View Single Post
  #19 (permalink)
Old 03-13-08, 03:23 PM
parthos's Avatar
parthos parthos is offline
Total cost was 367.24, shipped to my door, with screw in studs installed. They fit like a glove. I did have some issues though. I went with the ranger drum, the center hub didn't quite fit, but some light honing with a break cylinder hone on the drum center hole and everything fit. The other thing, is to make sure to specify the flange diameter. It should be 6 inches, but I forgot to specify this, mine was too wide to seat properly on the drum. No big deal, I took the axles out, and wrapped a rag around the bearing, lightly clamped the bearing in my vice, and used a grinder to reduce the diameter until they fit the drums. The axle rotated while I ground, and using a course flap wheel it took about 10 min per axle to get this corrected.
