If you don't like the 268H, then don't use the Edelbrock 2122. You won't be able to tell the difference between the two. I'm puzzled on just what you want here. You want the big cam sound but think the 280H is "too much" ? And you're not satisfied with the 268H? The X303 is way more cam than the 280H, only main difference between the two is the LSA. A roller is probably what you want, but to get one in a 289 block, it's going to cost you another $600 at a minimum, that's not including the cost for the screw in studs and springs to match the cam.
