Mustang Forums at StangNet
Clutch Chatter
This is a discussion on Clutch Chatter within the 2007 - 2009 GT500 Tech forums, part of the 2005 - 2009 (S-197) Mustang category; Clutch chatter started around 200 miles and is getting worse. Anyone else notice this condition?...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2007 - 2009 GT500 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 02-29-08, 07:00 AM
Roger Ramjet's Avatar
Official Member
Clutch Chatter
  #2 (permalink)
Old 03-03-08, 09:54 AM
Usually giving it a lot more gas will help. I barely notice it when I drive them now. If its getting worse, maybe there is something wrong with it.
  #3 (permalink)
Old 03-03-08, 02:37 PM
Official Member
That's what I was looking for - if someone else noticed the chatter. Thanks!
Since your car has more HP, how do you get it to hookup?
  #4 (permalink)
Old 03-07-08, 02:14 AM
Suspect is the throw-out bearing. It is nearly impossible to put it in backwards without noticing. There are long and short throw-out bearings. If you put in a bearing that was shorter than the one intended for the clutch, you would have exactly the situation you described..
  #5 (permalink)
Old 03-08-08, 05:51 AM
Official Member
Wrong throw-out from the factory?
  #6 (permalink)
Old 03-15-08, 03:13 PM
Williesvt's Avatar
Quote:
it took me a couple hundred miles to figure out where exactly it engages....maybe you are halfway in, halfway out? these clutches are soo much lighter than the termy cobras......
  #7 (permalink)
Old 03-15-08, 07:10 PM
aflacjack's Avatar
I have been having the same problem. I got it figured out now......it is just so much different than my termi. It engages way much later in the travel.
  #8 (permalink)
Old 03-22-08, 04:52 PM
The clutch chatter is normal, and I believe they even state that in the owners manual. I have pretty much figured out a way to drive it so it doesn't chatter anymore though. I think with some more gear it would be almost non existant.
  #9 (permalink)
Old 03-30-08, 12:13 PM
Williesvt's Avatar
Quote:
Reply
« Exhaust! | Cams? »
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
