Mustang Forums at StangNet
Help me create the "Surging Idle Checklist"
This is a discussion on Help me create the "Surging Idle Checklist" within the 5.0 Tech forums, part of the 5.0 Mustang category; Originally Posted by willys1 Awsome I couldnt find it,but someone here on SN gave it to me so I knew ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
LinkBack (6) Thread Tools Display Modes
  #76 (permalink)
Old 05-27-05, 08:57 AM
jrichker's Avatar
StangNet's favorite TOOL
Awsome I couldnt find it,but someone here on SN gave it to me so I knew it would show up!!,,My idle seemed fine today..I guess it needed a full cool down to compinsate for the cleaned IAB But it still stalls when I start it in the morning.....This thread is a great idea
Check & clean the IAB electrical contacts & the 10 pin connectors too. If that doesn't fix it, I would look into replacing the IAB. The cold stalling is a clue to a non-functional IAB.
  #77 (permalink)
Old 05-30-05, 06:11 AM
blown93feature's Avatar
Official Member
Hey guys, I read through the posts on this subject and I used the some of the technics to help find my gremlins.
Thanks, Joey.
  #78 (permalink)
Old 06-03-05, 07:58 PM
2dr_sedan's Avatar
$7 fuel filter, now my car runs smooth as silk... All this time it's been the freakin fuel filter...
  #79 (permalink)
Old 06-03-05, 10:24 PM
ImportEater98's Avatar
Official Member
My 89 LX idles right at 900-1000 steady on a cold start.....closed loop.
As soon as it hits operating temperature it starts bouncing 700-900 rpm.
From there the idle sort of "bucks". Soon it becomes such a "buck" that it stalls the car. I have an E-303 cam and i know someone mentioned that they are notorious for that problem.
Now that i know the problem is only in "Open Loop" operation, is there anything i can eliminate right off the bat as i try to trouble shoot?
It can't be a vaccum leak or it would happen in both open and closed loop, correct?
  #80 (permalink)
Old 06-04-05, 01:45 AM
HISSIN50's Avatar
"How long do you think it'll take me to get any help?" --Richard Harris
I might be loopie (well, we know that), but I think you have your loops backwards.
OL is when O2's are not used (Cold motor, WOT, etc).
CL is when the motor is warmed up a little and O2's are used.
I wanted to make this distinction - people who reply would probably want clarification. good luck.
  #81 (permalink)
Old 06-04-05, 07:00 AM
Official Member
ugh...im so stupid. Typed that post with a few beers in me. You are right hissin......basically switch the closed loop to open loop and vice versa in that post. Sorry bout that
  #82 (permalink)
Old 06-04-05, 12:48 PM
super302's Avatar
I'd do anything for free Bapples
Thanks,
A combination of things fixed it....all for a $3 can of throttle body cleaner
  #83 (permalink)
Old 06-07-05, 05:33 PM
I've tried just about everything listed here, and I still have a surging idle. But mine goes from like 700 up to 1300 RPM's. I'm also running very rich. My car was fine before I added the supercharger, 255lph fuel pump, and 30 lb injectors. Also went to a 76mm MAF. If I unplug my MAF, it won't surge anymore. I've cleaned the IAC and throttle body and still no luck. My brother thinks that putting in a Kirban FPR will fix my problem. Does that sound right? Between regulating fuel pressure and adjusting my timing, should that fix the problem, even though unplugging the MAF stops the surge?
  #84 (permalink)
Old 06-10-05, 07:10 PM
willys1's Avatar
Banned
Quote:
I went to Hackettstown Ford today and ordered a new IAB,it should be in next week.97 beans
  #85 (permalink)
Old 06-11-05, 11:54 AM
jrichker's Avatar
Quote:
Try cleaning the MAF element & then "clock" the MAF to see if changing its position helps any.
  #86 (permalink)
Old 06-11-05, 03:38 PM
willys1's Avatar
Banned
Yeah,I would try turning the MAF,its worked for me.Turn it 180 degrees towards the motor.
  #87 (permalink)
Old 06-12-05, 01:47 AM
Don Fiveolio's Avatar
Official Member
Alright,
I'm starting to have the same issue with my Stang and I think I have found the problem. I'ts most likely the IAB and I want to clean it out, but I don't know what to use.
What are you guys using?
  #88 (permalink)
Old 06-12-05, 02:11 AM
89MustangGX's Avatar
I have nothing productive to add!
Quote:
Originally Posted by don herberto
Alright,
Carb cleaner or similar. May need to use a screwdriver if it's REALLY bad...just be careful of the rubber seal part inside.
  #89 (permalink)
Old 06-12-05, 12:03 PM
Official Member
Here's a question that is a little of topic, but deals with the same situation. I pulled the IAB last night and cleaned the ports on the side of the throttle body. I put everything back together and now the surging idle is worse.
While I was cleaning, I decided to pull the throttlebody and the gasket was horrible. I figured this might be a part of the problem so I headed right out to the parts store and bought a brand new gasket, but this is the thing:
Do I need gasket sealant for this application?? I could not tell because everything got soaked in coolant. The guy at the shop said I should get it and sold me a tube, but I thought I would get some feedback before I started.
Any hints??
  #90 (permalink)
Old 06-12-05, 03:00 PM
jrichker's Avatar
Any hints??
I would use some RTV sealant since you are mating a water jacket (TB water cooling) to a part that has engine vacuum.
  #91 (permalink)
Old 06-17-05, 10:20 AM
Black Sun 5.0's Avatar
Definitely check all grounds. I had a problematic DC Control unit for my electric fan. I replaced it and all the associated wiring, surge is very rarely a problem now where it had once been stalling all the time. I doubt the issue was with the controller, the grounds made more sense.
  #92 (permalink)
Old 06-17-05, 08:47 PM
5.02GO's Avatar
Thought i read that someone wanted a part number on a bypass plate.
Well, here is a link to mustangs unlimited. "Idle Adjustment Plate".
I think its a must for "E" cam users. Mine would NOT hold an idle until i installed this plate. I realize this may not have alot to do with the original subject thread but here is the link just incase someone needs this.
http://www.mustangsunlimited.com/ite...=&catkey=74-01
  #93 (permalink)
Old 06-23-05, 04:19 AM
Marshall's Avatar
Great thread - It has been suggested that a final checklist be written with all the possible checks. Please someone do this so us dummies can download it for future reference.
Thanks
  #94 (permalink)
Old 06-23-05, 08:43 PM
BERT306's Avatar
Official Member
I just found that i had a X3Z computer in my 90LX, not the A9L. Had to get a calibration tube for my 76MM C&L
MAF to match the X3Z. Runs GREAT now!!!
  #95 (permalink)
Old 06-24-05, 06:21 PM
aete2's Avatar
thanks guys forthe list huge help
  #96 (permalink)
Old 06-24-05, 08:51 PM
HISSIN50's Avatar
Is the X3Z puter not a cobra unit? If so, it seems to me that the puter calibrates for 24# injectors itself (in case an issue pops up for you Bert).
Good luck.
  #97 (permalink)
Old 06-27-05, 08:35 PM
mkkrs1's Avatar
Tps Iab
If you replace the TPS or IAB. do they have to be set or is it a simple remove the old one and install new. are there any checks to perform to see if the TPS or IAB are still good before you purchase new ones not needing them.
mike 89-718
  #98 (permalink)
Old 06-27-05, 08:42 PM
HISSIN50's Avatar
Quote:
mike 89-718
Jrichker has some wonderful write-ups he has posted on peoples' threads. I would search each term above using the search feature, or search JR's old posts. You should find what you want.
Good luck.
  #99 (permalink)
Old 06-28-05, 04:52 PM
My engine doesn't surge, but if you get it over ~2000 RPM's it comes down to 16-1700 and just sticks until you come to a stop. I cleaned the IAC and did't help. I tried turning the IAC upside down and it was worse. I cleaned the MAF tube and that didn't make a difference. Haven't cleaned the element in the MAF yet. I have the idle set at 7-800 and the TPS is somewhere around .95, not over 1. I DO have an E-cam, but it doesn't have a rough idle, it just sticks. I lloked for the 10 pin connectors and couldn't find them. Anyone else have this similar problem?
  #100 (permalink)
Old 06-28-05, 09:20 PM
I would also recommend checking and replacing the pcv valve, grommet, and the wire mesh in the back of the lower intake. ( falls under vacuum leaks)
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.stangnet.com/mustang-forums/698148-help-me-create-surging-idle-checklist.html
Posted By For Type Date
Ford Escort Owners Association This thread Refback 10-02-09 02:47 PM
Official GTAMC Forums - stalling problem This thread Refback 09-09-09 06:25 PM
Official GTAMC Forums - choking car This thread Refback 09-07-09 08:26 PM
Official GTAMC Forums - stalling problem This thread Refback 09-07-09 08:18 PM
FYI FORD - MustangSteve's Ford Mustang Forum This thread Refback 09-01-09 02:32 PM
FYI FORD - MustangSteve's Ford Mustang Forum: Do EVERYTHING at this link, then Let Us Know "What fixed it" This thread Refback 08-31-09 07:21 PM
