Newest Product Release Fits: 1994-2004 Ford Mustangs
Camber/Caster Plates:
Do you need to take control of your Mustangs front suspension? You can do it by using a set of J&M Products adjustable caster and camber plates. J&M plates replace the stock rubber strut mount bushings with a chrome-moly spherical bearing, allowing you full control of the front suspension alignment. Whether you want your alignment set for track, street, or strip, these plates will allow you to fine tune your alignment so you can get the most out of your car. The bearing mounts are completely adjustable and are 100% high frequency pulse welded for the ultimate in strength, durability, and fit. These camber/caster plates also feature a special chrome moly replaceable Teflon lined spherical bearing for a noise free quality ride. J&M Camber/Caster plates are now coming with a LIFETIME WARRANTY which covers bearing failure, main plate bending, or just over abuse. That is right if you are the original owner and bend the plates or wear out the bearings they will be fixed or replaced for free. That is how confident we are that you are purchasing the best camber plates available.
J&M Products plates include the following features:
-LIFETIME GUARANTEE against bearing failure and main plate bending or breaking.
-Slots for adjusting caster and camber independently from each other.
-Easy adjustment for Street and Race applications without the need for taking apart and rotating the camber plate.
-Replaceable highest strength chrome moly Teflon-lined spherical bearings for noise free performance.
-Greatest increase in suspension travel for lowered cars.
-Powder coated for great looks and long lasting protection.
-4 bolt option for the 94-04 Mustangs vehicles for coil-over use.
-Alloy steel main support plate for ultimate strength.
-Press in studs allow for more suspension travel clearance on coil-over applications over any other design available.
-Bearings and bearing mounts are loaded and supported from the bottom to remove the load from the hardware.
