03-17-07, 10:57 AM
| | Official Member | | Join Date: May 2005 Location: Flower Mound, TX
| | | P1443.. What does it mean?
Since I purchased my GT, the check engine light has been coming on and off. It usually only stays on for a few minutes every 2 weeks. I went to AutoZone while the CEL was on, and they gave me this code.. P1443. It says on the reciept they gave me, "Evaporative emission control system control valve." First of all, is this that bad? Second, where is this so called valve? If it has something to do with the midpipe, I'm just gonna fix it by an o/r pipe with some MIL eliminators. So, help me please! |
03-17-07, 11:36 AM
| | Official Member | | Join Date: November 2002 Location: Cape Canaveral FL
I had that code once or twice a long time ago. It was caused by the gas cap(loose). I just reset the code and never saw the code again. HTH |
03-17-07, 11:40 AM
yeah, they reset the code for me but i hope it doesnt come back. I noticed that my gas cap doesnt feel like it locks in too tight, but it still seems tight enough to not cause a problem.... |
03-17-07, 01:46 PM
|  | Old guys rule!!! | | Join Date: March 2003 Location: Sea of Tranquility
| | Quote:
Originally Posted by 4.6vertGT yeah, they reset the code for me but i hope it doesnt come back. I noticed that my gas cap doesnt feel like it locks in too tight, but it still seems tight enough to not cause a problem.... | It could be tight but not sealing properly...
From another thread: Quote: |
Originally Posted by svttech it's for the purge flow sensor voltage. the purge flow sensor voltage is part of the evap emmisions system. | Quote: |
Originally Posted by ford pc/ed 1996 Continuous Memory Diagnostic Trouble Code (DTC) P1443 indicates an incorrect evaporative system purge control valve flow.
Possible causes:
Obstructed, open or cracked hoses between EVAP canister purge valve and intake manifold.
Damaged EVAP canister purge valve.
Damaged PF sensor. | |
03-17-07, 10:30 PM
|  | SuperMod it doe snot | | Join Date: January 1999 Location: the people's republic of massachusetts
this code will not be set by the gas cap being loose.. that code would be for a gross evap leak, this is a electrical fault most likely a bad evap canister purge valve. take a look at the electrical connector on it and make sure it's ok. |
03-18-07, 02:07 AM
|  | Official Member | | Join Date: September 2003 Location: Mb
| | Quote:
Originally Posted by svttech76 this code will not be set by the gas cap being loose.. that code would be for a gross evap leak, this is a electrical fault most likely a bad evap canister purge valve. take a look at the electrical connector on it and make sure it's ok. | What he said ^^ |
03-18-07, 09:51 AM
thanks for the help guys, i checked the connectors and i guess ill see if it ever comes back... |
03-18-07, 09:55 AM
| | Quote:
Originally Posted by 4.6vertGT thanks for the help guys, i checked the connectors and i guess ill see if it ever comes back... | I get the same code on occasion. Throws 2 in succession. Just bee too busy with other items with the car to fool with it yet. |
03-19-07, 07:55 AM
|  | Official Member | | Join Date: May 2005 Location: Randallstown, Md
what year is the car?
if its pre 1998, I'd suspect the canister purge solenoid and the thermistor, very common problems on pre 1998's wth 60k or more |
03-19-07, 08:45 AM
wow, thanks. its a '96. good call. but would i just go to the dealership and ask for those parts, or pay a bunch of money for them to hopefully tell me its those parts? |
03-19-07, 09:16 AM
| | Quote:
Originally Posted by 4.6vertGT wow, thanks. its a '96. good call. but would i just go to the dealership and ask for those parts, or pay a bunch of money for them to hopefully tell me its those parts? | its a common problem.
parts need are a E6ZZ-9C915-A canister purge solenoid @$46.30* and the thermistor, part # F57Z-14A606-BA @$18.00*
*wholesale, thru us. both are dealer ONLY parts |
03-19-07, 10:32 AM
thanks alot randy. and by the way, are these parts that are easy to install? |
03-19-07, 10:42 AM
| | Quote:
Originally Posted by 4.6vertGT thanks alot randy. and by the way, are these parts that are easy to install? | very easy, both parts are on the same vacuum line comming off the plenum on the rightside of the engine, near the firewall. and if you have trouble getting them, we have plenty in stock |
07-17-07, 09:06 PM
| | Official Member | | Join Date: July 2007
SORRY TO BRING BACK THE OLD THREAT.
RandyStinchcomb , do you still carrry those 2 part ? I really need it now. thanks |
07-17-07, 09:39 PM
|  | Official Member | | Join Date: June 2005 Location: In.
another possibility is a vacuum leak. or my maf being dirty for some reason caused this code  |
07-17-07, 09:59 PM
|  | Official Member | | Join Date: July 2005 Location: Four Oaks NC
| | Quote:
Originally Posted by KillaGT SORRY TO BRING BACK THE OLD THREAT.
RandyStinchcomb , do you still carrry those 2 part ? I really need it now. thanks | it will be easier to contact him over on modular depot. just look under ford factory parts |
07-18-07, 08:31 AM
| | Quote:
always  |
07-18-07, 08:43 AM
hey hey, how much for 2 part + s/h to 39110 ? thanks |
07-18-07, 08:52 AM
| | Quote:
Originally Posted by KillaGT hey hey, how much for 2 part + s/h to 39110 ? thanks |
@$75.00 shipped |
07-18-07, 08:56 AM
| | Quote:
Originally Posted by RandyStinchcomb @$75.00 shipped | Deal, I look at your site, and search for the part. none come up ? how do I pay you ? |
07-18-07, 09:21 AM
| | Quote:
Originally Posted by KillaGT Deal, I look at your site, and search for the part. none come up ? how do I pay you ? | well, its not my site. I just have a "parts forum" there. if you need this, just call me here at the dealership, 410-655-2000 x 5618 and Im here till 4pm |
07-19-07, 12:10 AM
I will call you on saturday, cause my check will be clear on saturday. Just want to make sure that those part will fit and fix this P1443 check engine light. I have a 1998 Mustang GT 5 speed ( stock ), those 2 part will fix this check engine light right ? and can you tell me how much for the fuel filter for my car ? can I pay you paypal or other payment ? thanks | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
