Mustang Forums at StangNet
Agent 47 mirror install
This is a discussion on Agent 47 mirror install within the 2005 - 2009 Specific Tech forums, part of the 2005 - 2011 (S-197) Mustang category; Just got done installing them this afternoon and I must say it was a fairly easy swap with an awesome ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2011 (S-197) Mustang > 2005 - 2009 Specific Tech
Over 153,000 Members!!
Reply
  #1 (permalink)
Old 01-24-08, 11:24 PM
kooldawg6's Avatar
mine works really well and can take a fair amount of pressure without bending
Just got done installing them this afternoon and I must say it was a fairly easy swap with an awesome look Took me about 1.5 hours including cutting time and pic taking. Spent several minutes while trying to get the factory glass off not wanting to break it.
Remove the plastic trim piece covering the wires/hardware for both driver and passenger side mirror. They just pull straight off. I found it worked by getting a hold of the top most corner and gently pull. The top will pop loose enabling you to use both hands and pull straight out. Be careful on the driver side as the wires for the adjuster aren't very long. Driver side has two connections(one for adjuster knob and one for the mirror motor) while the passenger side has one connection(mirror motor).
Passenger side
Backside of passenger side trim piece
Next step is use 7/16" wrench to remove the three retaining nuts for each mirror(careful upon removal of the nut as the door panel is open just below-drop one and off the door panel comes )
Remove the three studs from the factory mirror along with the foam pad and install on the new mirror housing.
Stud
Gently, yet firmly tug on the factory glass to remove it from the motor. I found it easiest by tilting the bottom of the glass out and pulling along those two corners. I've never done this before, so I was worried about breaking something...however, both sides came out fine
Now that you have the mirror motor exposed, there are three Torx screw holding the motor in place. After removing those, pull the motor up and there is a wire connector on the back side. '06 has a weird shaped connector(not sure what other years have)that has a clip on each side.
Next came the step that was not in the instructions and I did not feel comfortable tugging on the wiring harness connector to pull the rubber grommet through.
On the factory mirror there are two plastic rivots that I used a Dremel and cut them down so I could remove the "arm" from inside the factory mirror housing. There is also a small Torx screw holding the "arm" in place. Now all you have to do is twist and turn until the "arm" slides out. Now it is nice and easy to get the wire harness off. Working from the backside of the harness, I was able to push the grommet through and thread the harness out. Careful of the prongs on the connector as you pass it through the semi small hole.
Thread the harness through the new mirror and connect to the motor. Reinstall the motor using the factory screws in the housing.
Place the mirror back on the car and reinstall the three retaining nuts and wire connectors. Test the connections to make sure the motors work before placing the trim pieces back on(possibly to save a few seconds and hassle). Motors work and now can place the trim pieces back on by aligning the alingment pins with the holes and gently push straight in.
Now you take the glass and install it on the motor assembly. (Once again, I've never done this, so I had no idea how easy/hard it was) The piece of glass that has "Objects may be closer than they appear" goes on the passenger side. There is a "notch" in the plastic on the backside of the glass that runs nearly the full width. That part goes at the bottom. Place the glass against the motor and gently, yet firmly press until you hear some clicks/pops. That should be it! You are now ready to enjoy your new look
Backside of factory glass
These mirrors are quite a bit smaller than the factory ones.
Updated/better pics
Last edited by kooldawg6; 01-25-08 at 02:11 PM. Reason: Updated with newer/better pics
  #2 (permalink)
Old 01-25-08, 12:59 AM
fobra559's Avatar
At least it's more erect and not floppy anymore.
Looks great man. It's a lot better than the stock huge truck looking side mirrors. Nice write up too
  #3 (permalink)
Old 01-25-08, 02:00 AM
Towelly's Avatar
Official Member
Sweet. How did you take the glass out in the old mirror? Also, can we get some pic's of them from further away and say from the front? Looks like I may do this over the summerl.
  #4 (permalink)
Old 01-25-08, 02:06 AM
Mr_Q's Avatar
Yeah but I like how much I can see with the stock mirrors. The mod I wanted to do when I had my Stang with some color was to get the body color matching half caps. They set off the mirrors really nice.
I hate those tiny arse mirrors from Agent. They are just like the tiny arse mirrors in my '90 5.0, heh. I can't see ANYTHING in those.
  #5 (permalink)
Old 01-25-08, 10:11 AM
stangdude2000's Avatar
How is the visibility out of the mirrors?
  #6 (permalink)
Old 01-25-08, 10:24 AM
HEAVYGT's Avatar
Official Member
Quote:
Visibility is surprising good...I think they really make a difference in the look of the car.
Oh ya, nice little writeup Kool.
  #7 (permalink)
Old 01-25-08, 11:19 AM
fobra559's Avatar
Nice Heavy GT How much did it cost to paint the side mirrors?
  #8 (permalink)
Old 01-25-08, 11:29 AM
HEAVYGT's Avatar
Official Member
Quote:
I have a friend in the business who only charged me $60....he told me he would charge $100.00 normally.
  #9 (permalink)
Old 01-25-08, 12:16 PM
kooldawg6's Avatar
I will take some better pics this afternoon and post later tonight of the mirrors. Also the backside of the factory glass to show how they connect. Wish now I took some of the motor
  #10 (permalink)
Old 01-25-08, 12:27 PM
kooldawg6's Avatar
It is decent, but nothing like the truck-like stockers(I quickly realized just how big they were once they were side by side ). Of course it did have me moving my head a bit more today driving it for the first time, but it will become second nature soon enough. I don't at all see where it would be unsafe as other cars have similar sized mirrors Just that we get used to what's there from the start. I still haven't gotten used to looking out the back window and knowing what all is there after swapping the spoilers and that has been about 6 months. I feel the look that is achieved by these mirrors far outweighs the smaller field of view.
  #11 (permalink)
Old 01-25-08, 12:34 PM
fobra559's Avatar
Quote:
Well that's not going to happen as I'm here in Cali
  #12 (permalink)
Old 01-25-08, 12:45 PM
SlideWRX's Avatar
Official Member
Thanks for the comparison pics! I was wondering how different they were. Edit: I like the finish as well.
Tom
  #13 (permalink)
Old 01-25-08, 01:19 PM
bigcat's Avatar
start with the upper hole, and if more traction is needed, try the lower hole
nice write up kool! ill copy the first post to the write up thread.
  #14 (permalink)
Old 01-25-08, 01:22 PM
ApexStang's Avatar
Official Member
Thanks for the write up Kool. I have these mirrors still in the box at the house. Plan on doing the install in 3 weeks or so. Just been too lazy to knock it out.
  #15 (permalink)
Old 01-25-08, 02:12 PM
kooldawg6's Avatar
Quote:
Thanks big
I went back and edited the first post with updated pics.
  #16 (permalink)
Old 01-25-08, 02:13 PM
kooldawg6's Avatar
Quote:
It's really quite easy and will give you yet even more reason to stand and looking at your car
  #17 (permalink)
Old 01-25-08, 02:30 PM
HEAVYGT's Avatar
Official Member
Why...how much are they quoting you to have them painted?
  #18 (permalink)
Old 01-25-08, 02:57 PM
GoldMember
Nice mirrors and write-up.
Vision to the rear should be the same since you are reusing the mirror, just the housing is smaller. Correct me if I'm wrong.
  #19 (permalink)
Old 01-25-08, 04:30 PM
fobra559's Avatar
I've heard $200 plus. I'm still looking around through to see if I can find somewhere that does it in the $100 range at least and that is reputable.
  #20 (permalink)
Old 01-25-08, 09:22 PM
HEAVYGT's Avatar
Official Member
You are not reusing the same mirror...you get new mirrors...the only thing you reuse is the electric motors out of the stock ones, the factory rubber foam and the through door retaining bolts/nuts which you need to reattach with 5 minute epoxy.
  #21 (permalink)
Old 02-10-08, 04:50 PM
Az Pete's Avatar
Official Member
My wife actually complained about the truck mirrors blocking her view so I was on line ordering these mirrors instantly.
Read your report and once the flu bug passed, it took me 50 min. to do the install. I did not find it necessary to remove the original internal support to remove the harness. I used a small screwdriver to pop out the rubber grommet and then the wires simply fed thru the unit with a little finess to slip out.
One thing I did not like was when installing the three mounting studs into the new mirrors, it is real easy to get the angle wrong so be careful there. Wife loves them and since the car is black, no painting is needed. Great product.
  #22 (permalink)
Old 02-10-08, 06:03 PM
kooldawg6's Avatar
I didn't try prying it out as it was(both parts together)since I wasn't sure if I'd break the harness or a wire. At least it will be easy to put back together if you use some epoxy where the rivets were. I got one of the passenger side retaining studs threaded just wrong enough it wouldn't fit back in the door, but was easily fixed
Glad you're feeling better and love the new mirrors Pics????
  #23 (permalink)
Old 02-12-08, 03:11 AM
Deric's Avatar
Nice write up
  #24 (permalink)
Old 02-12-08, 03:31 AM
Official Member
looks good.
have them on my car...love them
visibility is more than fine, while the housings are a big difference in size, the mirrors themselves arent very different in size and the blind spot while driving isnt big enough for anything to hide in except for maybe some skinny chick standing exactly in the right spot.
  #25 (permalink)
Old 02-12-08, 11:38 AM
GOLDENPONY's Avatar
Mirrors
Nice write up, nice clean installation - looks good. Actually though, I like the visibility with my factory mirrors. I'll stay with the stockers, but I do appreciate what you've done here.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
