View Single Post
  #25 (permalink)
Old 07-22-08, 01:27 PM
1990Coupe's Avatar
1990Coupe 1990Coupe is offline
there's nothing cool to put right here
Quote:
Originally Posted by SVT32VDOHC View Post
Oh yeah...the bracket on the rubber brake line, just mount that to the frame rail. I did that with Hack Job. I just drilled small pilot hole in the frame rail, then ran a sheet metal screw through the bracket, just like the factory 94-04's are mounted. You will just have to mock that up once the rear end is installed, the springs are installed and the exhaust. I mounted mine before the exhaust, then had to redo them once the tail got mounted. You'll get it. Don't sweat anything.
OHHHHHHHH so what you are saying is, the original softline running to the rear end, then running to hardlines along the housing to the Drum i will no longer use, and i'll mod the hardlines on the CAR like this picture perhaps?
