Mustang Forums at StangNet
Need some help guys...car related
This is a discussion on Need some help guys...car related within the WC Classifieds forums, part of the West Coast category; I am thinking about selling/trading the stang. I never drive it, and it has only had about 4 miles, yes ...
Go Back   Mustang Forums at StangNet > Regional Forums > West Coast > WC Classifieds
Over 151,000 Members!!
  #1 (permalink)
Old 06-02-08, 05:54 PM
SQUEEZE&STROKE's Avatar
Official Member
I never drive it, and it has only had about 4 miles, yes only 4, since I put it all together. It runs like a beast, but I dont get to enjoy it. I want something I can drive everyday.
I spent about $13,000 last year alone on it.
I KNOW I will not get what I have in it out of it, but it is easily over 25K at this point. What does everyone think a fair price to list it as/trade for.
I AM VERY OPEN TO TRADES. I am hoping to find a newer GT/Mach/Bullit/Cobra.
It has the following mods:
Moser 33 spline axles with c-clip eliminators
Moser 33 spline spool
Ford Racing 4.30 gears
Ford Racing rear end girdle
BBK rear upper and lower control arms
Strange engineering Pinion yoke
Strange engineering custom length Chrome-moly driveshaft
Strange engineering hardened driveshaft yoke
Mike’s Transmission ultimate C-4 with transbrake, multiple clutches, hardened output
B& M 28 oz flexplate
JW “The Bell” blowproof bell housing
Moroso finned aluminum transcooler
B&M deep trans pan
Hitachi 360 degree clocking mini starter
Canton Drag pan with crank scraper and kickout
Canton Oil Pump pickup
Standard volume oil pump
ARP Oil pan studs
Early 80’s 302 block professionally decked, line honed, and machined by FPS
Eagle 331 crank, I beam Rods, SRP Pistons
Canfield Avenger CNC’d head-2.100 intake, 1.70 exhaust (Flow 322 cfm @ 600)
AFM N-111 cam
ARP Cam Bolt
All engine bearings Clevite H-race series bearings
Speed Pro file fit rings
Ford Racing Timing chain
FPS main girdle with windage tray and ARP Main Studs
Parker Funnel Web intake
Holley 750 HP carb
Aeroquip Stainless #8 carb lines and swivel fittings
Ford racing valve covers
ARP valve cover studs
CSR Billet throttle cable bracket
CSR Billet Electric water pump
CSR Billet water neck
CSR Billet fuel pump block off plate
Ford Racing Vacuum pump
Aeroquip stainless #12 hose and swivel fittings on Vacuum system
Moroso Aluminum Catch can
Comp Cams 1.72 rockers
ARP Rocker studs
Comp Cams Rocker stud girdles
Comp Hardened CORRECTLY MEASURED pushrods
Cometic Head gaskets
ARP Hardened oil pump driveshaft
MSD Billet Distributor
MSD 6AL
Bassani 1 & ¾” to 1 & 7/8” stepped headers
3” Bassani x pipe
3” bassani flow tubes
3” Spin tech mufflers
Global west full length subframe connectors
D & D tubular K member
D& D tubular A-arms
D& D coilover kit
QA1 175lb 14” coilover springs
Lakewood 90/10 front struts
UPR Billet aluminum caster/camber plates
PP Billet regulator
Holley blue fuel pump (-8 feed line)
Moroso 8” fuel filter
Mallory fuel pump pickup
Flaming river manual steering rack
Strange engineering manual brake Master cylinder
Moroso Line lock
Precision Performance billet shifter with integrated neutral safety and transbrake switches
Kirkey pro street drag seats
Kirkey black tweed covers
Autometer Fuel pressure, oil pressure, water temp, trans temp, Pro shift light stage 3
Autometer dash clock pod, a pillar pod, steering column pod
Painless Performance 8 switch panel (car was professionally wired)
All interior pieces there
Moroso main power disconnect switch in rear bumper.
HO Fibertrends Cobra RR pin on hood
Weld Prostar wheels, 3.5” up front, 9” out back, with an extra set of rear wheels w/tires
Factory Ford color DSG paint (Few months old)
NO DENTS AT ALL. Maybe a few small scracthes here and there.
Thanks guys
Pics
  #2 (permalink)
Old 06-02-08, 10:24 PM
Gearbanger 101's Avatar
SuperMod
Canadian Colossus
Bad ass looking ride, but are you sure you posted this in the right classifieds section?
  #3 (permalink)
Old 06-03-08, 11:05 AM
Official Member
Thanks Gear Banger...
  #4 (permalink)
Old 06-20-08, 12:58 PM
Official Member
Taking offers and offers for trades...
parrish.jeffrey@yahoo.com
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
