Mustang Forums at StangNet
Chevy Caprice water pump replacement question
This is a discussion on Chevy Caprice water pump replacement question within the Other Auto Tech forums, part of the General Automotive Forums category; i know, this is not stang tech, but it is tech ... i am trying to change the water pump ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-26-07, 07:07 PM
BlackVert's Avatar
Official Member
i am trying to change the water pump on my mother in law's 1992 caprice classic wagon, and i have the fan bolts off, but i need to get the thing that the fan was bolted to off the front of the pump. it is that light colored thing with all the ridges in it.
fyi, the water pump is that rusty thing behind the fan.
or am i supposed to remove the pulley from the front of the pump and leave the fan connected to that thing?
any chevy guys here?
  #2 (permalink)
Old 09-26-07, 07:15 PM
bigcat's Avatar
start with the upper hole, and if more traction is needed, try the lower hole
isnt therre a nut at the base of the clutch? should be right there next to the bolts for the fan. you will need one of the clutch fan removal kits. rent one from autozone if you dont have one. if you have access to air and an impact hammer, put a chisel bit on the end, and use it to break looke the nut. if you dont have experience doining this, might be better off with the proper tools.
  #3 (permalink)
Old 09-26-07, 07:39 PM
BlackVert's Avatar
Official Member
thanks, i'll follow that route and see where it takes me
  #4 (permalink)
Old 09-27-07, 06:43 PM
cjones's Avatar
the 4 nuts at the water pump shaft(where the pulley is) are the nuts you should remove. the fan doesn't need to be removed from the clutch unless you're going to change the clutch as well.
  #5 (permalink)
Old 09-27-07, 08:37 PM
BlackVert's Avatar
Official Member
i got it done, thanks everyone.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
