10-09-07, 09:12 AM
|  | Member | | Join Date: September 2007 Location: Commerce, GA
| | Best N/A mod before stepping up to a blower?
I'm considering a blower for my 4.6 auto. I've decided to get the following mods: Tuner for engine. Shift mod on transmission with tuner. 3.73 Gear (I do highway miles). Hi flow cats and mid-pipe to go with my glasspacks.
I'm not sure I want to spend what it will cost to add a blower on top of the mods I already want. I've been looking at the Ford Racing supercharger.
What would be a good cost effective mod with good gains to go with my mods listed above? I've decided to use MV Performance for all the work. |
10-09-07, 09:30 AM
|  | Official Member | | Join Date: April 2005 Location: Sacramento
get a nice set of Cams, best bang for the buck, and will reap great rewards once you add the blower ! |
10-09-07, 09:36 AM
|  | Official Member | | Join Date: December 2004 Location: Carmel, INdiana
Longtubes, hands down. If you're in GA just go to Modular Powerhouse, they do top notch work, and as far as blower installs go are pretty straightforward and affordable bout it. |
10-09-07, 10:08 AM
| | Quote:
Originally Posted by whyask get a nice set of Cams, best bang for the buck, and will reap great rewards once you add the blower ! | The shop told me that it might not be the best idea for a daily driver. I still like the idea of a slightly larger cam. The drag cars that shop runs is still on stock cams because of the class they run in.
I like the idea of a blower, but would also like to consider the options I have above what I want to do without going all out on a blower.
10-09-07, 12:39 PM
|  | Official Member | | Join Date: April 2006 Location: Las Vegas
I got cams and it's my DD. Just needs a good tune to drive like stock  |
10-09-07, 01:43 PM
|  | Official Member | | Join Date: July 2003 Location: Auburn, PA
stage 2 cams, long-tubes, tranny cooler |
10-09-07, 02:15 PM
|  | Official Member | | Join Date: July 2005 Location: Los Angeles, California
since you mentioned that you have an auto get a higher stall convertor, along with doing the J-mod on the valve body (only shift kit that should be done on the auto), and a trans cooler....before adding the blower |
10-10-07, 07:28 PM
| | Member | | Join Date: September 2007 Location: Alabama
ive read a lot on cams and blowers... and a lot of people encouraged me not to bc the blower is capable of creating more power than the motor can handle anyways |
10-12-07, 04:00 PM
|  | will post boobie pics for a supercharger | | Join Date: October 2004 Location: California
| | Quote:
Originally Posted by lvmustanggt I got cams and it's my DD. Just needs a good tune to drive like stock  | drives like stock in terms of power? |
10-12-07, 11:31 PM
| | Official Member | | Join Date: April 2004 Location: South Carolina
| | Quote:
Originally Posted by RoskiStang ive read a lot on cams and blowers... and a lot of people encouraged me not to bc the blower is capable of creating more power than the motor can handle anyways |
Big negative there. Its all in the tune. Get a conservative tune and you'll be pushing 350-400 rwhp (depending on blower, pulley size, tune paremeters, supporting mods, etc...), which is a safe place to be. Although some are pushing 450 rwhp, but thats like a ticking time bomb. |
10-14-07, 10:39 AM
|  | Official Member | | Join Date: August 2007 Location: Lynnwood
10-14-07, 10:46 AM
|  | Official Member | | Join Date: July 2004 Location: Augusta, GA
Shortblock, heads, cams, fuel upgrade, etc.
If you can't afford all that stuff, just step right into getting a blower then see what else you'll need to reach your goal. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
