12-16-07, 11:24 PM
|  | have car, will race....wait, it doesn't run | | Join Date: October 2004 Location: New Lenox, IL
| | | Dyno Numbers Thread
By popular request, I have created a Dyno Numbers thread.
Please PM me, or email me copies of your dyno sheets to be posted in this thread. If you need hosting, I would recommend creating a Photobucket account, or I also have a Photobucket and FTP site which I could use to host your sheets, as well.
Submissions will be displayed in the following format:
================================== your SN user name ### rwhp / ### rwtq
mod list goes here
[img] dyno_sheet.jpg [/img]
Time to show us what your hard earned dollars paid for!
12-26-07, 01:53 AM
| | HGFireHazard 313.6 RWHP / 374.2 RWTQ
Vortech S-Trim V1 Supercharger
Walbro 255 HP in-tank fuel pump
T-rex in line 255 fuel pump
FRPP 42# injectors
MSD (Vortech) BTM
AFM Power Pipe
PMAS 80mm MAF calibrated for 42# injectors
MAC 1 5/8" Ceramic Coated Long Tube Headers
Custom H pipe
Flowmaster 40s
2 1/2" Stainless tips
12-28-07, 06:59 PM
| | Wi Stang 511 RWHP / 479.5 RWTQ
Bone Stock shortblock
Vortech V-2 S Trim (10 PSI)
Twisted Wedge Heads
TF Street Heat Intake
TF Stage 1 Cam
Snow Performance Methanol Injection
AFM Power Pipe
PMAS 80MM MAF
70MM Edelbrock Throttle Body
255 lph Walbro Fuel Pump
42 lb FRPP injectors
twEECer
Meziere Electric Water Pump
Romac Balancer
BBK EL Shorty Headers
BBK Off Road H-Pipe
Dumped Flowmaster Mufflers
T-56 (Viper Spec)
Zoom Clutch
DynoTech Alum Driveshaft
01-15-08, 08:18 PM
| | kck6894 421.1 RWHP / 391.2 RWTQ
347ci - 11:1
TFS heads-custom porting
Victor 5.0L Intake-custom porting
90mm Throttle body
80mm Shorty Air Flow Meter
AFM Power pipe
AFM N-111 cam
42lb injectors
Kooks 1 3/4 long tubes
Kooks 3" x-pipe
PMS
Tremec TKO
Spec Stage 3+  |
02-09-08, 01:50 AM
| | ProKiller 390.2 RWHP / 361.0 RWTQ
Stock 302 bottom end
Edelbrock Performer 1.90 valve heads
Edelbrock Performer RPM intake
FRPP F-303 cam w/ 1.7 cobra roller rockers
FRPP 24# injectors
C&L 76mm MAF
Edelbrock 70mm throttle body
Vortech V2-SQ (~10lbs.)
255LPH intank pump w/ T-Rex inline
Vortech FMU
MAC shorty headers, O/R H-Pipe, MAC mufflers
MSD coil and 6A
Autologic chip burnt for safe tune
T-3550 w/ Alum. Driveshaft
Fluidyne Alum. Radiator 180* T-stat  |
02-09-08, 01:53 AM
| | ProKiller 450 RWHP / 450 RWTQ
DSS 331 stroker short block
AFM Power Pipe
AFM B-21 Cam
Pro-M 80MM mass air w/ attached filter
42lb FRPP Injectors
MSD Pro-Billet Distributor
AFM PMS w/ boost controller
Billet Smog Pump Delete
EGR Deleted
Mcleod clutch
Fidanza steel flywheel  |
02-10-08, 12:07 PM
| | zenboy99 330.1 RWHP / No torque rating on dyno pull
Holley systemax intake
Twisted Wedge heads (untouched)
Stock 190k shortblock
FTI cam (ground for daily driver use)
BBK long tube headers, x-pipe, magnaflow catback
Pro-M 80mm MAF Accufab throttle body
Smog pump and EGR removed,
Running power steering and AC  |
03-21-08, 08:49 AM
| | MattZ281LE 306.5 RWHP / 329.4 RWTQ
AFR 165cc cylinder heads
Tmoss Ported GT40 intake
Crower 15511 cam
Pro M 77mm MAF
24lb. Injectors
FRPP 65mm TB
Ford Shorty headers
MAC catback
Stock tune  |
03-21-08, 08:55 AM
| | MattZ281LE 660.59 RWHP / 570.02 RWTQ
331 stroker
Edelbrock Victor Jr. cylinder heads
Tmoss ported GT40 lower intake
Downs upper intake
Comp cams XE282HR cam
Vortech T-Trim supercharger
60lb injectors
75mm TB
80mm MAF
Full fuel system
Mac 1 3/4 ceramic coated longtube headers
Mac Prochamber and 2.5 catback
MSD Distributor, ignition box, and coil  |
05-15-08, 04:21 AM
| | SVTtripleblack 265.8 RWHP / 306.1 RWTQ
Crane 2031 cam
BBK short tube headers
BBK off road H-pipe
Flowmaster catback
Mac U/D pullies
FRPP 65mm TB
PMAS 75mm MAF
CAI
Diablosport chip tuned  |
02-01-09, 07:21 AM
| | GTA_V6_Mustang 224.45 RWHP / 298.33 RWTQ
Blue Oval Industries Aluminum Underdrive pulleys
Pypes Catted X-Pipe
Stock H/C/I  |
08-31-09, 06:23 PM
| | 1994Vib.RedGT 268.4 RWHP / 303.6 RWTQ
Pro-m 75mm MAF
BBK 70mm Throttle Body
Cobra intake
Self-ported E7 heads with Crane springs
Steeda #19 cam
Kirban AFPR
24 lb. injectors
BBK underdrive pulleys
Mac ceramic coated shorty headers
Bassani off road X-pipe
Flowmaster 40 series cat back
3.55 gears
MSD distributor  |
08-31-09, 06:27 PM
| | Dizzy_ax 418.77 RWHP / 394.16 RWTQ
Stock shortblock
Vortech V1 S-trim supercharger (8-10PSI)
AFR 165cc Pedestal Mount Heads
Steeda #19 cam
Flow matched 42 lb. fuel injectors
C&L MAF
BBK Shorty headers
High flow cats
X-pipe
Side exhaust
Flowmasters Delta 40 series cat back
Dual 255 lph fuel pumps
Canton high flow fuel filter
Crane Ignition box/coil
Snow Meth/water injection
3.73 gears  |
08-31-09, 06:31 PM
| | revhead347 489.78 RWHP / 635.31 RWTQ
347 Stroker
Canfield 192cc heads
Trick Flow stage 3 cam
Holley Systemax 2 intake
NOS dry nitrous system
Tremec 3550 transmission  |
08-31-09, 06:36 PM
| | D-Phresh 386.43 RWHP / 460.74 RWTQ
Stock shortblock
Single turbo @ 8 PSI
3.55 gears  |
08-31-09, 06:39 PM
| | Venom351R 338.15 RWHP / 342.85 RWTQ
AFR 185 Heads
Trick Flow R intake
FTI Camshaft (custom grind)
Trick Flow 1.7 RR
Edelbrock 75mm Throttle Body
Roush Shorty Headers
Bassani catted X pipe
Magnapack Mufflers
PMAS 95MM Velocity Meter
36 lb Injectors  | | Thread Tools | | | | Display Modes | Rate This Thread | Linear Mode | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
