Quote:
Originally Posted by back2fox I checked everything and nothing helped. I unhooked my mass air meter and finally a good idle. I rotated the position of my mass air meter about 45 degrees and plugged it back in. It finally will run on it's own. Hopefully this will help someone else. |
See item #8 on the checklist...
Quote:
Originally Posted by Surging Idle Checklist 8.) MAF meter on CAI system that needs clocking or protection from engine compartment air turbulence. A cone type filter located inside the engine compartment is almost sure to have surge problems due to the hot, turbulent airflow around it. Try cleaning the MAF element & then "clock" the MAF by rotating the entire MAF housing to see if changing its position helps any. |
