Mustang Forums at StangNet
The Dyno Sheet Collection
This is a discussion on The Dyno Sheet Collection within the 2005 - 2009 V6 Tech forums, part of the 2005 - 2009 (S-197) Mustang category; Alright we are starting a collection of dyno sheets to keep them easy to find. If you have a sheet, ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 V6 Tech
Over 151,000 Members!!
Closed Thread
  #1 (permalink)
Old 01-02-07, 07:34 PM
bigcat's Avatar
start with the upper hole, and if more traction is needed, try the lower hole
Alright we are starting a collection of dyno sheets to keep them easy to find. If you have a sheet, please submit a copy. All sections here will have a dyno sheet thread (for example, 5.0, 4.6, S197, etc).
I know several of you have very impressive 6ers, lets show them all off! This thread is not just for those with a power adder, we would like to showcase all dyno sheets regarless of the number of modifications. Even a stock dyno sheet is acceptable.
Submissions need to be in the following format:
forum that sheet needs to go into (ex. S197 V6)
your SN user name
### rwhp / ### rwtq
mod list goes here
[img] dyno_sheet.jpg [/img]
You can host your own dyno sheet via photobucket (or other host) or we can supply some FTP space as well. Email Tim if you would like him to host your sheet.
Submissions are to be made via Private Message to any S197 moderator, (preferably me) where that moderator can update this thread. Be advised, only posts of dyno sheets and details are going to be permitted to remain in this thread (i.e. only Staffers can post in this thread to update it).
Let's see what you've got!
  #2 (permalink)
Old 01-06-07, 10:14 AM
bigcat's Avatar
Rygen
278 RWHP / 362 RWTQ (DynoJet)
Mason Dixon Dragway
13.6@99.1 (on pnero stock street tires)
Modificaitons:
# Zex Base Kit 100 HP Shot
# Zex Racers Kit
# TI CAI
# Powerhouse Lower Control Arms
# Steeda Panhard Bar and Brace
# Magnaflow TruX Xpipe
# Dual Flowmaster American Thunder Mufflers
# SCT XCAL2
# PHP Alternator Pulley
# Ford Racing 3.73 Gears
# Ford Racing TLOK
# Stock Pnero Tires @ 30psi
  #3 (permalink)
Old 01-06-07, 01:05 PM
bigcat's Avatar
Rygen
320 RWHP / 371 RWTQ (Mustang Dyno)
Cecil County Dragway
12.4@109
Modifications
# Powerhouse Pipeline Turbo @ 10.38lbs (Note: Previous 12 second runs were also on 8.5lbs of boost!)
# Powerhouse Upper Control Arm
# Powerhouse Drive Shaft
# Powerhouse/CHE Drive Shaft Loop
# Powerhouse/CHE Panhard Bar w/Poly/Poly
# Powerhouse/CHE Panhard Brace
# Powerhouse K Member Brace
# SCT XCAL2
# Ford Racing TLOK
# LPW Girdle
# Reflashed Stock Converter
  #4 (permalink)
Old 01-19-07, 12:57 PM
bigcat's Avatar
ttt
Closed Thread
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
97 GT PI HEAD SWAP DYNO SHEET INSIDE theosan 4.6 Tech 36 10-29-09 12:15 AM
Dyno #'s after $750 in exhaust zenboy99 94-95 Tech 29 09-20-05 10:37 PM
The 306 Dyno Challenge. VibrantRedGT 5.0 Tech 89 09-17-05 03:50 PM
New Dyno Numbers Shibby 4.6 Tech 12 01-07-04 02:28 AM
Would someone host my dyno sheet... 98GtRioRed Power Adders 1 12-22-03 09:51 PM
