Mustang Forums at StangNet
5sp Burnout at the Track Tips!
This is a discussion on 5sp Burnout at the Track Tips! within the 5.0 Talk forums, part of the 5.0 Mustang category; Can anyone steeeer me in the right direction if this is the right process to burnout if you dont have ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Talk
Over 153,000 Members!!
Reply
  #1 (permalink)
Old 11-07-07, 07:23 PM
Redeemedsoul's Avatar
Official Member
Can anyone steeeer me in the right direction if this is the right process to burnout if you dont have a trans break.
1- engage clutch
2- clutch engaged, shift to first
3- REV RPMS, disengage clutch
4- slam break, while accelerating
5- Let go of break, clutch, shift 2nd (with or without accelerating?)
6- back on break to continue warming up tires in 2nd.
7- release break, move forward, clutch in
8- stage
Now my question is #5 with or without acceleration
and
a) Wouldnt this take a huge toll on your breaks?
b) Wouldnt the car budge forward too far if you dont do 4-5-6 quick enough?
Are there any better ways to light up your tires with a 5spd?
-rS
  #2 (permalink)
Old 11-07-07, 07:46 PM
ryan218's Avatar
In just 10 years, I'll be old enough to drive!!!!
if you can do the heel toe do that....i cant...so i just dump the clutch and ride the brake.
  #3 (permalink)
Old 11-07-07, 07:51 PM
millhouse's Avatar
Forget first gear, just dump it while in second and get on the brakes. Let up a little bit so as not to fry your rear brakes and when your finished roll out of the burnout. I've never tried the heel/toe method, for a burnout....but really I never felt I needed to.
  #4 (permalink)
Old 11-07-07, 07:52 PM
25thmustang's Avatar
Official Member
heel toe is the easiest for me anyways...
right foot heal on the brake, toe on the gas. Rev to 5000 or so and dump the clutch and the tires should spin and the car shouldnt move.
Either that or dump it high in the RPM. and then left foot on the brake fast.
Dont try and shift 2nd in a burnout. Fast way to mess something up.
  #5 (permalink)
ryan218's Avatar
Quote:
i cant do it..i got clown feet
  #6 (permalink)
Old 11-07-07, 08:24 PM
RYC CUKR's Avatar
Quote:
Agreed, trying to go from 1 to 2 during a burnout is a good way to fry your clutch.
Before I had my line lock I would just push the clutch in, bring the rpms up to around 5k, dump the clutch and get on the break with the left foot.
But I am lazy and got a line lock and now it is super easy, and saves your rear brakes some.
  #7 (permalink)
Old 11-07-07, 08:30 PM
bloopbloob's Avatar
Official Member
i have a hard time with the heel-toe method also, but i also have only tried a couple brakestands for the sake of my (expensive ass) new tires. as for the toll on the brakes, if you think about how many times your drums go around your pads every time you come to a stop (especially from highway speed), a few second burnout is nothing.
  #8 (permalink)
Old 11-07-07, 08:34 PM
millhouse's Avatar
Here is one of my doing a little burnout. Notice how I'm on the brakes and slowly roll into the burnout? Sometimes I roll a bit more than others...but the point is you'll need to find that modulation point.
http://www.youtube.com/watch?v=j1dBvPBTQ1o
http://videos.streetfire.net/video/9...e0007f601a.htm
  #9 (permalink)
Old 11-07-07, 08:37 PM
fastford91's Avatar
Official Member
heel toe dont work for me i tried it! but my size 12 boats get in the way and all it does is fry the clutch!
  #10 (permalink)
Old 11-08-07, 05:32 AM
Official Member
I know guys with size 14s who can heal toe it... I had issues the first few times, but figured out the best way to do it, and have no issues now. If your feet are "that big" then don't use the heal/toe, use more of the sides of your feet, can be done just the same. Also on the street or with water the tires should go up real fast...
  #11 (permalink)
Old 11-08-07, 07:01 AM
blackened88lx's Avatar
Official Member
Like the other people said, never shift during a burnout. If you're on street tires, 1st gear will work, and you just want to clean the tires off, not do a real burnout. You can practice and learn the heel-toe, or side-step method which is when you use the sides of your right foot like 25th mentioned. With 1st gear burnouts I use the side-step method because the car usually makes a big leap in 1st when you jump over to the brake with your left foot. In water it would be a different story, but I'm used to the street. With slicks, or if you're just doing a burnout for show, use 2nd gear like millhouse described. For 2nd gear I usually jump over with my left foot because it requires more throttle and it's easier to modulate the brake and gas with 2 feet. Also, if you do it right, the tires will break loose much faster so the car won't make a jump like in 1st, it almost just sits there for a second.
  #12 (permalink)
Old 11-08-07, 07:33 AM
ninety15.0's Avatar
Official Member
I think the heel/toe or sidestep way is the only way to do a burnout. The very first time i ever did a burnout was just jumping on the break after dropping the clutch. Not only is it violent but the car moves all over the place. Not only forward...but normally it gets cocked off sideways too.
I use the sidestep method with the sides of my feet most times...and if i need to modulate the throttle a little more i use the heel/toe method. Put it in 2nd gear...rev to 4-5k and dump the clutch....pretty straight forward.
  #13 (permalink)
Old 11-08-07, 09:34 AM
Official Member
Quote:
Yeah... and your mom gets pissy when you leave rubber in her driveway and plow over the trash cans.
  #14 (permalink)
Old 11-08-07, 05:45 PM
Official Member
If your running street tires, drive around the water box and pe-stage and then stage. The compound on street tires becomes slippery when doing a burn out. Plus the tread depth on street tires are going to bring the water up to the starting line and make you spin anyways.
A friend of mine drives around the water box with street tires and runs low 13's with his Parnelli Jones 2007 Mustang.
If your running drag radials, dot slicks, or slicks,
Rip it once through the water box and roll out about 3- 6 feet.
Shift into 2nd
Bring your rpms up to 4000 and dump the clutch
Have your drivers side mirror tilted down so you can see your rear tire
When they start to show some good smoke, roll out of the burn out and into pre-stage.
Also, if your not running skinnies on the fronts, drive around the water box and back in. Front street tires will also bring water to the line.
A line lock is the way to go when doing a burn out for drag racing purposes.
  #15 (permalink)
Old 11-08-07, 06:23 PM
fastford91's Avatar
Official Member
Quote:
  #16 (permalink)
Old 11-08-07, 07:13 PM
mike93lx's Avatar
Official Member
i highly recommend spending the few dollars on line lock. you'll have much better control over the car (safety wise) and you won't be beating the crap out of your brakes.
i love my line lock and it wasn't very expensive.
  #17 (permalink)
Old 11-08-07, 09:34 PM
Foxfan88's Avatar
My Grandpa has great wood.
i just mash the brake pedal hard with my right heel and rev with my toes. pop it in 2nd and rev it to around 4k and pop the clutch quick. the tires will turn over and i keep holding the brake with my heel and adjust the gas during the burnout, when i am done i let off the brake and roll forward.
  #18 (permalink)
Old 11-08-07, 11:08 PM
talladam's Avatar
Official Member
i can't heel toe with my 15's but i did do the cover half the brake and gas with one foot. roll the right side of my foot more towards the gas and dump on that bitch. worked okay but i still need to install my linelock.
  #19 (permalink)
Old 11-09-07, 03:57 AM
black87ttop's Avatar
yeah i wear size 14 and 15 shoes depending on brand, and i can do the heel toe method, so there is no reason why anybody else cant , unless they have bigger feet than me. I usually start out in first then i use my right foot to control brake and gas, then i can shift and use the clutch with my left leg. I never had any problems this way. and i have about 10 friends that can vouch for the 4 gear burnout i did one nite. LOL wish i had a camera for that.
  #20 (permalink)
Old 11-09-07, 07:11 AM
Official Member
You guys realize during the burnout/shift thing, the tires stop in each gear. So why not just try and start it in 4th?
  #21 (permalink)
Old 11-09-07, 09:14 AM
ninety15.0's Avatar
Official Member
I always wonder this too...why would you ever try to shift during a burnout. Have you ever seen a video of someone doing this? The tires stop spinning immediately once you depress the clutch.
Just start in 4th...if you really want to do a burnout of that magnitude and destruction!!
  #22 (permalink)
Old 11-09-07, 01:56 PM
Foxfan88's Avatar
a 4th gear burnout is excessive IMO. i just start in a second. 1st never does get tires hot. with the low gear i can get enough tire speed top burn rubber. 4th is just wasting tire IMO.
i've always had to burn my tires really hard on the first pass of the day to get the dried out rubber off and get them hot.
with a nice day, good tires and a well prepped track hardly any burnout is required to hook. except for maybe the first burnout of the day which i take a little longer to knock the dry surface off and then the rest of the day i dont have to burn them as hard.
but for showing off and making a smoke show 4th gear is where its at.
  #23 (permalink)
Old 02-07-08, 04:31 PM
Official Member
wow, i like show. I got 290 RWHP and 324 RWft/lbs. You think I can do a 4th gear burnout with that??
  #24 (permalink)
Old 02-07-08, 06:11 PM
90_Red_LX's Avatar
Official Member
I just use a high rpm 1st gear burnout on street tires. 3-5 seconds is optimal for traction for em.
  #25 (permalink)
Old 02-07-08, 06:16 PM
85_SS_302_Coupe's Avatar
Do the heal/toe routine and with practice you can feather the brakes enough to pull off one of these:
http://videos.streetfire.net/video/2...8a32c26c36.htm
That was 2nd gear and about 20 feet of third. I would've got really crazy but the street was like a tar and gravel surface...really super rough and i was afraid i'd blow a tire and they had to get me to the tire shop..lol.
Quote:
That's how i do it. It's not a literal HEAL/TOE, more of an arch area on the brake and rolling my toe to the gas. As i let off the brake i just roll my toe over more as needed to keep the RPMs up.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
