Hello,
I just have a few questions regarding my 93 coupe. The car has a few idle problems, noticeably hunting around at idle (which is set at probably 800 or 900), sometimes dropping to say 400 rpm, then surging back up, and sometimes flat out dying. And when I'm running the AC in town, I can get it to die almost consistently when I stop at a light, when the motor gets back down to idle. Which is terribly annoying, as it means I don't use the AC much in town (in Houston).
Now, perhaps it's my meter that's the problem (as I hear the C&L's hunt around due to the design), in which case Id like to hear opinions. Or maybe I need a better tune for Houston (car was tuned in NM before I came down here).
My combo:
CHP 331 with AFR 185's, TFS Stage 2 cam, Edelbrock Performer RPMII, 30lb injectors, C&L 76mm MAF, Accufab 70mm TB, using stock airbox with K&N filter (is this too restrictive?), 130amp alt, stock ignition...
Perhaps the C&L is the culprit, however Ive had more success with it than an 80mm Pro Mass Air (which throws a code, saying it doesn't have enough air). Is this something that will be resolved with a tune, or adjusting my idle? I need to get the car dynoed here, but I was hoping to resolve any simple issues before I took the car in, as that will undoubtedly increase my shop time.
Any ideas? Let me know if more info would help...
Thanks...
