-33.html Datalogging is not possible.
TunerPro - This is another free to download software from here http://www.moates.net/software-drivers-c-33.html. Datalogging is not possible.
PCMX - This software is not free to download, but has a reputation for being very powerful. Datalogging is not possible.
Moates - This company builds hardware that is used to burn custom chips that can be plugged into the J3 port. Moates seems to recommend the use of TunerPro or EECEditor. Datalogging is not possible.
EEC-Tuner -
The manual can be viewed here http://www.allfordmustangs.com/techa...CTuner_FAQ.pdf
FAST -
SCT - I currently know nothing about this system.
PMS - Taken from here http://www.turbomustangs.com/techart...ECUarticle.php
Overview: The Programmable Management System, P.M.S., is a plug-n-play system that works with your stock processor. The P.M.S. goes far beyond the capabilities of a performance chip, offering a broad selection of adjustments and tuning. Now you can take advantage of aftermarket performance components while still using the stock engine control computer. The P.M.S. offers a user-friendly interface with a large variety of options.
Latest News- Anderson Ford Motorsport has introduced the PMS system for the modular motor vehicles along with new data logging software, InterACQ. Also released is the PMS Upgrade for pre-04 models. A new chip, new handheld, and manual is included in the upgrade.
Information Source / Company Response- The information was supplied by Troy Chapman, co-owner of StangTuning.com with input from Brian Koestner and Rick Anderson of Anderson Ford Motorsport.
Approximate Cost
1987-1995 Mustangs $857.00 or $1,057.00 w/ Low Impedence Driver
1996-1998 Mustangs $1,077
1999-up Mustangs $1,077
1999-up Lightning and Harley Truck $1,077
Plug-in Low Impedence Driver $249.00
3-bar MAP sensor for boosted applications $85.00
Pre-04 PMS Upgrade $249.00
Optional Hardware:
AFM/EFI wideband sensor kit $549.00
InterACQ for Windows $269.00
InterLOG for Windows $175.00
Vendor
Anderson Ford Motorsport (888) 715-6487 www.andersonfordmotorsport.com
AFM is the exclusive dealer for the Programmable Management System and with the purchase of the PMS system you will receive a free start-up tune.
Hardware
Each P.M.S. system comes with the P.M.S. purple box, wire harness, hand-held monitor, 9pin serial cable, user manual, and data sheet.
The InterACQ and InterLOG come with software disc and user manual.
Software/Connection
The Programable Management System plugs inline with your stock processor and the handheld controller uses a seriel cable that plugs into the PMS box. Essentially is a "plug-n-play" set-up.
Hardware Designed for
Stock mustang or 1000+hp Mustangs
Special Features
· Global fuel adjustments.
· Air temp and water temp fuel and timing adjustments can be made from –40 degrees to +250 degrees.
· TPS voltages are now adjustable, which means you are able to set Idle and WOT voltages.
· Easier to use controller with adjustments down to 500rpm increments starting at 2000rpms.
· All engine data is displayed on one screen with the new handheld controller.
· Start-Up fuel controls to help hard starts on cars using 42lb or bigger injectors.
· Air fuel mixture is fully adjustable.
· Idle mixture and timing is fully adjustable.
· New Standalone Control, which overrides the stock processor giving the PMS full control where the rev limiter can be moved up to 9900rpms. Standalone Fuel and Timing adjustments can also be controlled independently as low as 2000rpms.
· Total spark and rate of advance is adjustable.
· Built in Two-Step rev limiter.
· Two programmable RPM/Throttle Output accessory control switches.
· Tunable nitrous oxide adjustment table.
· Tunable Supercharger or Turbocharger timing and fuel adjustments up to 30lbs of boost.
· Plug-N-Play installation
· Installs in less than an hour.
· New user-friendly manual and controls.
InterACQ
· Comprehensive PMS control, data acquisition, and Standalone Design and Editing.
· Automatic connection and triggering for racing.
· Logbook to keep track of data runs.
· Customizable monitors (i.e. wideband 02 sensor)
InterLOG
· Data logging only features of InterACQ.
Datalogging
There are two datalogging programs that the work with the PMS, the InterACQ and InterLOG. These are window-based programs and uses the 9pin serial cable to connect to the laptop, also a RS232 to USB adapter can be used. The InterACQ offers datalogging and more detailed control over the PMS settings. The InterLOG is a datalogging only program.
Additional Items Needed
Nothing else is needed. You can purchase the AFM UEGO 1000 wideband kit and have the PMS/InterACQ display and datalog wideband readings. The UEGO 1000 kit is $549.00.
Support
You can contact Anderson Ford Motorsport through their tech line (217) 935-2384 and you can download all the user manuals from their website.
Additional support can be found at www.stangtuning.com
Accel - I currently know nothing about this system.
Below are several support programs you may want to look into
EEC Analyzer - EA is a software program that will guide you through what changes should be made. EA can be used to analyze any datalog and is not specific to any of the tuner software. It can be downloaded here http://eecanalyzer.webhop.net/. The creator of the software (Clint Garrity) is very active in helping his customers with EA, as well as helping anyone to better understand the Ford EEC-IV. Cost is $50, and worth every penny!
SnEEC - This is a datalog hardware and software package. The SnEEC plugs into the factory main wiring harness in order to create datalogs. The package does not come with editing software; this is for datalogging only. More info can be found here http://www.racesystems.com/
  #2 (permalink)
Old 06-06-06, 12:16 AM
vristang's Avatar
Official Member
If any one has info that can be added please do so.
With so many options out there it would be nice to have a standard way to compare the tuners.
Just make a post with any info you have and I will keep the first post updated.
Credit will be given where it is due.
  #3 (permalink)
Old 06-06-06, 06:23 AM
millhouse's Avatar
  #4 (permalink)
Old 06-06-06, 09:06 AM
Official Member
I wondered how long it would take you to find your way in here Millhouse. hehe How did you go about tuning your turbo setup?
This system here has been peaking my interest over the last couple of months.
Holley Holley Commander 950
Overview:
Vendor/Reseller: Fonse Performance, Summitt
Latest News- 1/1/04 Holley introduced the Pro s/w as the standard for the Cmdr950
Information Source / Company Response- Dennis Moore / Fonse Performance
Approximate Cost
Cmdr950: $880-1050
MAP Sensor: 1 BAR included (2+3 BAR are $52 and $134)
Narrowband O2: 3 wire heated O2 included.
Wideband O2: Any standalond WBO2 can be added.
Hardware
A new Batch Fire ECU which can mount in place of the stock one or where desired. Additional wiring or vehicle modifications are required. Comes with new Main and Injector harness for cleaner look. The system requires the use of GM coolant, air temp sensors (included) and a GM IAC (Does not support PWM IAC) The ECU has a configurable Ignition setup. Will work with TFI distributors, aftermarket distributors, Hall effect systems or crank trigger
Software/Connection
Windows based, state of the art graphical software via serial cable to a laptop. The Cmdr950 software is universal so if you friend has one, you can use their laptop and download your map. Startup calibrations provided at no additional cost.
Hardware Designed for: Has been used successfully in anything from a 225hp stock Mustang to a 1600hp race car.
Special Features
All special features come standard out of the box. You don't pay extra for anything. This includes, Single pulse or Dual pulse per revolution injector firing sequence, TBI control, Closed Loop WBO2 support, Internal Datalogger, Fan control or 2 user selectable outputs via any RPM, TPS or MAP value, fuel pump control, knock sensor feedback control, Decel Fuel Cutoff, Programmable Load and RPM scale for best resolution of boosted engines.
Onboard 512kb Datalogger · 1Dedicated coil outputs · 2 General Purpose Outputs · 2 Definable Switch Inputs · Full Idle Control for stepper motors · Definable Knock Control
Datalogging
Yes, comes standard out of the box. You can datalog any sensor in the system and 2 additional analog inputs. Includes software to analyze your datalogs. You can datalog directly to a PC or datalog onto the onboard memory on the Cmdr950 and then download it later. You can also control when the datalogging automatically comes on or off based on any of the parameters selectable
If you are using low impedance injectors you will need a low impedance driver box.
Support
Support Hotline, call Holley Tech Service direct or vendor support, very comprehensive installation/tuning manual for every feature included w/ system.
  #5 (permalink)
Old 06-06-06, 09:27 AM
millhouse's Avatar
[QUOTE=Daggar]I wondered how long it would take you to find your way in here Millhouse. hehe How did you go about tuning your turbo setup?QUOTE]
Yeah…I was waiting for my moment to pounce.
I went with the good ole megasquirt setup. I'm running the msns-e which allows me to control spark as well as fuel. It also has an adjustable rev limiter built in as well as overboost protection. If you want to control an electric fan….yep, you can do that too. Water injection…no problem. Two step you say….yep, you can do that too. There are sooooo many options you have with it that it seemed to be a the most reasonable choice. The only downside (if you want to call it that) seems to be that you actually have to learn how to tune....and there is no "live" tech support. The message forums over at www.msefi.com can handle every know problem anyways.
I myself built my own…and through no fault buy my own ran into a couple stumbling blocks. I'm now back on track and will hopefully have her in tip top shape before to long.
So….for ~ $ 750 I bought the complete megasquirt kit, pre-made wiring harness, a lc-1 wideband 02 controller as well as the xd-16 digital gauge. On top of that I get to sell my pro-m univer maf sensor (no longer needed) to recoup some of the costs.
  #6 (permalink)
Old 06-07-06, 09:05 PM
srothfuss's Avatar
Last night I stabbed the same guy 7 times in a row.
Thanks for the link! I'll be doing a lot of reading it looks like.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Re: 2005 Mustang GT Anti-Theft Optional Package barrboy1 2005 - 2011 (S-197) Mustang 6 08-09-05 06:25 AM
Aftermarket C-Clips?! bobbys9350 5.0 Tech 28 04-12-05 11:06 PM
Aftermarket fenders V's original tooling STSFCTN67 Classic Tech 5 11-10-04 12:03 PM
need help.....trickflow package ?s 89five0 5.0 Tech 3 02-11-04 07:29 PM
