Mustang Forums at StangNet
O/D OFF light flashing
This is a discussion on O/D OFF light flashing within the Other Auto Tech forums, part of the General Automotive Forums category; Is there a way to get the trouble code for the O/D light? I changed the plugs and wires and ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-06-07, 03:26 PM
Is there a way to get the trouble code for the O/D light? I changed the plugs and wires and drove the car a little harder than my wife does and now the light flashes after cruising about 55 for a while. It's a 2000 V-6. Any help would be much appreciated. Thanks in advance!
Nate
  #2 (permalink)
Old 09-06-07, 04:22 PM
DBMSTNG's Avatar
I fantasize about it being BIG!
don't know for sure, but i would assume it would throw a code.
  #3 (permalink)
Old 09-06-07, 10:35 PM
timeless2's Avatar
Vi Veri Veniversum Vivus Vici
Nate, is this on a Mustang or another vehicle?
  #4 (permalink)
Old 09-08-07, 06:25 AM
The OD light is flashing because the transmission hs set a code, Take it to your local auto parts store and let them scan if for free. Then come back with the code number and the discription of the code.
  #5 (permalink)
Old 09-08-07, 11:09 PM
kbeefy's Avatar
I don't know about mustangs, but that year superduty will do the same thing with different sized tires, gears, a loose speed sensor plug on the rear diff or a faulty speed sensor. As mentioned, get it scanned. I think ford stuff all goes throught the same OBDII plug but may take a different or better scanner, some others (chevy) have a seperate drivetrain diagnostic plug.
edit: I spelled diff : doff
  #6 (permalink)
Old 09-10-07, 03:43 PM
Thanks for the advice. Guess I'll be taking it to get it scanned.
  #7 (permalink)
Old 09-20-07, 08:57 PM
dragnazz5.0's Avatar
My "0" key d0esn't w0rk, s0 I have t0 use the zer0.
that light usually indicates a tcc lockup problem....ive never seen it on a mustang before but the ford trucks (usually mid to late 90s) will flash that code when there is a torque converter lock up problem. i hope that isnt your case but just a heads up
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
