03-28-08, 11:23 PM
|  | Official Member | | Join Date: May 2005 Location: Rowland Heights,California
| | | Guess on dyno numbers????
im trekking my car down 2 hours to CPR (10secgoal) to get tuned and dynoed.any guesses on my numbers(if it stays together  ).heres my combo.
349 stroker
9.3:1 compression,Mahle 6cc forged pistons
forged rotating assembly with girdle
MP 70 mm turbo,9 psi
CNC fully ported 70 cc Avenger heads,205 cc intaket runners,2.02/1.60 valves
Crane 1.6 roller rockers
custom grind roller cam,244*,.591 lift,114 lsa
ported Vic jr manifold
Performance Carb stage 3 blow through Holley 750 HP
Mallory Unilite with MSD Digital 6,
Product Engineering 360 GPH pump, -10 lines(1/2")
03-28-08, 11:44 PM
|  | Official Member | | Join Date: May 2005 Location: San Jose CA
humm i would guess only 310 Hp |
03-28-08, 11:45 PM
haha jkjk humm about 610hp |
03-29-08, 02:20 AM
|  | Official Member | | Join Date: September 2007
shoudl put down 450hp at the rear wheels at the minimum |
03-29-08, 09:24 AM
| | Official Member | | Join Date: February 2003 Location: Australia
03-29-08, 09:25 AM
Oh BTW - 10sec if youre reading this - do you have a kit that lets you keep the swaybar and P/s? |
03-29-08, 11:00 AM
| | Official Member | | Join Date: January 2007 Location: Camas, Washington
I will say 475 rwhp and 515 rwtq. |
03-29-08, 12:12 PM
| | Official Member | | Join Date: December 2003 Location: San Diego
| | Quote:
Originally Posted by C0V3R Oh BTW - 10sec if youre reading this - do you have a kit that lets you keep the swaybar and P/s? | Haha. I can in here to call my wife, and checked here. I knew there was a thread on this. Yeah, the kit Mario has is like that. You loose a good bit of ground clearance though.
I think 500rwhp or very close at 9psi is possible if the heads are what the porter claims them to be. We'll see. |
03-29-08, 07:11 PM
|  | Official Member | | Join Date: November 2004 Location: Aldergrove, B.C. Canada
435HP/275TRQ @5700RPM
Just a guess before final tuning. |
03-29-08, 07:19 PM
|  | Founding Member | | Join Date: February 1999 Location: canton, oh
03-29-08, 10:54 PM
03-29-08, 11:58 PM
| | Founding Member | | Join Date: November 2001 Location: Paw Paw MI
That thing sounds way better than 400hp to the wheels.......
Next time you go back, put a set of slicks on it to make sure you aren't breaking traction on the rollers.
Your car makes power really fast... you could be over powering the tires on the dyno and getting a false reading. |
03-30-08, 12:03 AM
I thought we saw some tire smoke and smelled them, but the cluctch ended up just killing the day.Its still a crazy ride, but couldve been crazier  |
03-30-08, 12:23 PM
| | Member | | Join Date: August 2006
| | Quote:
Originally Posted by Jimmys66 That thing sounds way better than 400hp to the wheels.......
Your car makes power really fast... you could be over powering the tires on the dyno and getting a false reading. | Bingo. I've heard 400 hp cars before and that doesn't sound like a 400 hp car.  |
03-30-08, 12:41 PM
|  | Official Member | | Join Date: February 2007
that dyno pull wasn't like any I'd seen. What type of dyno was it? Did you spool the turbo then hit the load on the brake? It seemed a bit fast. where did you start your pulls from? |
03-30-08, 05:17 PM
in 4th gear , i think Dustin had it about 22-2500 rpm and nailed.It revved REALY fast even before the clutch died. |
03-31-08, 03:45 AM
Wheelspin + clutch slip losing 100+ hp i reckon! |
03-31-08, 10:39 AM
How much power were you making with the blower setup? |
03-31-08, 11:00 AM
That carb was extremely fubar. PV in both front and rear, both PVCR's over 5/16's. Was shooting ducks pretty bad the first few pulls. Had to block the rear, and make the front PVCR's smaller. All the way to .059 and knock jetting out before we could even see the A/F. It was taking a good nose dive when the clutch would slip, then it would level out. The carb has HUGE venturis causing the A/F to nose dive. I know it's making tons of power, clutch just won't hold. Never smelled it though. But it was confirmed when we did a back to back test and the RWHP dropped 50. Took a little bit to figure out if it was the clutch, or the extremely rich A/F. |
03-31-08, 12:31 PM
the pvcrs were 5/16" WOW you must have had some gorilla holley "tuner" working on it earlier. I thought you just plugged the pvs and jet it up with a blowthrough setup. Those pulls looked extremely quick and I wouldn't be surprised if the dyno didn't apply the proper brake force, the clutch and/or tires slipped, or some combo of the three |
03-31-08, 01:20 PM
| | Quote:
Originally Posted by mrmustangman357 the pvcrs were 5/16" WOW you must have had some gorilla holley "tuner" working on it earlier. I thought you just plugged the pvs and jet it up with a blowthrough setup. Those pulls looked extremely quick and I wouldn't be surprised if the dyno didn't apply the proper brake force, the clutch and/or tires slipped, or some combo of the three | Noooooo. You need them. If you block and jet up, you run around town with 80's in the front and probably 10-1 AFR. Generally jet down, then larger PVCRs. I try to keep them small so the motor doesn't load up when it opens. |
03-31-08, 06:22 PM
|  | Official Member | | Join Date: April 2005 Location: Oakwood, GA
| | Quote:
Originally Posted by Jimmys66 Next time you go back, put a set of slicks on it to make sure you aren't breaking traction on the rollers. | I don't know about you, but I don't have ~$360 to waste on tires just to dyno.
A traction problem is not about tires and you WILL wear out slicks extremely fast on a dyno.
Its all about the straps and weight in the back. We have had plenty of cars over 800rwhp on our dyno that didn't wheelspin.
Hope you get the carb worked out.
That motor should make close to 400rwhp on the motor . . . |
04-02-08, 03:39 PM
| | Quote:
Originally Posted by 57fairlane I don't know about you, but I don't have ~$360 to waste on tires just to dyno.
I didn't say anything about BUYING a set of slicks. I said put a set on.
I don't own a set either, but between my other 3 car buddies I could borrow a set for the day.
And not to poke at Isk but, with a car as fast as his I would own a set of slicks.  |
04-02-08, 05:50 PM
| | Quote:
Originally Posted by Jimmys66 And not to poke at Isk but, with a car as fast as his I would own a set of slicks.  | at this point, slicks would cause other damage(body,drivetrain etc) so i'll work with street tires and learn to skate  |
04-02-08, 08:21 PM
| | Quote:
Originally Posted by iskwezm so i'll work with street tires and learn to skate  | Yep, it is an art form. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | | |
