Mustang Forums at StangNet
Oil pump for 347 stroker
This is a discussion on Oil pump for 347 stroker within the 5.0 Tech forums, part of the 5.0 Mustang category; Not sure where to be asking this at but here goes I was looking at oil pumps for 302 engine ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-03-08, 10:43 PM
I was looking at oil pumps for 302 engine they have an OEM
a high pressure and a high volume this is going to be a 347 stroker
and I dont want her to starve oil
thanks
  #2 (permalink)
Old 04-03-08, 10:56 PM
timeless2's Avatar
Vi Veri Veniversum Vivus Vici
What year of car are you working on?
  #3 (permalink)
Old 04-03-08, 11:57 PM
I'm actually working on a 1995 F-150 putting in a 347
  #4 (permalink)
Old 04-04-08, 08:24 AM
timeless2's Avatar
Quote:
Good deal. If we don't get any more bites in here, I can relocate / direct more attention to this thread from another section to help you out more.
  #5 (permalink)
Old 04-05-08, 02:03 AM
Most appreciated timeless2
  #6 (permalink)
Old 04-05-08, 08:29 PM
timeless2's Avatar
Moved to 5.0 Tech from Other Auto Tech for more responses.
  #7 (permalink)
Old 04-06-08, 05:02 AM
thank you much
  #8 (permalink)
Old 04-06-08, 05:19 AM
dcurtis's Avatar
Official Member
I say run the high volume only if you plan on racing the engine if not a stock volume pump pushes enough oil in my opinion, I only run high volume pumps in mostly race engines, not street engines, if you do go with a high volume pump get a oil pan that holds 1 or 2 quarts more than stock or you will starve the bottom end.
  #9 (permalink)
Old 04-06-08, 06:21 AM
Rick 91GT's Avatar
Officially Addicted
The type of oil pump really depends on the clearances you build the motor at. If you stay with fairly tight clearances a stock pump will work just fine, M68.
  #10 (permalink)
Old 04-06-08, 08:15 AM
rd rd is offline
It seems the thinking on this has changed a lot over the years.
When I had the shortblock built built for an engine in 1986, everyone said to put a high volume oil pump in it, so I did. That engine is still running fine in my 82, w/ 95k miles, and a couple hundred track passes. Oil pressure is still halfway up the stock gage. I have never had a numeric gage on it. This engine has always had 10W40.
Advice changed to using a standard oil pump, but I still put the same Melling HV pump in the new engine in my Capri in 2000. I assembled this one, worked on by a different, and much more performance oriented machine shop, and it has very tight bearing clearances, and it has the stock oil gage pegged 99% of the time. Hot, at idle it drops to 2/3s. I had to switch back to 10W30 on this one. I don't remember exactly, but mains at .002 or less, by plastigage.
I used the Ford Racing pump driveshaft in both, and would recommend it in any engine. Both engines have stock 5.0 oil pans.
So, I would say the standard pump would be fine, and free up some hp.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
