Mustang Forums at StangNet
Mods of your 35ths!!
This is a discussion on Mods of your 35ths!! within the 35th Anniversary forums, part of the Special Production category; i want to start a thread to see how modified you have your GTs, i am going to the bolt ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Special Production > 35th Anniversary
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 05-08-08, 07:25 PM
i want to start a thread to see how modified you have your GTs, i am going to the bolt on tunned high 12s GT way! i hope i make it
Mods
UPR cold air intake done
75mm BBk throttle body,
75mm TrickFlow plenum
BBK 1 3/4 Long tube headers done
BBK Underdrive pullies
Unknown brand o/r X pipe (already came when i bought it)
Borla's ProXs done
FRPP 4.10s done
Subframe welded conecctors (already came when i bought it)
red springs, don't know brand (already came when i bought it)
M/T 275/40/17 Drag Radials done
i'm planning to go to Sanolis performance solutions located in the RGV for the dyno/tune
lets see those 35ths mods!
  #2 (permalink)
Old 05-09-08, 02:22 AM
jcint's Avatar
Official Member
I got the basics: 93 octane tune, x pipe no cats, shorty headers, under drive pullies,upper and lower control arms, canton oil pan. I think my next mod will be the typhoon and plenum package and maybe a little shot of nitrous.
  #3 (permalink)
Old 05-09-08, 10:10 PM
Tommy3O3's Avatar
Here's a basic list of mods for my 35th. It's still in the shop getting the motor finished, so there'll probably be more parts added to this list:
Forged motor
Cobra Crank
Bullitt intake
Twin 52 mm Bulitt TB
ProCharger D1SC with 3-core intercooler and 12-psi pulley
2003 Cobra tank and dual pumps
Diablo Predator
Diablo MAFia
Mach 1 Grill Delete kit
Mach 1 Front Splitter
Granatelli upper and lower control arms
Cut FMS 'C' Springs
20% Tint
Complete front bumper clear bra wrap
Magnaflow Exhaust
BBK High-flow Cat pipe, (for emission time)
Steeda front sway bar
Steeda Tri-Ax Short Throw Shifter
FMS 3.73 gears
Tokico HP Shocks and Struts
18" BBS RK II's
MT ET Streets
SCR Subframe Connectors
Baer 13" Track Kit with 13" rear rotors as well
Tremec T-56 6-speed transmission
Moser racing axles
Auburn Pro Posi
SLP Line-Lok
Rear Differential Cap
BBK Longtube headers
BBK Off-road H-pipe
Aluminum Driveshaft
Custom stage II blower cams built by Crane for Modular Performance.
New valve springs
New stock retainers
New crank bearings
New rings
New rod bearings
New Manley custom .20 over oil coated pistons
Kenne Bell Boost-a-pump
62 lb. Siemen's High Impedance fuel injectors
PI head cores
spark plug stainless steel inserts
machining for larger intake and exhaust valves, (1mm more flow)
CNC intake and exhaust ports & combustion chamber
Spec Stage 3+ clutch
Pioneer 940MP
2 Alpine 10" Type R Competition Subs
Sub Caps
2 Alpine Amps
8 Boston Accoustic mids/tweets
MGW Headlight switch
MGW Shiftknob
MGW E-brake handle
Chrome bumper inserts
Custom "35th" front license plate
American Muscle blacked out head lights
ATS Sequential Tail lights
Blacked out Tail lights
Interior Dash Trim Kit
Custom Valve covers
All the associated stuff necessary like gauges 'n things.
  #4 (permalink)
Old 05-17-08, 10:58 AM
blkhorse's Avatar
most of my mods are in my sig. I am in process of a 5.0 stroker with billet rods/alum. block/cp piston's
  #5 (permalink)
Old 05-17-08, 08:33 PM
Red9935thGT's Avatar
Official Member
A list of my mods and other pictures are here - http://www.chicagolandmustang.com/fo...ad.php?t=17244
  #6 (permalink)
Old 05-18-08, 10:27 AM
Mods in sig
  #7 (permalink)
Old 05-20-08, 08:28 PM
blacksheep-1's Avatar
Stallion
Eibach lowering springs
Steeda bump steer kit
Hedman "H" pipe and flowmaster cat backs
Aluminum flywheel
Steeda shifter
K&N air intake
Convertible subframe connectors
Motorsports Weapon Wheels 18x9
99 Cobra nose
6 psi Kenne Bell supercharger
Cobra IRS swap (3.27 gear)
BTW link for the swap:
http://www.tamparacing.com/forums/fo...tick-axle.html
  #8 (permalink)
Old 06-21-08, 08:41 AM
35th on Procharger website
My 35th was just put on the Procharger website gallery. Check it out.
http://www.procharger.com/gallery/search.php?market=1
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
