Mustang Forums at StangNet
Cam selection for my 289
This is a discussion on Cam selection for my 289 within the Classic Tech forums, part of the Classic Mustangs category; Hey guys I just got my 289 rebuilt around 2 months ago, its been bored .030 with 10:1 flat tops ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Classic Mustangs > Classic Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 03-23-08, 12:44 PM
Banned
Hey guys I just got my 289 rebuilt around 2 months ago, its been bored .030 with 10:1 flat tops pistons, stock 289 mustang heads,crank,rods, 1.6 roller rockers, weiand intake, hooker headers and my cam is a CompCam 289-302 Marine 268H Cam. My 289 runs real good, but I was expecting to hear more cam. I love the X303 camshaft and wandering is their any cam that could go in my 289 to sound similiar to the X303? I was also wandering what else would I have to do to my motor to be able to handle that kind of camshaft? (Change out the valves, heads etc..)I know the X303 cam runs in the 302 but with usually the GT 40P heads. I would appreciate any help yall could give me.
Camshaft Specification Table
Part Number 31-218-2
Engine 1963-1995 Ford
289ci-302ci
8cyl.
Grind Number FS 268H-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.456 0.456
Duration At 0.006 Tappet Lift 268 268
Valve Timing At 0.006
Open Close
Intake 28 60
Exhaust 68 20
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 218 218
Lobe Lift 0.2853 0.2853
Lobe Separation 110
Recommended Valve Springs 942-16
  #2 (permalink)
Old 03-23-08, 02:23 PM
Official Member
the cam you have is basically the same cam that was in my 351 interceptor from the factory...nuttin' special. i swapped mine for a comp magnum, 292 duration/ 510 lift. it has a nice lope at idle, yet smoothes out just off idle. btw, ford motorsports has discontinued all smallblock flat tappet cams, they are rollers from here on out. also, congrats on the young owners awards, i showed my son (12 years old) the picture in mustang monthly, as the tahoe turquoise was the color of the 66 i drove in high school.
  #3 (permalink)
Old 03-23-08, 07:05 PM
You need more cam with that kind of compression, a good start would be Comp's 280H. As for springs, you'll need to see what you have now, plus what studs are on the heads. Have they been converted to screw in types? For just about anything hotter than the 268H, you'll need screw in studs, guide plates will depend of what 289 heads you've got. If they're the pre April 66 heads, they'll have pushrod guide slots and won't need guide plates under the screw in studs.
  #4 (permalink)
Old 03-23-08, 07:40 PM
57fairlane's Avatar
Official Member
I wouldn't swap the cam until you had the heads ported or bought better ones.
It will sound good but run like a dog . . .
  #5 (permalink)
Old 03-23-08, 08:14 PM
coolblue65's Avatar
I used to use a Edelbrock RPM in my 289 and it performed well with the stock heads. Sounded awesome!
  #6 (permalink)
Old 03-23-08, 09:03 PM
Banned
Now I used the comp cams 280H kit first, part # is K31-226-3. I love the cam but its WAY to much for the street, would be PERFECT for the strip.Then I put the 268H cam in and left rest of the kit. I just switched cams. Would the Edelbrock Rpm part #2221 match everything that I'm using now? Thanks everyone!
  #7 (permalink)
Old 03-23-08, 09:15 PM
brianj5600's Avatar
Official Member
Which intake do you have?
Edit: I looked on the CD site. I think it should work fine with the RPM cam.
  #8 (permalink)
Old 03-23-08, 09:16 PM
Banned
a weiand X-celerator
  #9 (permalink)
Old 03-24-08, 10:04 PM
If you don't like the 268H, then don't use the Edelbrock 2122. You won't be able to tell the difference between the two. I'm puzzled on just what you want here. You want the big cam sound but think the 280H is "too much" ? And you're not satisfied with the 268H? The X303 is way more cam than the 280H, only main difference between the two is the LSA. A roller is probably what you want, but to get one in a 289 block, it's going to cost you another $600 at a minimum, that's not including the cost for the screw in studs and springs to match the cam.
  #10 (permalink)
Old 03-24-08, 10:34 PM
Banned
I love the 280H but I know it was way too much. It had my engine and pipes shaking like crazy. I didnt know the X303 was more than that but thanks for telling me! Thats marks out the X303 then.. just want it to sound similar to this.. http://videos.streetfire.net/video/M...tion_94703.htm. Thanks for your help Mr. Hearne!
  #11 (permalink)
Old 03-25-08, 06:26 AM
Official Member
Garage
I put one of these in my 68 DQ 4sp car;
http://store.summitracing.com/partde...2&autoview=sku
Sounds real cool, but I broke a lot of valve train parts getting it together right.
There is so much more to building a car than just a big cam! It all has to work together, cam, fuel, transmission, rear end gears, exhaust, safety equipment, like seat belts and stuff! It all looks good on paper, and then somebody gets an eye poked out!
  #12 (permalink)
Old 03-25-08, 07:06 AM
You're wrong, it doesn't all have to "work together" (as in the "matched parts" you always hear about). Every combo of parts has it's own set of results. There's no reason the 280H was not streetable for mattj25's car. It's all in the tuning. You have to take the time to make it all come together. Like everyone says Holleys and multiple carbs require constant attention. Nothing is further from the truth. Want the "big cam" sound ? Look no farther than a B303 roller, by it's specs, it's the smallest of the Ford Racing "alphabet" cams but it's got a healthy lope at idle.
  #13 (permalink)
Old 03-25-08, 09:08 AM
Official Member
Garage
All I'm saying is that a lot of folks put in a huge cam, don't change anything else, and wonder why the car is slower than it was.
(I think the 280H is an excellent package)
I put an XE274H in my 69 351 W. It was a dog, wouldn't even turn over the tires! Then, (it's a long story) after I found out all the specs and what the cam needed to work, I started swapping parts.
3500 stall? Check. 3.73 or higher gears? Check.
Now, it's hard not to turn the tires. I've got an RPM air gap intake and 670 holley,complete MSD ignition, shift kitted FMX and 3.89's. But, since I installed the cam without knowing all the specs, I'm afraid to spin my motor over 4500 for fear of ruining my valve covers.
The cam alone will not make it a race car, any more than putting a '750 double pumper' on a stock 289, even though Shelby 289's ran a 715 cfm.
You can't tune in a gear ratio, or a power band.
Sure, you can swap parts as you go, but it's better to have a clear plan and a clear understanding of what you want.
  #14 (permalink)
Old 03-25-08, 10:20 AM
57fairlane's Avatar
Official Member
Quote:
So they imply that the 374rwhp was on the motor with gt40p heads and a 306?
Why didn't they just come out and say its got a plate . . . ?
  #15 (permalink)
Old 03-25-08, 11:12 AM
hivewax's Avatar
Official Member
Quote:
what plate?
  #16 (permalink)
Old 03-25-08, 11:54 AM
Official Member
It's a solid lifter cam conspiracy I tell ya...
Idle sounds very rough in that video and then in other parts of the video it sounds much smoother. Put a 270S in your 289 and be done with it. If ya want more testosterone, use a 282S...a very good cam for a 289.
  #17 (permalink)
Old 03-25-08, 08:18 PM
You could have skipped all the other parts and just cured the slow take off with just the gear swap. There was no need for a 3500 stall converter. A milder one would have done nicely. The one in my 77 Comet is probably less than a 2000 stall and with it's 3.50 gears Z303 cam all it takes to break the tires loose is a twitch of the gas pedal.
  #18 (permalink)
Old 03-25-08, 11:20 PM
brianj5600's Avatar
Official Member
Ford SB heads are not known for having a strong exhaust port. I think either of these would do fine. http://store.summitracing.com/egnsea...115+4294838638
  #19 (permalink)
Old 03-25-08, 11:38 PM
57fairlane's Avatar
Official Member
Quote:
Originally Posted by hivewax View Post
what plate?
no n/a 306 is making that power . . . more torque than HP, please.
the numbers fall in line with spraying 70-100 on it.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
