Mustang Forums at StangNet
C4 trans won't go into park unless I let the car roll a few inches
This is a discussion on C4 trans won't go into park unless I let the car roll a few inches within the Classic Tech forums, part of the Classic Mustangs category; I have had this issue for a long time, but have the bottom of the transmission opened up this weekend, ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Classic Mustangs > Classic Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-26-06, 01:01 PM
I have had this issue for a long time, but have the bottom of the transmission opened up this weekend, and thought I would try to finally fix this.
When I stop and try to put the trans into Park it won't lock in - the shift lever just comes back a small amount and sits between Park and Reverse, allowing the car to roll.
It will go into Park if I hold the shift lever in Park and allow the car to roll a couple on inches either forward or backward. When doing this it will lock into Park with a click and stop rolling.
Does anyone know what generally causes this? I'm working on replacing some seals in the trans and have the pan and valve body removed. I can see and move what I think is the shaft that puts the car into Park - it is a rod going back from the shift shaft area with a spring around it. I can't see what it goes back to, but I can move it forward and back 1/2 an inch or so.
Is there a common cause of this problem? Is this something I can address without much further teardown of the trans?
  #2 (permalink)
Old 08-26-06, 01:10 PM
krash kendall's Avatar
Official Member
Is it the original trans? The early cars came with a "Green Dot" C4 (there's a green dot on the shift indicator beside DRIVE) that shifted slightly differently than the later ones. The original shifter doesn't exactly line up with the indicated marks when used with the later C4. If you adjust the shifter rod (it's a turnbuckle type assembly) so that PARK works everytime the you may not be able to reach 1st and can only downshift as far as 2nd when manually shifting. Conversely, if you adjust it to reach 1st, you will have problems reaching park.
In my car I found a happy medium that allows PARK to work, but I still use the handbrake for security. If I slam it I can get to drop into 1st, but not every time. I have to order in the C4 ends for my B&M shifter and fix it for good.
  #3 (permalink)
Old 08-26-06, 01:58 PM
Not sure if the trans is original. My shifter has a white dot next to drive, and a green dot on a white dot next to 2nd.
The shifter seems to move all the way from 1st to Park, it just won't lock into Park without holding it all the way forward and rolling the car a couple of inches.
  #4 (permalink)
Old 08-26-06, 02:13 PM
Official Member
Yeah, you're right about the green dot location. I didn't walk outside to look. Shorten the rod and park will work fine. It sounds like you have the problem I was describing.
  #5 (permalink)
Old 08-26-06, 03:53 PM
I'll give it a try, thanks.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Here is a 99 Cobra I MIGHT trade for... BlackenedSVT 4.6 Talk 127 08-29-06 11:51 AM
Modular Motor Specs!!!!!!!!!!!!!!if Anyone Is Curious productj1 4.6 Tech 12 06-20-05 02:33 PM
S351 Fuel Pressure Question 96 S351R Saleen 35 12-15-04 02:02 PM
Suspension silver87 5.0 Tech 14 08-12-04 06:00 PM
Gran Turismo 4 Car list rudeone707 94-95 Tech 58 02-02-04 05:06 PM
