View Single Post
  #6 (permalink)
Old 08-20-07, 06:28 PM
5spd GT's Avatar
5spd GT 5spd GT is offline
"the 5.0 owns all"
Quote:
Originally Posted by FastDriver View Post
I'd love to see a comparison with TFS CNC'd 205cc heads vs. AFR205cc heads on the same day, same dyno, same operator if any of you have seen one.
Chris
Well no dyno information, which would be much better but here is a little comparison:
BOLD shows the advantage to each compared to the other.
AFR CNC 205------------------------------------------------------ Trickflow CNC 205
Airflow Chart for Track AFR 205 Heads:
Lift Value (in.) - Intake Flow - Exhaust Flow
Inches - CFM - CFM
0.200 - 141 - 125
0.300 - 201 - 180
0.400 - 251 - 211
0.500 - 291 - 225
0.550 - 301 - 228 (TW info not given)
0.600 - 306 - 231 (Exhaust Tie)
0.700 - 310 - 235
Airflow Chart for CNC Ported 205cc Track Heat Heads:
Part Number: TFS-51400010-C02
Inches - CFM - CFM
0.100 - 071 - 056
0.200 - 144 - 112
0.300 - 220 - 150
0.400 - 270 - 192
0.500 - 299 - 220
0.600 - 316 - 231
AFR 205:
205cc Head, 58cc, 2.08”/1.60” Valves, 1.550” Roller Dual Valve Spring w/ dampner (.670”), 10* locks, 7/16” rocker studs, no smog provisions. $1,850.
210# of spring pressure and 70cc exhaust port.
Valve Angles: 23* for Intake and Exhaust.
Trickflow 205:
205cc Head, 65cc, 2.02"/1.60" Valves, 1.460", Dual Valve Springs w/ dampner (.600”), 10* locks, 7/16” rocker studs, no smog provisions, and not machined for o-rings. $1,990.
66cc exhaust port.
Valve Angles: Intake is 15* and Exhaust is 17*.
Looks like a nice even match to me...the Trickflow has the intake side 'won' and the AFR has the exhaust side 'won' (maybe a bit better for expending the compression for boosted application) and save $140.
