Mustang Forums at StangNet
new dd ..help with timing
This is a discussion on new dd ..help with timing within the Other Auto Tech forums, part of the General Automotive Forums category; i got a new DD its a 93 honda civic lx 15 non vtec 5spd. picked up for next to ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-12-07, 10:11 AM
blckstng96's Avatar
Official Member
i got a new DD its a 93 honda civic lx 15 non vtec 5spd. picked up for next to nothing and put a new distributor in it but i have no idea how to time one of these things,anyone here have a clue? i see no marks on the balancer or anything and i dont know what factory timing is set to either.any help is appreciated.thanks
  #2 (permalink)
Old 09-12-07, 10:20 AM
85ragtop's Avatar
Deputy Dawg
Man woods surround my office.
You may get more help in here.
  #3 (permalink)
Old 09-12-07, 10:22 AM
ninety15.0's Avatar
Official Member
I dont think you time those cars with the balancer...isnt it done with the cam gears? I may be mistaken but OHC engines are timed at cam gears, which means i think you need to pull the cam cover. You might try a honda forum...may have better luck there.
  #4 (permalink)
Old 09-12-07, 10:42 PM
Darkwriter77's Avatar
Resident Ranting Negative Nancy
If it's anything like the 1.5L I had in my '87 CRX Si, there's not a whole lot of timing adjustment to be done on these things. Basically you need to pull the plastic timing belt cover off and rotate the crank around manually until the cam gear timing mark (an engraved/painted dot) lines up with the mark on the cylinder head, and ditto for the mark on the crank and engine block. If they're not off, then either the timing belt was improperly installed or the timing belt tensioner is getting weak enough that it allowed the belt to slip a notch ... but Hondas are usually interference engines, meaning that if the timing is off, you'll be banging valves against pistons and creating all kinds of a mess in there.
Honestly not sure if those motors allow for any real kind of timing adjustment at all or not, but if there's any to be had, I'd imagine it would be done by turning the dizzy ... although how, exactly, one goes about that, I dunno. IIRC, they're held into place pretty solid by a two- or three-bolt mount and don't really allow for any rotation like on a Ford or Chevy V8...
Now as for VALVE adjustment, that's a whole different deal. Older Hondas especially need to have their valvetrain adjusted every so many thousand miles. I remember reading that it was recommended every 15k, but I'd say more like 50k ... about the same time you change the timing belt, basically.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
