Mustang Forums at StangNet
EGR valve problems
This is a discussion on EGR valve problems within the Other Auto Tech forums, part of the General Automotive Forums category; I have a 92 saturn SL2, 5 speed and it boggs at 1500 to 2000 rpms, it is really annoying ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 03-20-08, 12:13 AM
gnx547's Avatar
Official Member
EGR valve problems
I have a 92 saturn SL2, 5 speed and it boggs at 1500 to 2000 rpms, it is really annoying now when releasing the clutch when I am in first gear to get going it boggs..
I think it is the EGR valve doing this, when I raise the idle it boggs but when I disconnect the vacuum line from the EGR it is fine. And when I raise the idle with the hose disconnected it is fine but when I connect the hose while the idle is up, it boggs and runs rough..I tried this with another EGR valve I got from the junkyard and does the same thing, I cleaned out both EGR valves and the diaphram moves and down. I also replaced the EGR solenoid. There is vacuum from the solenoid when I raise the throttle, so the solenoid is good.
Is my EGR valve bad? I do not see how the valve can be bad, is there something internal that could be bad? The diaphram moves easy, so I think it is good, but when it is on the car connected it boggs at 1500 rpms..I do not want to buy a new EGR valve and the bogging still happens..Driving the car like this is really annoying..What do you guys think?
  #2 (permalink)
Old 03-21-08, 08:20 AM
timeless2's Avatar
Vi Veri Veniversum Vivus Vici
Is the car throwing any codes?
  #3 (permalink)
Old 03-21-08, 10:07 PM
Darkwriter77's Avatar
Resident Ranting Negative Nancy
Is the solenoid separate from the EGR valve, itself? ... or is it one of those later-style valves with the solenoid and EGR valve together? Even though it may seem to move freely, does the EGR valve feel like it has any "grit" in its movement when you move the diaphragm in and out manually? It might be sticking on some bits of carbon.
Junkyard EGR valves are hit-and-miss. Tough to say whether you got a bum one by chance, or if the problem lies elsewhere when you go using old parts...
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
