Mustang Forums at StangNet
I need help! Ignition problems
This is a discussion on I need help! Ignition problems within the Fox 5.0 Tuning forums, part of the 5.0 Tech category; I did an efi swap in my 67 mustang. I have s-trim supercharger on a 331 stroker. I also have ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech > Fox 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-16-08, 09:27 PM
Official Member
I did an efi swap in my 67 mustang. I have s-trim supercharger on a 331 stroker. I also have a msd 6al box with the msd/vortech boost controller module. When I went to start the car I was not getting any spark. so then I tried to bypass the ignition box then I started getting spark. Also for some reason when I move the distributor it cycles the fuel pump?? I have no Idea why this might be happening Anybody?
Thanks in advance,
Kyle
  #2 (permalink)
Old 06-16-08, 09:51 PM
mustangfan1990's Avatar
Official Member
would sound like your msd box is bad if you bypass and it gets spark. The Distributor has a igintion module on it correct? if so alot of times that is how the computer knows which injectors should fire when it does so when you turn the distributor your injectors should click also
  #3 (permalink)
Old 06-16-08, 10:08 PM
Official Member
Yes, it does have an ignition module. Yes the injectors alson click.
So this is normal to be happening its not a wiring problem?
Also thanks for your help.
  #4 (permalink)
Old 06-18-08, 09:45 PM
Official Member
No this is not a wiring problem. This voltage being cycled through the igintion system from the computer very normal. If it doesnt click then I would be worried
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
