Mustang Forums at StangNet
ABS Light/Traction Control
This is a discussion on ABS Light/Traction Control within the Mach 1 forums, part of the Special Production category; Hello everyone!! This is my first time here... and I'm here for a reason. I need some help! My boyfriend ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Special Production > Mach 1
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-05-08, 09:56 PM
Question ABS Light/Traction Control
My boyfriend has a 2004 Mach 1 (my avatar is a pic of it).
Recently, the ABS light has been coming on and off. We didn't notice until driving at night once, that when the ABS light is on, the traction control light on the button is also on. Once that light is on, the button won't turn the light off even once pushed. Then when the ABS light goes back off, traction control can be turned on and off like normal.
The car itself has been working fine, no problems at all.
I was wondering if anyone else has had this problem? What is causing this to happen?
Thanks for your help!!!
  #2 (permalink)
Old 06-06-08, 09:07 PM
twogts4us's Avatar
Official Member
Garage
Ck the brake fluid level.
I'd also inspect the wheel sensors (they look like sprockets that feed wheel speed to the ABS system)
The ABS system and the TC system are related.
  #3 (permalink)
Old 06-13-08, 09:28 PM
Sooo... we checked the brake fluid, no problem there. Then, we were able to take the Mach 1 to a brake shop and they ran a diagnostic. The light wasn't on at the time (of course... err) and no codes were found. The guy we took it to agreed that it is a wheel sensor, we have to figure out which one is making the problem.We will just have to time is out right to run the test for ABS light codes.
Now, we've noticed a weird crunching sort of sound when you push the brakes in hard at a stop. And if you listen really closely, it sounds like pressure lets out like a small hissing sound. Then, a sound comes from what sounds like the rear axel, sort of like something is flapping or wrapping around while the car is in motion, not at a stop. It's very frustrating! It seems like when the ABS lamp is on, the sound can't be heard, when it's off, it's very loud and obvious.
Hopefully, we can get it out to the shop with the light on soon and fix this bad boy back right!!
  #4 (permalink)
Old 09-05-08, 12:06 AM
62thunderbird's Avatar
The hissing noise just may be the calipers grabbing the rotors lightly. My mach does it I think it is the calipers slightly rubbing on the rotors. About the rear end, I am not sure what you mean. I think it may be just the drive shaft moving when you turn. I was driving my mach and turing at slow speeds I hear a clanking come from the rear it is the drive shaft moving a little. Just a guess.
Reply
Tags
abs, control, traction
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
