Mustang Forums at StangNet
Help me create the "Surging Idle Checklist"
This is a discussion on Help me create the "Surging Idle Checklist" within the 5.0 Tech forums, part of the 5.0 Mustang category; would replacing the vacuum lines with rubber hose that is rated at 15 psi +/- cause a surge if my ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
LinkBack (6) Thread Tools Display Modes
  #26 (permalink)
Old 04-13-05, 04:55 PM
Funanin's Avatar
would replacing the vacuum lines with rubber hose that is rated at 15 psi +/- cause a surge if my vacuum pulls at -17.5 psi at idle?
  #27 (permalink)
Old 04-13-05, 08:24 PM
jrichker's Avatar
StangNet's favorite TOOL
Quote:
Vacuum is measured in inches of mercury, 30 inces of vacuum = roughly 15 psi. Hose designed for pressure will generally carry vacuum with no problem. Vaccum would try to colapse a hose with no reinforcement by sucking it flat, like a soda straw stuck in the ice cream in the bottom of a milk shake.
With this in mind, the cause of your surge is not the rubber hose.
  #28 (permalink)
Old 04-13-05, 11:29 PM
Ranchero5.0's Avatar
The Voice of Reason
D, I just dremel out a little at a time till it idles around 1k. In my experience the stock puter doesn't like to idle a cammed car down low.
Jamie
  #29 (permalink)
Old 04-13-05, 11:54 PM
Official Member
Quote:
Jamie
So basically the 950 or so idle I have is about the lowest Im gonna be able to get it right?
  #30 (permalink)
Old 04-14-05, 08:07 AM
dvs bullet's Avatar
Official Member
Just wondering how much vac. does a stang pull? by the way this a great idea, I have had this prob. for a long time, and this is giving me a lot of potential solutions.
  #31 (permalink)
Old 04-14-05, 01:30 PM
Once you have all the checklists done up, have them as a sticky on page one. Make it a one stop shop before a "this-has-been-answered-already" question gets posted.
  #32 (permalink)
Old 04-14-05, 02:49 PM
jrichker's Avatar
Quote:
A healthy engine with a stock cam will pull anywhere from 16"-19" at 675-750 RPM. Changes in spark advance, camshaft timing, and overall engine health will make this figure vary greatly from one engine to another.
  #33 (permalink)
Old 04-14-05, 02:55 PM
dvs bullet's Avatar
Official Member
Thanks man! It will give me more ammo when I go after my car with this list
  #34 (permalink)
Old 04-15-05, 07:12 AM
Snake1's Avatar
If you have R12 in your A/C you might want to check the charge on your A/C.
Low Charge = hunting idle
unplug your commpressor and see if it makes a difference.
did with my 88 GT and it went to a steady 650 rpms.
Decided to take the A/C out,got rid of everything except the compressor(I use the compressor as a pulley only,that way I didn't have to change the belt)
I've had a steady idle ever since I took everything out.
I also run with a vacuum guage and that is also running steady at idle.
Gained on horsepower and fuel mileage.
  #35 (permalink)
Old 04-15-05, 03:36 PM
Quote:
Only possible if the hunting idle only happens when the A/C is on.
  #36 (permalink)
Old 04-15-05, 07:36 PM
Snake1's Avatar
Quote:
as you probably know Ford heaters are on all the time except when in the off position,doesn't matter is the A/C is on, or heater side is on because your Compressor kicks in on heat side also.
Put your lever on mix on the heat side and go watch your compressor kick in, Trust me i've been thru all of this with my 88GT and R 12. if it doesn't kick in,not enough oil in your system to activate it.
  #37 (permalink)
Old 04-15-05, 07:53 PM
I could be wrong, but I'm almost positive that the compressor turns on in the A/C positions and defrost. Not in any of the other positions.
  #38 (permalink)
Old 04-15-05, 08:05 PM
Snake1's Avatar
On the heat side, the compressor kicks on for a bit then kicks off,on the ac side it stays on until you switch over to the heat side,then it starts its on/off cycle again
  #39 (permalink)
Old 04-15-05, 08:11 PM
gregpro50's Avatar
Official Member
If you have the original IAC motor on a higher mileage car the idle hunting seems to be a common problem. I have found that simply pulling off the IAC motor and hosing it out with cleaner helps it out a lot. My '90 vert that I just got this year had this problem so bad that it would actually stall. I cleaned out the IAC motor and now it idles perfect. I'm sure this isnt a permanent fix and that it needs to be replaced but it works for now.
  #40 (permalink)
Old 04-15-05, 09:01 PM
89MustangGX's Avatar
I have nothing productive to add!
I've never seen this before, not on any of my Fords ... and the A/C has worked fine.
As mentioned above, the A/C only cycles on with A/C and Defrost. It does cycle when it's on however, that is normal.
It sounds like maybe you had a stuck clutch in your compressor or something else going on.
  #41 (permalink)
Old 04-16-05, 12:53 AM
Snake1's Avatar
hey 89 Gx maybe i'm not saying this right,what I mean is the compressor cycles on and off on the heat side,I don't mean it's is running the A/C,
and you'll notice below 9 deg Celsius that your compressor won't cycle in and out and your compressor is basically a pulley then.
That's what tweaked me to the rough idle,went away when it was below 9 deg.
Hope you can understand all that.
getting tired of typing,have a good one.
  #42 (permalink)
Old 04-17-05, 02:53 PM
mkkrs1's Avatar
My car idles around 800 but I have a rpm spike between shifts. any thoughts also what is IAC
  #43 (permalink)
Old 04-17-05, 08:23 PM
gregpro50's Avatar
Official Member
Quote:
IAC= Idle air control. It is the thing that bolts to the front of your throttle body that has wires plug into it.
  #44 (permalink)
Old 04-18-05, 10:41 PM
my car had a pretty bad surge problem. used the checklist and l ceaned my IAC and my throtle body. idols real nice now. thanks
  #45 (permalink)
Old 04-19-05, 08:56 PM
MUSTANGJOE's Avatar
Silver Stanger
How do you guys clean your throttle body? Doesnt it say not to clean it? Also were is the salt/pepper connector located?
I bought that IAC adjuster from 50resto.com and it sucks!..used the new gasket that it came with and threw the rest!
  #46 (permalink)
Old 04-21-05, 01:57 PM
jrichker's Avatar
Some TB's are coated and are marked "Do not clean". If they have no markings, spray them down & use a toothbrush to do the tough places that refuse to come clean. Spray some more and wipe up the mess with a paper towel. The rest will go through the engine with no problems.
The salt & pepper shakers are the 10 pin connectors on the rear of the upper manifold.
Photo courtsey of Tmoss & Stang&2birds.
  #47 (permalink)
Old 04-22-05, 08:20 PM
mkkrs1's Avatar
What kind of spray are you using to clean with
  #48 (permalink)
Old 04-22-05, 08:24 PM
Slo 5.0's Avatar
Official Member
Will you take a pic and draw on it where the pcv valve is? i dont know where it is. i have a 1990 5.0
  #49 (permalink)
Old 04-23-05, 11:33 AM
83 Capri 5.0's Avatar
Official Member
Still have this bad cold idle
I have a cold start idle problem that lasts for about 5 mins of driving then is fine or if I shut it off and start it up again couple of times it seems to go away as well. It doesn't do the standard high idle at start anymore, rather it now surges up to 1500 RPM and the down to 100-400 RPM. If you don't give some throttle, it just dies.
I have replaced the Idle Air Bypass
Cleaned the ACT, Mass Air filiments
tested the temp sensor at 180* it reads the right ohms (as per a Chilton manual)
I should probably check it cold and clean Pin 10 as suggested in this thread.
What else should I be looking at?
  #50 (permalink)
Old 04-23-05, 12:39 PM
jrichker's Avatar
Quote:
The PCV is almost imposible to see unless you have the engine out of the car, have the intake manifold off, or you are a snail & have an eyeball on a stalk.
The PCV fits in a rubber grommet that plugs in the block at the rear of the lower intake manifold. The rubber grommet is notorious for not fitting tight or sealing like it should. It connects to the upper manifold by a 3/8" vacuum hose coming from the rear of the upper intake manifold. The easiest way to find it is to follow the hose with your hand and pull it out of the rubber grommet. Check the screen below the PCV while you have it & the grommet out if you can get to it.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.stangnet.com/mustang-forums/698148-help-me-create-surging-idle-checklist.html
Posted By For Type Date
Ford Escort Owners Association This thread Refback 10-02-09 02:47 PM
Official GTAMC Forums - stalling problem This thread Refback 09-09-09 06:25 PM
Official GTAMC Forums - choking car This thread Refback 09-07-09 08:26 PM
Official GTAMC Forums - stalling problem This thread Refback 09-07-09 08:18 PM
FYI FORD - MustangSteve's Ford Mustang Forum This thread Refback 09-01-09 02:32 PM
FYI FORD - MustangSteve's Ford Mustang Forum: Do EVERYTHING at this link, then Let Us Know "What fixed it" This thread Refback 08-31-09 07:21 PM
