08-04-07, 08:34 AM
|  | Founding Member | | Join Date: June 2002 Location: Boston, MA
| | | Painting Calipers
So I'm trying to think of affordable things I can do to my car in the 2 weeks between school and work. I'm graduating and then starting work at the end of Aug.
Anyone ever paint there own calipers? What kind of paint did you use? Did it fade over time?
Here's a pic of my car, thinking about red calipers.
08-05-07, 01:27 AM
|  | Doubt I could be of much help, unless you need porn pics!! | | Join Date: August 1998 Location: Morgantown, WV...where couches meet their doom
I painted mine with some of that Duplicolor 1200 degree paint, it holds up good as long as you don't get brake fluid on it.
Mine have been painted for about a year and they still look pretty good. |
08-05-07, 04:20 AM
| | Banned | | Join Date: June 2002 Location: Prattville, Alabama
| | Quote:
Originally Posted by 91LX302 Anyone ever paint there own calipers? What kind of paint did you use? Did it fade over time? | I painted mine red last summer using G2 caliper paint from Tire Rack. http://www.tirerack.com/brakes/g2/caliper_paint.jsp
Worked great and looks good. It has stood up to multiple applications of acidic wheel cleaning products and has not faded at all.
U.M. |
08-05-07, 07:22 AM
|  | Member | | Join Date: May 2005
I painted mine last year. It was pretty easy once I got the rust off. I can't remember what paint I used but it's holding up really well which suprises me as I did kind of a rush job when I was changing rims. |
08-05-07, 08:05 PM
|  | bubb rubb says: "woo woooooo" | | Join Date: September 2002 Location: Syracuse, NY
| | Quote:
Originally Posted by Uncle Meat I painted mine red last summer using G2 caliper paint from Tire Rack. http://www.tirerack.com/brakes/g2/caliper_paint.jsp
U.M. | they also sell that caliper paint at walmart. if your a perfectionist and want it to look perfect buy the kit and just brush it on.
if you dont care as much and just want the red look then get some high temp engine paint and tape off everything u dont want painted |
08-05-07, 08:37 PM
|  | Thanks to Tim, I get off pretty easy. | | Join Date: February 2001 Location: Houston, TX
You mean they don't come painted?...  |
08-05-07, 09:12 PM
| | Quote:
Originally Posted by GT40XStang9 You mean they don't come painted?...  | unfortunately no, they did in '06 but mine is an '05.
I'm going to try the paint on stuff, I'll post pics when I'm done |
08-05-07, 09:52 PM
|  | Official Member | | Join Date: November 2004 Location: Mass
08-06-07, 03:41 PM
looks good
i assume that's the brush on stuff. how well is the color holding up? I see you're in Mass. too, I'm more worried about sand/salt in the winter fading the paint. I doubt you drive you car year round though |
08-14-07, 06:17 PM
08-14-07, 08:36 PM
|  | there's nothing cool to put right here | | Join Date: March 2002 Location: Toms River NJ
| | Quote:
Originally Posted by 91LX302 unfortunately no, they did in '06 but mine is an '05.
I'm going to try the paint on stuff, I'll post pics when I'm done | actually the brakes on the 06-07's are different. The calipers are 4 piston's and are painted red...
Your's came out bad ass tho!!! Nice job!  |
08-15-07, 04:59 PM
thanks, didn't know that about the '06 brakes |
08-16-07, 02:22 AM
|  | Resident Ranting Negative Nancy | | Join Date: July 2005 Location: Apache Junction, AZ
I painted my rear drums black last year with VHT Brake Paint. They were a bit too obvious with their natural rust color, even behind the 10-hole rims I'd been running, and I knew they'd REALLY stick out if I ever put anything else on there (such as the Ponies I'm running now), so I just wanted to make them less obvious.
The VHT stuff works great. I just wire-brushed off the drums, hosed 'em with brake cleaner to get rid of the dust and such, and then sprayed 'em down with the VHT paint. No chipping or anything in over a year, so far. I used the same spray paint on my 10-hole rims, as well (black with polished lip), and they've held up quite nicely ... aside for one rim that I had to touch up because I missed a couple of spots with sloppy prep work. Frankenstang's running those rims on her '86 GT 'vert, now.
Dunno about how they'd hold up against brake fluid, but they've withstood plenty of heat and washes and such over the past year or so. Autozone sells the VHT stuff (several different color options, of course), but I dunno who else does. | | Thread Tools | | | | Display Modes | Rate This Thread | Linear Mode | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
