Mustang Forums at StangNet
Got thru inspection and then the EEC throws a 543
This is a discussion on Got thru inspection and then the EEC throws a 543 within the 94-95 Tech forums, part of the 5.0 Mustang category; I cut my base timing and fuel pressure back a bit and took the stang over to inspection. It passed ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-13-07, 11:27 PM
Official Member
I cut my base timing and fuel pressure back a bit and took the stang over to inspection. It passed easily and my emissions numbers were pretty good. Anyhow, I start heading back home and suddenly I've got what feels like a dead miss, but I couldn't understand why since I replaced the plugs and wires recently. I ran a KOEO test when I got back to the house and the EEC threw a 543 (fuel pump circuit - open connection). Can this be? Would it even run at all if the circuit was open? I went ahead and ran the KOER test and it passed with a 111. I decided to reset the EEC and set my base timing and fuel pressure back to my usual numbers. I fired it back up and went for another spin and it ran fine. Could the lower fuel pressure wreak havoc with the EEC? I ordinarily leave the fuel pressure set for 40# with the vac. hose off, but I cut it down to 35# before I went to inspection. I also retarded the base timing down to 4 deg. BTDC with the spout out. Ordinarily I leave it at 12 deg. BTDC because if I advance it any further I start getting a little pinging under load. The check engine light never came on, but it was really running like a dog on the way back home from inspection.
  #2 (permalink)
Old 09-13-07, 11:32 PM
HISSIN50's Avatar
"How long do you think it'll take me to get any help?" --Richard Harris
Not that it's the case here, but it can be a ghost code. Any time the pump loses power for a split second, the FPM can generate the code. Also, stalling the car can create it.
Good luck.
  #3 (permalink)
Old 09-14-07, 09:07 PM
Official Member
I can hear the fuel pump cycle on when I turn the key on (which is normal, of course) so I took another test drive today and it seemed okay. I can't explain what happened yesterday, that was kind of weird.
  #4 (permalink)
Old 09-14-07, 09:17 PM
go-stang5.0's Avatar
Official Member
Until you can recreate the problem I wouldent worry about it. You cant diagnose it anyhow now that its not doing it.
  #5 (permalink)
Old 09-15-07, 12:35 AM
HISSIN50's Avatar
Also, if you haven't, reseat your plug wires.
Good luck.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
