06-20-08, 11:03 AM
| | Official Member | | Join Date: December 2003 Location: San Diego
Not sure on the paint scheme. The owner had the rendition done. I'm just paying attention to the structural part of the drawing.
The exhaust is still going to go up and over the axle. We got some tricks though.  |
06-21-08, 09:22 PM
| | Official Member | | Join Date: February 2003 Location: Australia
| | Quote:
Originally Posted by SNAKEPILOT Composite springs and staggered shocks - you won't need a torque arm.  | How much of a difference do the staggered shocks make? I have FAF's but I get axle tramp fairly badly compared to my old leaf + slapper bar setup. |
06-21-08, 10:01 PM
| | Official Member | | Join Date: June 2004
GREAT looking concept! i love the colors and stance. |
06-21-08, 10:11 PM
| | Official Member | | Join Date: July 2005
I have a 482 FE with a TKO600 and 3.50 rear. It puts a fair amount of torque to the rear wheels. I have zero wheel hop. When I had regular leafs and under ride "traction master" type bars, I had terrible wheel hop. I also have Shelby snubbers for my springs so that may have help eliminate wheel hop.
06-21-08, 11:38 PM
|  | Official Member | | Join Date: September 2003 Location: Middle Tn.
That set up should put out more than 700 rwtq. What ever the rear suspension is used, it won't have an easy job. Any leafspring set up will need help IMO. |
06-22-08, 04:52 AM
Thats very weird. I have a 300+hp 302, tko600 and 3.5 rear with FAF's and bad wheel hop. The only thing I am missing is the shelby snubbers and the staggered shocks it seems. I wonder which of the two is doing more.
Did you always have the staggered shock setup? Do you think it makes much difference? |
06-22-08, 08:25 AM
It's a real mild 482 so I can run power brakes and A/C. I am guessing 500hp/525tq.
67s didn't come with staggered shocks. I converted mine because of my previous wheel hop issues. Ford offered a drag-pack option on their 69-70 Mustangs that came with staggered shocks. They were also on GT-500KRs.
Likewise, the Shelby snubbers are supposed to preload the front half of the spring during hard acceleration to keep the springs from warping and initiating wheel hop.
I didn't want any wheel hop with the new motor so I took a three prong approach to eliminate it. Mono-leafs (Flex-a-Forms), staggered shocks, and Shelby snubbers. I am using Global West Delalum bushings too which may also help. I think when you get Cal-Tracs, they come with a solid front bushing to eliminate front eye movement that exacerbates wheel hop.
06-23-08, 02:10 AM
|  | Official Member | | Join Date: April 2006 Location: Copenhagen, DK
| | Quote:
Originally Posted by brianj5600 That set up should put out more than 700 rwtq. What ever the rear suspension is used, it won't have an easy job. Any leaf spring set up will need help IMO. | Indeed! The new tranny will take around 800 lb.ft. and that'll be the limiting factor. Engine is built to take more just in case we decide to up the boost later on. I wouldn't rely on just composite springs, the torque arm is a must and also contributes to a very solid road feel. Also with a composite you loose the ability to repack the leaf sets for different spring rates and ride heights.
Color scheme, try looking at the George Follmer 69 Trans Am Mustang and you'll see where the idea came from. http://www.trans-amseries.com/Driver...ockMustang.htm
The originals rear paint scheme is odd, so we're trying different ideas with and without white divider, all green , all black etc. |
06-23-08, 11:19 AM
| | Quote:
Originally Posted by DK832 Indeed! The new tranny will take around 800 lb.ft. and that'll be the limiting factor. Engine is built to take more just in case we decide to up the boost later on. I wouldn't rely on just composite springs, the torque arm is a must and also contributes to a very solid road feel. Also with a composite you loose the ability to repack the leaf sets for different spring rates and ride heights. | Yeah, it's rated at that in a 3800 lbs car. This will be lighter obviously, but I think with the gear ratio it'll have, it's going to offset the weight savings.
I wouldn't trust this to just staggered shocks either. They won't help plant the tires like a torque arm. |
06-24-08, 08:44 AM
| | Official Member | | Join Date: August 2005 Location: los angeles, ca
| | | hey! Quote:
Originally Posted by SNAKEPILOT I have a 482 FE with a TKO600 and 3.50 rear. It puts a fair amount of torque to the rear wheels. I have zero wheel hop. When I had regular leafs and under ride "traction master" type bars, I had terrible wheel hop. I also have Shelby snubbers for my springs so that may have help eliminate wheel hop.  |
what rear breakes are those? |
06-24-08, 08:54 AM
Wilwood 12.2" two piece rotor and hub with integral parking brake. |
06-24-08, 11:20 AM
Can we keep the questions to PM's fellas ? Already have 8 pics of a car that isn't the subject car.  |
06-24-08, 12:18 PM
My bad. I pulled the pics from my posts but can't do anything about the responses that quoted my pics.
Great project. Keep the updates coming. |
06-24-08, 12:26 PM
| | Founding Member | | Join Date: August 2002 Location: lubbock, texas
| | Quote:
Originally Posted by 10secgoal Can we keep the questions to PM's fellas ? Already have 8 pics of a car that isn't the subject car.  | just standard SN threadjacking....i don't see the problem really.  |
06-25-08, 10:24 AM
No hard feelings. It's it can get out of control pretty easy. |
06-25-08, 12:18 PM
|  | Founding Member | | Join Date: August 2000 Location: Currently: NH Originally: Rhode Island (and all points in between.)
So has anyone seen the new hulk movie yet? And what's up with these gas prices?  |
10-11-08, 11:27 AM
10-11-08, 11:30 AM
10-11-08, 12:42 PM
|  | Official Member | | Join Date: May 2004 Location: London (uk)
looking good, keep the picture coming  |
10-13-08, 11:26 AM
|  | Official Member | | Join Date: February 2007
that is gorgeous. the donor car's engine bay looks so good! |
10-13-08, 07:51 PM
|  | Official Member | | Join Date: April 2005 Location: St. Mary's, GA
10-14-08, 02:35 AM
10-29-08, 03:11 PM
Need to make some corrections I left in. We decided on a Worlds block, even though I wrote in Dart at the top. And we went with a hyd cam. Didn't want ANY issues. talked to local guys that were breaking rockers around town at low RPM's, even with low lash solids. Without the rebound from the spring at high rpm's, figured it was breaking from bouncing off the backside of the cam. We'll still meet our HP goal, just a little more cam.
Shaved the trunk lock hole. You can see a little heat fence around it to minimize heat warping.
All done with the trunk
Some antenna hole shaving
More heat fence with the anntena
And done with it
Some frame sleeving for the K-member bolts
We've got the Fab 9 in, just need to get the calipers on and take some more pics ! |
10-29-08, 05:32 PM
| | Official Member | | Join Date: January 2007 Location: Camas, Washington
What is your HP/TQ target on this build? |
10-29-08, 05:40 PM
Tranny and clutch are rated to about 850 in drag racing scenarios @ around 3800 lbs. We'll be under that. But 700rwhp around 15-17psi. Tranny setup is the only weak link. Everything else is rated over 1k hp. Upgrade turbo and fuel sytem, set on kill  So it should be perfectly reliable at 700rwhp. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | | |
