03-24-08, 01:30 PM
| | Official Member | | Join Date: November 2006 Location: Jackson Michigan
| | | Best drag radials on pony wheels???
I am looking to buy a set of of drag radials that will fit my pony wheels. I want to have a tire I can bolt on at home and drive to the track. I see many options. Micket Thompson. Nitto, BFG. Hoosier. I am looking for a tire that will give me the best traction at the track and I am not so worried about life because I will not drive them on the street except when driving to the strip. |
03-24-08, 01:33 PM
|  | Official Member | | Join Date: January 2003 Location: Indianapolis / Columbus, Indiana
I had good luck with the Nitto's but I was more concerned with tire life than you are. I've also had good luck with the BFG's but they didn't last quite as long. Never tried the MT's or the Hoosier's. |
03-24-08, 01:39 PM
|  | Official Member | | Join Date: March 2008 Location: New Jersey
Go with nitto's great tire for the track also good for the streets...I had them on a 89 iroc 350...with those tires and a 100 shot i used to go 13.0 and have 1.7 60ft's not bad for a tire you can drive to the track with...Thats what im going to use on my GT.... |
03-24-08, 01:45 PM
BFGs and Mickey Thompsons only come in 255/50/16. Nitto comes in 245/50/16. I already have 245/50/16 on the rear right now. I am not sure if the 255/50/16 will rub? |
03-24-08, 02:31 PM
I ran 255's on mine before I converted to 5 lug. Didn't have any problem with rubbing but I didn't have quad shocks either. |
03-24-08, 02:40 PM
|  | Official Member | | Join Date: May 2005
I swear i thought my old Nittos were 255/50/16, maybe they changed the sizes? They fit fine, absolutely no chance of rubbing anywhere.
I just made a thread in 5.0Talk, but i'm concerned about the tread life even though i'm only driving to and from the track. it came down to which would last longer even if for just a few more miles.
I just put my order in for BFGs. If tread life didn't come into play i would be waiting on a pair of MT drag radials.
IMO i dont think you'll be satisfied with the Nittos. Sure, you'll get more mileage and be MUCH safer in the rain with Nittos, but it doesnt sound like thats a concern for you.
From my thread: Quote:
Originally Posted by GroverDill Nittos last longest, hook least.
BFG's last less, hook better
MT's last least, hook best. | http://forums.stangnet.com/showthread.php?t=743241 |
03-24-08, 03:08 PM
|  | Founding Member | | Join Date: May 2002 Location: Orlando
I run a set of MT 255/50/16s on pony rims on my 93. Very nice tire for the track and occasional street driving but be warned they don't have a really long tread life and they DO NOT like the rain. |
03-24-08, 03:48 PM
So the 255/50/16 on pony wheels will work fine. It sounds like you guys are saying the Nittos are best for longevity and rain and the BFGs and the MT are best at the track and not so good for longevity. I guess it is narrowed down to BFGs or the MT. What style MT are best? ET Street, or the ET Street Radial? |
03-24-08, 04:42 PM
| | Member | | Join Date: July 2003
I am running MT Street Radials (255/50 - 16) and they work great. I put them on before heading to the track and take them off afterwards. |
03-24-08, 06:13 PM
|  | Official Member | | Join Date: May 2005 Location: KY
| | Quote:
Originally Posted by 91notchbk What style MT are best? ET Street, or the ET Street Radial? | The et street is a street slick, the street radial is a drag radial. Their probably is a life difference between the two. Also, with the et streets, and driving in the rain, its compareable to driving on ice. You also need tubes for the et streets. The et street radial is a street tire, with softer compound. |
03-24-08, 08:45 PM
Get the ET Street Radials.
The ET Streets are just DOT approved slicks. They have a little bit of grooving, enough to be DOT certified, and are like ice in the rain. |
03-24-08, 10:28 PM
|  | Official Member | | Join Date: September 2003 Location: Asheboro, NC
I just put the bfg d/rs on my ponys a month ago or so and they work very well. I wanted the mickeys but price and availabilty caused me to lean toward the bfg's. My car does not spin anymore though. |
03-24-08, 10:53 PM
|  | Official Member | | Join Date: November 2002 Location: ARKANSAS
mt is the only way to go have been on them and bfg's |
03-25-08, 06:24 AM
Ok, you guys like the MT street radial which is actually a drag radial. And possibly the BFG as well. I will compare prices. |
03-25-08, 09:12 AM
the mickeys are going to be more expensive but i promise its worth the extra cash |
03-25-08, 09:34 AM
|  | Official Member | | Join Date: April 2005 Location: Pa.
In a few weeks I will be ordering the MT's for my pony wheels. I have had the Nittos's but you really have to heat them up to get them to hook. On the street the nittos were far worse than my old falkens that were on. |
03-25-08, 10:08 AM
|  | invalid | | Join Date: July 2006 Location: Baghdad, Iraq
I've never had a problem with my Nitto. It's a great DR and does well in rain.
To each his/her/it's own.  |
03-25-08, 10:41 AM
| | Quote:
Originally Posted by Turkey Sammich I've never had a problem with my Nitto. It's a great DR and does well in rain.
To each his/her/it's own.  | i thought they were great on the street. When i got to the track though i was cutting the same 60ft times as worn out street tires. Now that might have something to do with the fact that I have a 1-2 shift problem (and me=teh sux), but i would have expected to see "some" improvement.
But you are right, to each his own. Everybody has different driving styles. I just think that for a dedicated "to the track and back" tire....the extra money is well spent on a set of BFGs or MTs.
EDIT: holy smokes! $187 for a nitto vs $156 (BFG) vs $174 (MT) at Jegs! When did that happen?? i always thought Nittos were 20-30 cheaper!
03-25-08, 11:16 AM
|  | Founding Member | | Join Date: May 2002 Location: MI (Lansing/Howell/Farmington Hillls)
| | Quote:
To each his/her/it's own.  | I thought the same way once….and for a daily driver (or one that gets higher mileage) I still think there is no other tire that can compare. 1.7 60's on my (then) mostly stock setup were not out of the ordinary….and up until you reach the 15k mile (mine always last 20k miles) mark they work great in the rain too.
Only because I drive the stang far…far less than I used to, I will now be switching over to a stickier drag radial. I am simply overpowering the nitto's with my current setup. |
03-25-08, 12:30 PM
| | Official Member | | Join Date: January 2008
It really depends on what you're doing.. if you're going to be using it as a street/strip kind of daily driver, then get the BFG's - they last long and are second only to MT's (from what i'm told)... however, if you have a separate set of rims that you're going to use only for the tracks, i suggest MT's - they are "by far" worth the extra money. |
03-25-08, 01:35 PM
|  | it sucks (I know) to be on the receiving end | | Join Date: November 2003 Location: Near Cincinnati, Ohio
| | Quote:
Originally Posted by mazroth The et street is a street slick, the street radial is a drag radial. Their probably is a life difference between the two. Also, with the et streets, and driving in the rain, its compareable to driving on ice. You also need tubes for the et streets. The et street radial is a street tire, with softer compound. |
For ET Streets, pour some dish soap inside the tire before mounting it...rub it all over the inside of the tire. Mount it without tubes. This will help prevent the rubber from letting air pass through it. It's a natural rubber which is why it leaks air, but the soap helps to fill the pores and slows down leaking. The tubes add considerable weight to the tires. Just keep an eye on tire pressure and hit the gas station air stations when you need to. |
03-25-08, 05:45 PM
|  | Official Member | | Join Date: May 2003 Location: Hudson, MA
how many miles are you guys getting on m/t drag radials? can i get 5000-7500? |
03-25-08, 06:23 PM
|  | Official Member | | Join Date: November 2003 Location: Stafford,VA
03-26-08, 03:08 AM
|  | Official Member | | Join Date: February 2004 Location: Calgary, Alberta
I have 275/60/15 ET streets on my coupe. |
03-07-09, 11:42 PM
| | Member | | Join Date: September 2006
ive had nitto 555r's since the august of 07. i think i put 10, 000 miles on them and their finally not legal. their great in the rain and hook amazing. i can do 2.5k dumps on the street in the summer and i just go. no spin. i planning on getting another set to replace them to be legal and then save these ones for the track. ive never used the other ones but i definitley feel these are a great tires. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
