12-18-07, 01:22 AM
|  | Member | | Join Date: August 2005
| | | washing a machined block?
I am building my first motor from the ground up but ran into a question. Is power washing the block a really important key before assembling a shortblock? Why I ask is I put my engine together, its ready to drop in, but after reading some things it seems like alot of people recommend washing the shortblock before hand. Am I taking a risk here? is there anything else I could do to clean it while its assembled? Should I just bite the bullet and dissasemble every thing to clean it?It was machined at a very reputable machine shop here and looked very clean when I picked it up and though nothing of cleaning it. |
12-18-07, 02:24 AM
| | Banned | | Join Date: May 2007 Location: illinois
the shop cleansthe bocks after machine work most of the time they leave behind honing grit in the cylinder bores and maybe small metal flakes people usually clean it out
id say run it for 30 minutes to 1 hour and change the oil |
12-18-07, 10:48 AM
|  | Founding Member | | Join Date: December 2001 Location: Jefferson, WI
Any decent machine shop should not give you back a freshly machined engine with shavings in coolant/oil passages. |
12-18-07, 11:49 AM
|  | Official Member | | Join Date: September 2005 Location: Delavan, IL
There's nothing wrong with washing a block. I would suggest hand and air drying it immediately afterwards. Then just coat it in some light oil to keep rust away. |
12-18-07, 04:12 PM
|  | Official Member | | Join Date: August 2007 Location: FORD CITY, PA.
wash it with dish detergent and purple power in hot water then dry it with an air hose and paint it, put motor oil on all the bores (cylinder,lifter) and decks. |
12-18-07, 07:15 PM
|  | Official Member | | Join Date: August 2003 Location: Newark, Ohio
Please, please dis-assemble it and wash it. You know those little white, fuzzy, bendy things people use for decorations? Get some of those and run it through your crank and block oil passages along with some hot soapy water, you'll thank me later. Punisher has it right, soak the block with purple power, get some hot soapy water and scrub the block down (don't forget your white fuzzys  ). Rinse it off good, wipe off the machined surfaces (bores & deck) with a CLEAN lintless rag and quickly spray it down quickly with WD. Machined surfaces will start to rust almost instantly if you don't, be alert. Air hose the rest of the block dry, being sure to keep the WD handy. After your done drying wipe some oil in the bores and deck. Your block may look clean, but there are always places where dirt is hiding, just trust me. |
12-19-07, 12:58 PM
|  | Official Member | | Join Date: September 2007
| | Quote:
Originally Posted by Jason 302 Please, please dis-assemble it and wash it. You know those little white, fuzzy, bendy things people use for decorations? Get some of those and run it through your crank and block oil passages along with some hot soapy water, you'll thank me later. Punisher has it right, soak the block with purple power, get some hot soapy water and scrub the block down (don't forget your white fuzzys  ). Rinse it off good, wipe off the machined surfaces (bores & deck) with a CLEAN lintless rag and quickly spray it down quickly with WD. Machined surfaces will start to rust almost instantly if you don't, be alert. Air hose the rest of the block dry, being sure to keep the WD handy. After your done drying wipe some oil in the bores and deck. Your block may look clean, but there are always places where dirt is hiding, just trust me. | LOL! White fuzzys = pipe cleaners  |
12-20-07, 08:49 PM
| | Quote:
Originally Posted by Fast63 LOL! White fuzzys = pipe cleaners  | Haha, thats what they are! I couldn't think of the word | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
