Mustang Forums at StangNet
Thinking of adding another pony to stable!
This is a discussion on Thinking of adding another pony to stable! within the Mach 1 forums, part of the Special Production category; i like the Mach 1's because of the shaker hood! (and of course the performance) does it shake a lot? ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Special Production > Mach 1
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 12-19-07, 07:36 PM
88-378's Avatar
Official Member
i like the Mach 1's because of the shaker hood! (and of course the performance) does it shake a lot? Like the old T/A's?
  #2 (permalink)
Old 12-19-07, 09:00 PM
Crzyhrse's Avatar
Official Member
It will shake a good amount when you stab the gas. Under just normal idle it only shakes a very small amount. I'm sure with a different set of cams or alot higher horsepower it probably shakes alot under normal idle. Most people who don't know what a new Mach is thinks it's a supercharger.
  #3 (permalink)
Old 12-20-07, 07:55 AM
DOHC otto's Avatar
Quote:
Like he said not much factory but there was a guy at the NMRA's in Bowling Green this year with a set of Comp cams and it shook like the ground in California very cool with cams but you'll need about 1100 bucks for a set.
  #4 (permalink)
Old 12-20-07, 09:11 AM
88-378's Avatar
Official Member
Are they easy to work on?
  #5 (permalink)
Old 12-20-07, 06:29 PM
DOHC otto's Avatar
Everything is pretty easy except headers most guys have to pull the motor to get them on the car but you don't flow that much better with headers because the 4v heads come port matched to the manifolds.
  #6 (permalink)
Old 12-22-07, 07:39 PM
rowapr's Avatar
the mach shaker definately shakes with a power adder. i have a vortech on mine and i had to remove the two mounting bolts because it would hit the side of the hood. and the header install is not as bad as most people make it out to be. i took me 7 hours on my back to get mine in. just drop the k member. 8 bolts and it falls out
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
