Mustang Forums at StangNet
Why should I get an Optima battery?
This is a discussion on Why should I get an Optima battery? within the 4.6 Talk forums, part of the 4.6L Mustang category; I see many posts saying "Optima is the best", "Optima for teh win", "Well worth it" and so on. What ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Talk
Over 154,000 Members!!
Reply
  #1 (permalink)
Old 01-03-07, 04:55 PM
propellerhead's Avatar
Official Member
I see many posts saying "Optima is the best", "Optima for teh win", "Well worth it" and so on. What I have not see is why. Why is Optima so much better than a regular Sears or Autozone battery? The way I see it is I can buy four Autozone batteries to cover me for 20 years for about the same cost as one Optima. What do I gain by spending $100 more on a battery?
Any Optima owners care to show me the light on this issue?
Thanks.
  #2 (permalink)
Old 01-03-07, 05:45 PM
SaleenGT2001's Avatar
Official Member
i have the red top in my car. the advantages are a full replacement warranty for 5 years on certain batteries. they are sealed gel batteries and have more capacity tahn standard batteries.
plus they just look better.
  #3 (permalink)
Old 01-03-07, 05:51 PM
Official Member
When they die though.... there's no warning, they're just dead.
On the other hand, I drove about 40 miles round trip at night with the headlights on and dead alternator and didn't know it until I was nearly home. Even then, the only indication was that my battery discharge gauge had swung to the right. I still started it up the next day and went back and forth to the parts store for a new alt.
The only other indication that I had (it only occured once) was when I stomped on the gas and got a backfire while in boost. It didn't make sense at the time but I wasn't getting proper spark to the plugs with all the other accessories running. It all made perfect sense once I'd discovered that the alt was dead.
So there's my good and bad for the Red Top. Hope it helps.
  #4 (permalink)
Old 01-03-07, 05:58 PM
DTNODYA's Avatar
Official Member
So do you just take it back where you bought it and get a brand new one? If so, I'm going to buy one for sure when my battery dies.
One time, one of my brothers friends gave him a red top but it was reading like 11.4 volts. I tried to charge it but it did nothing. Are they un-chargable because of the gel? Maybe just a bad one ....
  #5 (permalink)
Old 01-03-07, 07:19 PM
GDawg's Avatar
Mine is only a few months old with less than 100 miles on it. My car sits right now and is not being driven. I put a full charge on it and if I don't fire it up in a week, it's dead. Not sure if I just have a bad one or maybe the cold weather is too hard on it.
It does look good but all that extra money just for looks...?
  #6 (permalink)
Old 01-03-07, 07:24 PM
Official Member
That's what I'm seeing so far. There's nothing amazing about them to justify the 3x price. I think I'll go for an Autozone special. Even if I have to buy another one in 3-4 years, I'm still way ahead on cost.
  #7 (permalink)
Old 01-03-07, 07:38 PM
PULMEOVR's Avatar
On a Stangnet Vacation!
I've read quite a few posts on here about Optima batteries, and the consensus seems to be that they are more problematic then typical ordinary, wet-cell batteries. There seems to be good and bad comments, but the bad comments seem to take majority. People seem to get them for several reasons:
A) Fall into trend that they are significantly better batteries (when used without heavy duty accessories such as a stereo etc.)
B) Like the look
C) Need the extra power for accessories
That is what I've gathered anyways, FWIW.
Matt
  #8 (permalink)
Old 01-03-07, 07:58 PM
MakotoS13's Avatar
Official Member
i have one in my 240 because i needed a gel cell due to it being a hatchback.
  #9 (permalink)
Old 01-03-07, 08:04 PM
DropTopPony's Avatar
Noob Slayer
if i had a stock stereo/alarm etc i'd stick with a regular battery...i went optima to see how good they were. I'm on my 3rd one in 7 years. 2nd one only lasted 1 year and was replaced under warranty thus why i'm on #3...the first one lasted 5 years with no problems but the 2 newer ones don't seem to be of the same quality as my first.
  #10 (permalink)
Old 01-03-07, 09:42 PM
droid#83853's Avatar
carfax for friendship
A question I can answer. I studied batteries and the technology. I even wrote some papers on it. In short, the Optima is good if you are running juice draining accessories like a big amp, coffee maker, microwave, or washing machine in your car. They can deep cycle like a sonavabitch, and come back from the brink. Regular lead acid batteries never fully recharge. The gel batteries also last longer, are more stable, and if you roll your car, the battery can be taken out and put in your next car. They do not corrode things like a conventional auto battery. The big problem is when the battery overcharges. An overcharged gel cell is junk. Basically when the plates inside get overcharged they; (note: keep it easy and short) well it gets a dead spot. So you end up with less juice. A voltage reading is not the best way to test a battery. The ideal way is to submit it to tests while in the car, under various loads. Just cause you got some volts doesn't mean you got some amperes. A home multimeter won't handle the few hundred amps a battery is producing. You gotta throw down a couple of G's for something that can do that. Also an Optima weighs a crap ton. Unless you are racing, want to keep the battery tray in mint collector condition, or just like colored batteries, I wouldn't get an Optima. Regular old Diehard's and the like are great for everyday use. Take a used battery to an auto shop. Most of them have the equipment to test a battery properly.
  #11 (permalink)
Old 01-03-07, 10:47 PM
O-G
If you do get an Optima, be warned: you have to modify the stock battery tray to make it fit.
I run the yellow top, but I have a lot more voltage draining accessories than most people do.
  #12 (permalink)
Old 01-04-07, 12:24 PM
Seraphitia102's Avatar
will post boobie pics for a supercharger
I run an Optima because I have 2 amplifiers, subwoofer, and a capacitor.
  #13 (permalink)
Old 01-04-07, 12:56 PM
Official Member
I only have the stock Mach 460 in my car. The sweet sweet exhaust note overpowers the stereo so I hardly turn it on. I don't drive around at night with my fog lights on. In my case, I see no reason to spend the money on an Optima.
Thanks for everyone's inputs.
  #14 (permalink)
Old 01-04-07, 01:21 PM
VOORHEES's Avatar
My stock battery has lasted 7.5 years, I'm getting another one just like it. $65.89 from the dealership.
  #15 (permalink)
Old 01-04-07, 01:23 PM
DTNODYA's Avatar
Official Member
Quote:
  #16 (permalink)
Old 01-04-07, 01:27 PM
dls322's Avatar
Official Member
Don't regular batteries vent gases though? Optima or other brand gell batteries don't and can be used without a vent tube. I got one when i pickup my battery relocation kit. Still have yet to install it so we shall see.
  #17 (permalink)
Old 01-04-07, 01:32 PM
speedfreak98r's Avatar
Banned
Motorcraft>all.
Where's Kilgore to help me argue this point?
  #18 (permalink)
Old 01-04-07, 01:36 PM
SRT Handz's Avatar
I tripped & fell down and cut myself & got blood
on my Abercrombie & Fitch shirt & tore my Abercrombie & Fitch shirt & now
I can't wear my Abercrombie & Fitch shirt because I got blood on it.
And it got torn, too.
Dry Cell Owns!!!
  #19 (permalink)
Old 01-04-07, 01:39 PM
Banned
Quote:
Originally Posted by SRT Handz View Post
Dry Cell Owns!!!
Pipe down, ya stoner.
  #20 (permalink)
Old 01-04-07, 02:11 PM
Shiroelex's Avatar
There's nothing worse than automotive blue balls.
Wow, there's some bad info floating around randomly in here. The Optimas are so special, because they are spiral cell. That's why they have the round bulges. They are coils of plating one inside of the other, rather than standard rectangular plates like a standard battery. This gives them more surface area inside. They are gel-filled, so you could mount one completely upside down, if you so desired. Vibration does not hurt these batteries. They are also preferred because of their massive reserve capacity typically. I run these batteries in alot of industrial equipment at work. The only downside, is you can't test the cells individually in the same way you could test a standard battery, but who does that anymore these days. You can still load test the cells the old way. Autozone does this for free. If you have an old 65 series battery, an Optima produces twice the cranking amps and reserve capacity, for damn near half the weight. The 58 series batteries are pretty close to the same weight.
As for some randomly dying; they did have a large batch that came out bad. Of course, that's why they have such a huge warranty. My last one I bought about 6 months ago is still going strong, in a car that's only started once a month or so.
  #21 (permalink)
Old 01-04-07, 03:26 PM
Official Member
So Optimas are good if...
You often run lots of electronic accessories in your car.
You plan to mount your battery upside down or in the trunk.
You only start your car once a month.
You go off-roading to shake up a bottle of chocolate milk.
You just like the looks of a red or yellow battery.
You like stuff that "ownz".
You like spiral cells.
None of these apply to me.
  #22 (permalink)
Old 01-04-07, 05:00 PM
Orange...'s Avatar
Official Member
I only have one thing to say:
Mine is rated at 650 ca and 540 cca. When I bought it (3 years ago), it tested at 1400 cca @ 12.85 volts... I just tested it last week and it's still doing 1100 cca at 12.8something volts.
Thats more then doubled the power that is advertised...
I will never buy another battery.
  #23 (permalink)
Old 01-04-07, 05:40 PM
007's Avatar
007 007 is offline
GoldMember
Quote:
<Rushes to the store to get one ASAP. />
  #24 (permalink)
Old 01-04-07, 05:41 PM
007's Avatar
007 007 is offline
GoldMember
So what is a good LIGHTWEIGHT battery anyway?
  #25 (permalink)
Old 01-04-07, 06:40 PM
Stang|ess's Avatar
seeking cyber partner(s)
slightly more .
the main question; can it power up the flux capacitor in my car?
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Anyone using Optima Red Top battery , what part # i need Slow5.0 94-95 Tech 13 03-04-06 11:24 PM
OPTIMA Battery Billet Hold Down GROUP PURCHASE!! PaLiAcH 4.6 Tech 12 01-17-06 12:42 AM
Optima Battery Seraphitia102 4.6 Tech 20 10-23-05 12:21 AM
OPTIMA Battery Billet Hold Down Group Purchase! PaLiAcH 4.6 Tech 2 12-03-04 06:52 AM
Battery relocation using Optima battery FastLane68 Classic Tech 5 07-03-04 03:35 PM
