Mustang Forums at StangNet
supercharger/turbo question
This is a discussion on supercharger/turbo question within the 5.0 Tech forums, part of the 5.0 Mustang category; Anybody know the location the oil drain should go in the oil pan? I can't find the booklet for the ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-03-07, 09:01 AM
Black1987Stang's Avatar
Official Member
Question supercharger/turbo question
Anybody know the location the oil drain should go in the oil pan? I can't find the booklet for the exact dimensions. Btw im putting it on the passenger side. Thanks
  #2 (permalink)
Old 11-03-07, 09:36 AM
According to my Vortech manual, it should be 1 and 3/4 inches below the pan lip, and 1/2 inch back from the first bolt on the SIDE of the pan
  #3 (permalink)
Old 11-03-07, 09:40 AM
Here you go, found the manual in PDF. Diagram on pg. 14:
http://www.vortechsuperchargers.com/...s/4FA218im.pdf
  #4 (permalink)
Old 11-03-07, 12:12 PM
Banned
Perfect, exactly where mine is and its perfect.
  #5 (permalink)
Old 11-03-07, 01:16 PM
Official Member
Thanks I found it. I will be boostin soon
  #6 (permalink)
Old 11-03-07, 03:22 PM
Foxfan88's Avatar
My Grandpa has great wood.
you can locate the fitting anywhere you desire as long as its under the blower but above the oil level.
  #7 (permalink)
Old 11-03-07, 04:30 PM
millhouse's Avatar
Quote:
Ideally you want the return inline with on of the main caps, as anywhere else will drain oil into the rotating assembly and sap of you power...as well as aerate the oil. The location dictated by vortec puts the fitting directly inline with a main cap for presumably that reason.
  #8 (permalink)
Old 11-03-07, 09:27 PM
bluevenom867's Avatar
I will have images of molesting stuffed animals in my mind forever!
Quote:
Does the late model timing cover have the hole for the front mount dipstick? You could probably use a small NPT tap and put a fitting there if it has one. Just have to pack the flutes with grease and have the shop-vac near by to make sure shards dont get in.
  #9 (permalink)
Old 11-03-07, 09:52 PM
millhouse's Avatar
Quote:
Nope, and even if it did...it would likely be to small to serve as a drain.
  #10 (permalink)
Old 11-03-07, 10:20 PM
How large of hole you need? Its close to 3/8"
  #11 (permalink)
Old 11-03-07, 10:32 PM
millhouse's Avatar
The hole size is going to need to be big enough for a 3/8 NPT tap. This comes out to be 9/16" tap drill.
  #12 (permalink)
Old 11-03-07, 11:08 PM
Hmm,guess they use a larger return line than I though. Is it -04AN or -06AN?
  #13 (permalink)
Old 11-04-07, 08:37 AM
millhouse's Avatar
The fittings they use are 3/8" NPT with a 1/2" barbed fitting. The actual hose size is 1/2". The closest -AN size I believe is -10AN.
  #14 (permalink)
Old 11-04-07, 03:49 PM
That would be -08AN, -10AN is 5/8"
but 1/2" is still large,as big as the oil drainback holes in the heads and block (I didnt think they would require so much oil).
  #15 (permalink)
Old 11-04-07, 04:52 PM
millhouse's Avatar
Yep, my bad. I think though it's not a matter of requiring so much oil, but attempting to keep any oil backups from occuring.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
