Mustang Forums at StangNet
Pinion Angle help
This is a discussion on Pinion Angle help within the 2007 - 2009 GT500 Tech forums, part of the 2005 - 2009 (S-197) Mustang category; Hi all, I'm new to this forum and found it by the suspension tech articles given to me through J ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2007 - 2009 GT500 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 03-01-08, 08:46 AM
Pinion Angle help
Hi all,
I'm new to this forum and found it by the suspension tech articles given to me through J & M products. I have an 07 500 vert and have installed the J & M adj upper contol arm, lower control arms, adj panhard rod and lowering springs. My question is with pinion angle. Following the tech article by Bigcat it states,
FACTORY TWO-PIECE DRIVE SHAFT: Use your magnetic angle finder and attach it to the FRONT drive shaft. Record the front drive shaft angle. Next, attach the angle finder to the pinion flange. Record the angle. Subtract the pinion flange angle front the front drive shaft angle to get your net pinion angle
I think the word "front"used first in the last line is a typo and should be "from" but any way I am reading 4.4 degrees at the front driveshaft (rearward or downward toward the rear of car) I am attempting to read at the pinion angle because there really isn't a flat on the pinion flange I can attach to with the driveshaft installed but I am getting around 89.9 degrees. So based on the instructions I am getting -85.5 which is obviously not what I'm looking for (-2 is my understanding) Because the driveshaft and pinion flange are perpendicular should I be viewing this in reference to 90 degrees? In other words 90-85.5= 4.5 net?
Any help would be greatly appreciated
Tim
  #2 (permalink)
Old 03-01-08, 01:53 PM
I think I figured it out by a different method. I ended up measuring vertically off the rear of bellhousing as perpendicular to transmission centerline then off the pinion flange as perpendicular to pinion centerline. I set rear 2 degrees more than the front which moves the front of pinion downward or -2
  #3 (permalink)
Old 03-03-08, 05:56 AM
Roger Ramjet's Avatar
Official Member
The whole idea of setting pinion angle is to get the U-joints operating at the same deflection angle. Measurilng the bellhousing angle has nothing to do with the driveshaft angle. I think you need to start over using the front section driveshaft angle vs. the pinion angle.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
