07-06-08, 08:47 PM
|  | SuperMod Canadian Colossus | | Join Date: August 2002 Location: Ontario, Canada
| | Quote:
Originally Posted by Metalcop I would not use the boost-a-pump as a long term solution. IMO, I have never agreed with cranking up the juice to the fuel pump, to get more volume. The boost-a-pump is 'band aid' defined. | Been running one on my ride for over a year now with "zero" issues. And that's running it under constant high voltage operation....I got rid of that crappy hobbs switch after the first week. |
07-07-08, 12:37 PM
| | Member | | Join Date: September 2005
I don't think the clutch is slipping. At least, it didn't smell like it was! I do have the NGK tr6's gapped at 36. Did have a small vaccume leak. It was fixed for the tune, but I will need a more permanent solution. Easy fix!
And from what everyone has posted, it seems like I dynoed my car under the worst possible conditions. No fault to Dynospeed of course! 150 degree IAT's, a heat soaked engine, and 100 degree weather in July! With all that, I still managed 345rwhp! I guess its good to know what I can be guaranteed to have during the summer months!
And I'm not a fan of bench racing, but 65 degree weather and seeing 12 -13lbs of boost might put me over the 400rwhp mark! 10hp for every 10 degrees of temp, and guessing almost 10hp for every additional pound of boost. Didn't know if those two would bleed together or not. And a question on that! My tune is based off of 10lbs of boost! When the months cool down and I do see 12-13lbs, will it cause me to run lean? And should I be concerned about how much power I see over my tune when it cools down?
07-07-08, 01:34 PM
A10hp for every 10 degree drop in temp is really generous…and those are gains from much larger and more high RPM efficient blowers than the little M90. I would realistically put horsepower increase guesses in around the 3-4hp range from what I normally see of them. And 10hp per pound of boost is assuming you're running enough blower and also within its adiabatic efficiency level. You run a pulley any smaller than 2.5-2.7" on an M90 and you're bringing it out of its efficiency range and turning it into an expensive hair dryer. Over spinning your Eaton will most likely result in a little more torque down low and earlier in the rev range, but don’t count on seeing much more up top.
Ask me how I know.  |
07-07-08, 02:52 PM
| | Member | | Join Date: July 2008
| | Quote:
Originally Posted by pbm.cc I would had stuck with the 111.5! The guy that MAKES the MOSALEEN idlers is the one that told me to use that size belt with the 66mm and the idler. It seems to weird to use the stock belt that was on a bigger pulley plus no idler, that could also be why you didnt see the 13lbs.
Some things dont make sense to me...
1: if the Chicane intercooler almost garrantees about 40-50rwhp where are they at? (my s281sc dynoed at 301rwhp with everything stock from Saleen.)
2: the TTI should had given it more rwhp... I was thinking about 10-25rwhp since its from the LMAF sensor, single blade TB and the intake itself. ( so that should had been about 301 + lets say 40rwhp from the intercooler + say 15rwhp from the TTI= 356rwhp give or take and you still have LT's and the 66mm pulley! and lower ported!!! Something is wrong... I would think.
what size injectors do you have? maybe time for a bigger heat exchanger? cams? catback? damn it! It should be over 400!  | I've been watching this thread for awhile now.....something definitely doesn't seem right.
With a 66mm pulley, custom tune, and SVT fuel pump I put down 340rwhp with a series II saleen blower. SVT focus fuel pump was fine and I didn't run out of fuel. I think I topped out at about 8 or 9psi for boost.
PBM.CC is right. The chicane intercooler (if properly installed) should give you about 30-35 more horsepower (the highest ever documented was +44hp from Mark @ Performance Autosport in VA on a series IV S/C.
I swapped out my belt for a smaller one. I'd guess you're seeing at least some belt slippage.
Maybe something went wrong with the porting? I would check fuel delivery on this one and then upgrade to 42lb injectors if necessary.
Also...for the mods that you have done.....you should have had to change out your mass airflow sensor (or go the diablosport MaFiA route). Did your MAF peg? I was right on the border with mine. I have to upgrade if I add the chicane intercooler.
Last thing....there's gotta be something wrong with that tune. Re-check the A/F ratio.
Keep us updated.... |
07-08-08, 12:58 AM
| | Official Member | | Join Date: June 2004
| | Quote:
Originally Posted by eviligloo I've been watching this thread for awhile now.....something definitely doesn't seem right.
Keep us updated.... | What I am really leaning towards is just installing cams on the Saleen! I bet since it already has boost by me adding cams, 66mm pulley, mosaleen idlers and my frpp ceramic coated shorties I will either be higher or about the same as he.
I may need a MAFia and a LMAF, plus I still have room to upgrade the intake and intercooler and heat exchanger.
I still think something is wrong other than the temp. Probably the fuel pump I would go with the twin cobra fuel pumps. Why even bother with another Focus pump.  |
07-08-08, 09:19 PM
|  | Official Member | | Join Date: August 2003 Location: NJ
| | Quote:
Originally Posted by pbm.cc What I am really leaning towards is just installing cams on the Saleen! I bet since it already has boost by me adding cams, 66mm pulley, mosaleen idlers and my frpp ceramic coated shorties I will either be higher or about the same as he.
I still think something is wrong other than the temp. Probably the fuel pump I would go with the twin cobra fuel pumps. Why even bother with another Focus pump.  | Putting cams in a 4.6 ohc engine is far from a cost effective way to get more power.
The cams are expensive, and labor intensive, all for minimum power.
If the engine was getting rebuilt, ya, they are probably worth the trouble, but with the engine in the car, tearing it down to a longblock would not be worth it.
Basically, if someones goals are 425rwhp+, the saleen blower setup is not the way to go, nor is it finally wise to drop loads of money on parts to make it better.
You can sell it, slap a kb or vortech on there, and easily exceed the numbers you can get with the saleen kit. |
07-11-08, 02:11 PM
| | Quote:
Originally Posted by 2000xp8 Putting cams in a 4.6 ohc engine is far from a cost effective way to get more power.
You can sell it, slap a kb or vortech on there, and easily exceed the numbers you can get with the saleen kit. | Well the Anderson cams that I was looking at cost about $630.00 maybe like $200.00 for springs and retainers. My buddy at Ford house will charge me a 6 pack and a night to use the pool and have a cook out. I already have the 66mm pulley just not installed, I already have the headers just not installed. My buddy at Gearheads in Arlington TX or Manny at HPP can dyno the car with everything installed and we will see who spent more $ and for the most performance.
See that is my thing, I am not going to spent $6k on the KB 2.6 if:
1: I have to get ride of my hood
2: I am still limited by the heat exchanger and intake on the blower
3: pulley pulley pulleys
I would much rather get a Turbo kit for about $3-4k intalled and dynoed. That is why it is very important as to WHO you know! More than WHAT you know....
I can still keep the blower cams that I will have installed on the SOHC heads and being able to use them when I upgrade to the turbo kit wich will alow me to use the stock hood and would limit me less to RWHP/RWTQ. I will only install the headers idler and pulley and twin cobra pumps as I will need the fuel either way and the idler and pulley and headers can be sold again when I install the Turbo kit.
Trick flow make a new intake that is SOMEWHAT like the Bullit and I wanted to go that route. Add the TT single blade tb and buy a built shortblock and I am done.
See, my goal for the Saleen is 550rhwp-600rwhp from the turbo kit and a built short block. Give me a year or year and a half and I will be there.  |
07-11-08, 02:19 PM
+ with a turbo kit you relive crank stress and IT SOUNDS REALLY COOL WHILE SPOOLING UP AND THE BOV! lol |
07-11-08, 03:16 PM
Maybe for you if you are getting labor for free a turbo kit is 3-4 grand installed with a dyno run.
For anyone that has to pay for it, you are looking at leat at 6 grand, and possibly up to 9k.
Me personally i'd rather have an aftercooled vortech than most anything else. (on a 2 valve) on a 3v or 4v i'd rather have a whipple. |
07-12-08, 11:42 AM
| | Quote:
Originally Posted by 2000xp8 Maybe for you if you are getting labor for free a turbo kit is 3-4 grand installed with a dyno run.
Me personally i'd rather have an aftercooled vortech than most anything else. (on a 2 valve) on a 3v or 4v i'd rather have a whipple. | My friend Lance has a turbo shop where he will fabricate the kit.
My friend Robert works fot a Diesel company that he can get any turbo parts from the dealers dirt cheap (including Turbonetics)
My friend Jason will do the labor at Ford house in Dallas.
My friend Chris or Manny will tune it for a good deal.
everything is just parts that I can find for a good price. That is why I am leaning towards it.
I rather do a 2v cause I have never built one, I have had 2 built 4v and the cams will be more noticable on the 2v.
I do like twin screw blowers but the fact remains that you COULD have slippage and Turbos just makes more power for the same amount of boost or less.
I have experimented with ever poweradder and I must say Boost from a Turbo is something you do not forget.  |
07-18-08, 12:16 AM
| | Quote:
Originally Posted by RedS281GT I don't think the clutch is slipping. At least, it didn't smell like it was! I do have the NGK tr6's gapped at 36. Did have a small vaccume leak. It was fixed for the tune, but I will need a more permanent solution. Easy fix!
And I'm not a fan of bench racing, but 65 degree weather and seeing 12 -13lbs of boost might put me over the 400rwhp mark! 10hp for every 10 degrees of temp, and guessing almost 10hp for every additional pound of boost. Didn't know if those two would bleed together or not. And a question on that! My tune is based off of 10lbs of boost! When the months cool down and I do see 12-13lbs, will it cause me to run lean? And should I be concerned about how much power I see over my tune when it cools down? | Did you do a compression test? vaccum leak test? |
07-20-08, 02:17 PM
I haven't had time to do a compression test, my last semester of grad school is 24/7 right now. I hope to get it done soon though. I did find some vaccum leaks which might explain the bumps in the upper rpm range. I thought we fixed it on the dyno, but it might be coming loose with all the pressure around 5500prm
I did have some time to do a little research: Here's what I found on corral.net!
"When I had the stock Series IV setup, I did a series of 3 street runs from 1-3 gear and saw temps break into the 160-5° area (~80°F ambient). After changing to the Chicane cooler I recall the temps dropping to 130°F. I remember we got about a 35°F delta when we swapped the cooler out."
"A few months ago I did some WOT street runs while data logging information on the stock Series IV SC kit, ambient air temp was ~80°F. The inlet air temperatures jumped into the mid-to-high 160's °F (I think 167/8°F was the hottest run) boost was ~8.5-psig @ 5800-6000-rpms."
My temps were in the 150-160 range with the intercooler, heat soaked, and in 100 degree weather! I really believe that this is the reason I didn't break the 400rwhp mark! The vaccum leak hurt as well! But the intercooler was fighting a losing battle all day. Even with ice, the temps before the runs were at 130!!! I need to go back on a cold day in the winter and see what happens! I think I might need something to keep my temps down during the summer, i.e. smow performance or chiller killer  |
07-22-08, 04:02 PM
| | Member | | Join Date: May 2008
or a 35 shot of juice...  Thats what i believe I will be doing.
I can't wait to get myne on the dyno. It took out a 14 psi turbo grand prix gtp to over a buck thirty and when we were logging it says its 20+% too rich (base tune). This was on a predator mind you and no wideband but when it's dialed in i think 400 shouldn't be a problem. only problem is there are no dyno tuners close to here, and i don't have a license for another 37 days.
Im also getting belt slip like a mofo, the mosaleen idler will be ordered before its dynoed. Still Im hittin like 12-13 psi (on the 03 cobra cluster) @ 6grand. And talk about loud, the port makes these things sound NUTS.
07-29-08, 07:45 PM
| | Official Member | | Join Date: July 2003
| | Quote:
Originally Posted by RedS281GT Just wanted everyone know that i'm testing a new experimental intake for my Saleen. It's made by Tork Tech and the quality is amazing! I'll be taking it up to Dynospeed in Memphis for some testing in the next few weeks. Can't wait to see what numbers this thing produces! Enjoy the pics! 00 GT vert
Series II S/C
BBK long tubes & o/r x-pipe, pro 5.0, 3:55's, TT inlet, cobra TB, 66mm pulley,
90mm TB, Chicane intercooler, hand ported lower intake, SCT
| So where can we buy this intake it looks really good! |
07-29-08, 09:40 PM
| | Quote:
Originally Posted by mat82284 So where can we buy this intake it looks really good! | Tork Tech Inc. |
07-29-08, 09:50 PM
| | Quote:
Originally Posted by Gearbanger 101 | Thanks but i dont see it on there, just a photo no product. Do you have a direct link? |
07-29-08, 09:56 PM
| | Quote:
Originally Posted by mat82284 Thanks but i dont see it on there, just a photo no product. Do you have a direct link? | You really need to read this thread from the beginning.
The intake isn't advertised for sale alone, but from what I understand they're willing to sell it on it's own for Saleen guys that want to upgrade their current, restrictive inlet system. Try contacting them directly, or PM the original thread starter to see what it's going for. |
07-29-08, 11:01 PM
what to do? what to do?! I still think that the inlet kit (intake,TB,MAF,ADAPTER and K&N) would be worth it as my car is a real sc281! but I want to be forsure in the 400's! maybe I can guarantee it with the bigger heat exchanger and the cams!? and buy the intercooler... I already have the 66mm pulley, I am getting the gears (either 3:55's or 3:73's) this thursday... alumminum driveshaft... and FRPP ceramic headers, tuned with a predator.
What do yah think? the Inlet kit + 66mm (mosaleen idler) + Chicane intercooler + Cams + Bigger heat exchanger= 400rwhp?!
I will also be taking off the Borla mufflers and putting the Borla stingers on it. Should help for 1rwhp! lol... |
07-29-08, 11:39 PM
Why not add an electric water pump to your engine. Said to be good for 15rwhp alone.  |
07-30-08, 10:45 AM
|  | Founding Member | | Join Date: August 1999 Location: Vancouver, WA
JDM Engineering is testing the TTI setup on the 12th of August and doing a re-tune on the car, since the airflow has increased drastically.
Chris at JDM is running the project. |
07-31-08, 01:57 AM
| | Quote:
Originally Posted by rfedd JDM Engineering is testing the TTI setup on the 12th of August and doing a re-tune on the car, since the airflow has increased drastically.
Chris at JDM is running the project. | on RedS281GT car? I really wanted a goal of 400-440rwhp with the eaton M90... if I can guarantee those numbers from the TTI intake setup, intercooler and cams I would jump on it.
If not... then I would not invest on any parts for the motor and just start saving for a turbo kit.
I love all the insite and everyone's opinion on here... I really wanted to keep the M90 as its a real Saleen. Hopefully, if a new entire retune and enough fuel for the air is in RedS281GT's car at the retune... It should get alot better numbers.
Remeber to cool it before dynoing. Good luck bro.   |
07-31-08, 06:40 AM
| | Quote:
Originally Posted by pbm.cc on RedS281GT car? I really wanted a goal of 400-440rwhp with the eaton M90... if I can guarantee those numbers from the TTI intake setup, intercooler and cams I would jump on it. | I think you're pushing your luck a little with your estimates....especially with the torque values. |
07-31-08, 07:05 AM
| | Quote:
Originally Posted by Gearbanger 101 Why not add an electric water pump to your engine. Said to be good for 15rwhp alone.  | I'd say that's a bit of stretch, the water pump on a modular engine turns very easily, and IMO, there is no way it takes 15 hp to turn it. |
07-31-08, 10:41 AM
07-31-08, 12:32 PM
| | Quote:
Originally Posted by rfedd | Wait, is his m90 stock? or are you saying he upgraded his mp90 internals with the Tork Tech m112? Is that even possible? Second he had the stock saleen intake tube! So it sounds like a better alternative to spend the money on Cams and the Tork Tech M112 internals. How much does Tork Tech sell it for? | | Thread Tools | | | | Display Modes | Rate This Thread | Linear Mode | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | | |
