Mustang Forums at StangNet
Funny Noise from the Mach ???
This is a discussion on Funny Noise from the Mach ??? within the Mach 1 forums, part of the Special Production category; My car is making a really weird noise after you start it and it is at high idle for about ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Special Production > Mach 1
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 01-09-08, 02:33 PM
DOHC otto's Avatar
My car is making a really weird noise after you start it and it is at high idle for about 20 seconds it makes a loud thump coming from the bottom of the car. Only does it once and only when the car hasn't ran in a few days. Temperature outside doesn't seem to effect it. It kind of sounds like someone hit the bottom of the car with a bat. Seems to be coming from the passenger side by the mid pipe. I got under the car and no scrapes or dents around any of the exhaust. If anybody has a clue what it could be please help me out .
  #2 (permalink)
Old 01-15-08, 05:21 AM
fox-gt's Avatar
Official Member
Quote:
Mine makes a similar noise if the AC or Heater is on.
from: http://www.mach1registry.org/forums/...ad.php?t=59200
Yep. Welcome to the world of the infamous A/C thump. There is a TSB on it, and it is the hose shifting when the compressor engages. You can actually fix it yourself with some pipe insulation and zip ties. Look at the right side strut tower and the hose right next to it. When the A/C cycles the hose shifts and thumps againt the strut tower. By wrapping the hose in the pipe insulation it keeps it from shifting as much and muffles the noise. Hi-tech...eh?
* TSB #17531 -- THUMP NOISE WHEN A/C CLUTCH ENGAGES. *MJ (NHTSA ID #10008103, FEBRUARY 01 2004)
* TSB #17286 -- THUMP NOISE WHEN AIR CONDITIONING CLUTCH ENGAGES. *TT (NHTSA ID #10004930, OCTOBER 01 2003)
* TSB #02208 -- CLIMATE CONTROL A/C SERVICE TECH TIPS. *EH (NHTSA ID #10013060, OCTOBER 14 2002)
HTH
  #3 (permalink)
Old 01-15-08, 08:59 AM
DOHC otto's Avatar
Thanks man that fixed it. You can barely even hear it now.
  #4 (permalink)
Old 01-15-08, 09:03 AM
fox-gt's Avatar
Official Member
No Problem
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
