Thanks, the intake flow numbers were all sourced by different testers. Numbers will vary slightly.
Also, the intake numbers are averaged, not peak cfm flow.
Uppers typically flow more than a lower/upper. The lower intake is usually the more restrictive of the two part intakes.
The design is different as well, as I believe it was designed for the optional supercharger from Saleen. Correct me if I'm wrong.
