Mustang Forums at StangNet
Are the A/C systems from '86 - '90 the same?
This is a discussion on Are the A/C systems from '86 - '90 the same? within the Other Auto Tech forums, part of the General Automotive Forums category; Are the A/C systems on '86 5.0 cars & '90 5.0 cars the same? If not, what changed?...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 02-01-08, 05:49 PM
Loco5.0's Avatar
Official Member
Question Are the A/C systems from '86 - '90 the same?
  #2 (permalink)
Old 02-01-08, 06:40 PM
Darkwriter77's Avatar
Resident Ranting Negative Nancy
Far as I know, all is the same, at least as far as Fox-bodies are concerned. It wasn't until automakers started using R-134 in the early 90's that things got a little different, although nothing dramatic. You can always retrofit R-134 into an older 5.0 just by flushing the system out completely, putting on the different R-134 fittings, sucking it down, and pumping 'er full again, although it would be a good idea when you do that to swap all the A/C system seals out with newer-style O-rings and such. And, of course, you ALWAYS wanna replace the orifice tube and accumulator when redoing the A/C system, as they kind of act as filters to screen out all the gunk n' crap, and they tend to plug up over time.
I don't think Ford really started using R-134 all across the board until around '94 (or '96, at the latest), so pretty much all '79-'92 Foxes were R-12 from the factory ... not so sure about the '93 models, though.
  #3 (permalink)
Old 02-02-08, 07:24 PM
Loco5.0's Avatar
Official Member
The reason I ask is b/c the 89 I bought does not have a/c & I need to put it back in the car.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
