View Single Post
  #12 (permalink)
Old 08-29-07, 06:49 PM
MUSTANG J's Avatar
MUSTANG J MUSTANG J is offline
Official Member
Quote:
Originally Posted by THE COBRAMAN View Post
What do you think about these.... the II kit line is 19". I was thinking buy the II kit and use the GM banjo bolt, since it appears that they are the same diameter as the metric banjo bolts specified in the kit, just diff thread pitch?
I don't think those will work, but these would work. Note you can change the two last two digits of the part numbers to change the length.
http://www.holley.com/63010220ERL.asp
Then you just need a couple of these
http://www.holley.com/989543ERL.asp
And a couple of these
http://www.holley.com/977520ERL.asp
The ones you picked out are intended for Mustang II cailipers. (Not the GM metric that the "Big" brake kits use)
